I am unable to program the remote. The numbered buttons do not access a specific channel and the channel and volume buttons do not work.
    Brigadier General:
  • 3,513 Answers
Thank you for contacting Fixya.com
To program a remote please follow the bellow mentioned steps:
Turn on the component you want to program.
  • Press and release the component button on your remote that corresponds to the component you want the remote to operate (TV, VCR, etc.). The illuminated ON-OFF button will turn on and remain on.
  • Press both the component and the ON-OFF buttons. The illuminated ON-OFF button will turn off, and then will come back on.
  • Release both buttons after the ON-OFF button turns back on. The button should remain illuminated.
  • Press and release the PLAY button. If the component does not respond after five seconds, continue to press the PLAY button every five seconds until the component turns off.
  • Press and release the REVERSE button when the component turns off, then wait to see if the component turns on again.
  • Press and release the STOP button to save the new code.
  • Hope this resolves the issue.
    God Bless
    Posted on Jul 15, 2009
    TV is on one channel and will not work with remote or allow me to change channells from side of tv
    I've run into this same issue. Although not a complete fix, I was able to program the tv with a basic universal remote. Try using the Goldstar remote codes. While I'm unable to use the channel buttons, I can change channels manually and turn the tv on/off and use the volume button. Again, not a fix, but a work around for now.
    Jun 25, 2011 | Element Electronics FLX2211B 22 in. LCD TV
    Original remote lost. have universal remote. cannot program TV
    On the right hand side of this television there are panel buttons. It appears that your son in law knocked the tv out of the correct input. Press the input button in order to cycle through the 5 inputs. Typically pressing the input button on the side panel of a television and pressing it again and again and again will make it change inputs. Universally the buttons on the tv panel function as follows: Channel up moves the cursor up. Channel down moves the cursor down. Volume + moves the cursor right. Volume - moves the cursor left.
    Hope this helps
    Apr 28, 2010 | JVC LT-42E478 42 in. LCD Television
    I have a philips I got from a hotel but i cant program the channel to 3 to hook up a dvd player even with a universal remote what do i do?
    Channel 3 is probably locked out... here is how to fix it....
    1) Press the Menu button on the remote or press both Volume buttons on the front of the TV to access the TV's internal menu's
    2) Scroll to highlight INSTALL using down arrow on the remote or Channel - on the front of the TV.
    3) Press the Right Arrow on the remote or Volume + on the front of the TV to access the INSTALL menu.
    4) Scroll to highlight Channel Edit using down arrow on the remote or Channel - on the front of the TV.
    5) Press the Right Arrow on the remote or Volume + on the front of the TV to access the Channel Edit menu.
    6) Use the Left or Right Arrow on the remote or Volume + / - on the front of the TV until you get to Channel 3.
    7) Use the Down Arrow on the remote or Channel - button on the front of the TV to select SKIPPED.
    8) Press the Right Arrow on the remote or Volume + on the front of the TV to select OFF.
    9) When finished press Exit on the remote or press the power button on the TV and then power the TV back on.
    You should now be able to use channel 3.
    Good Luck....
    Jan 15, 2010 | Philips 20PT6441 20" TV
    Cannot access channel 73 on TV2
    If you are unable to access the TV menu using the buttons on the TV itself it is possible you can with the TV2 remote if it still controls the volume etc. for this TV. If it doe not you will need to find a code for your set in the manual for the receiver or you can go to the following link to find that info as well.http://tech.dishnetwork.com/departmental_content/TechPortal/content/tech/receiver/625.shtml
    Assuming you have control of the volume still press the small TV button on the top left of the remote. Now press the menu button and you may be able to access the TV's menu. If so you need to run a channel scan/auto program the TV. You may need to use the buttons on the TV still to maneuver through the menu.
    If you are still unable to access the menu you may need to purchase a universal to access the menu.
    Jan 11, 2010 | DISH Network DVR-625 DTV Receiver /...
    I was able to program my Comcast remote to control the volume of my tv, but was unable to get it to change channels. Is there something else that I should do?
    Controlling the TV power and volume is probably all you'll be able to do with that control. The Comcast remotes are meant to be used with their converter boxes, and normally people want to change channels on the box while the TV stays on the box output channel (usually 3, sometimes 4). The remote's channel up and down buttons and number keypad only send out the codes recognized by the converter box. You'll need to fall back to the TV remote if you want to control more than power and volume.
    May 04, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
    No remote specific to Sharp combo unit..how to turn off closed captionning
    on some models the menu button is on the front disguised as the volume up/down or channel up/down buttons. you have to push both up/down buttons on either one of these to bring up the menu.
    Apr 24, 2008 | Sharp 13VT-K100 13 in. Combo
    Multiple issues with tv
    Pressing i+ button (bottom left on the original remote) for 5+ seconds worked for me...
    Feb 21, 2008 | Philips 32PF5320 32 in. HD-Ready LCD...
    Sylvania 6313CB 13" TV/VCR replacemnt remote
    We have a Sylvania 6313CB TV/VCR combo.  I bought a universal remote and the code would not work when I tried to program it to the "TV" button using all those possible codes listed in the books.  So, on the universal remote, there was a button named "VCR" and when I programmed in the code "0000" all worked.  This was a $6.00 universal remote named "One For All"  we bought at the Big Lots store.
    Specifically, here is what I did:
    Turned TV on Pushed the "VCR" button and light blinked once Pushed and held the "set" button until it blinked twice Released the "set" button and entered the numbers "0000" Pushed the on/off button and it worked including volume, channel up/down and channel change by entering the channel number.
    Hope this works for you too.
    Jan 14, 2008 | Sylvania 6313CB 13 in. TV/VCR Combo
    Channel memory reset
    Bryan,
    Usually the menu can be accessed from the buttons on the console, sometimes by pressing a "menu" button but other times by pressing both Volume or Channel (+ AND -, UP AND DOWN) buttons simultaneously. Menu levels are usually selected with one or the other of Volume or Channel, and toggles/selections with whichever doesn't do the levels.
    Nov 05, 2007 | Sharp 27K-S300 27" TV
    Lost the remote, manually need to access Menu button
    VCRs since the early '90s have limited function with the machine located controls, and a remote is necessary to get into most setup options, probably including the channel add/delete. Many VCRs do have an auto program mode which searches for active channels, but I'd guess this also is activated via remote. A universal remote which specifically has the capability of performing the advanced functions is probably available. Look here for an exact http://www.electronicadventure.us/panasonic.htm Part number is VSQS1418 according to this site for PV4501.
    Aug 27, 2007 | Panasonic PV-7661 VCR
    Televison & Video Logo
    16 people viewed this question
    Top Televison & Video Experts
