Question about Hunter 27187 Remote Control
Light and fan turns on by themselves - Interference
Light and fan turns on by themselves - I believe it is an interference problem - How do I adjust the receiver range down?
  • 147 Answers
This is not a interference problem.impossible!!
there not any way to turn the receiver range down.reset the tv by pressing the system reset button on the front of the tv.
Posted on Jul 15, 2009
Chrysler Sebring 2001 3.0 v 6 sohc interference motor or non interference I've seen answers that it was and then it wasn't
Chrysler
  • 1.4L, 1.5L & 1.6L Interference
  • 1.7L Non-Interference
  • 1.8L Interference
  • 2.0L DOHC Interference
  • 2.0L SOHC Interference
  • 2.2L DOHC Interference
  • 2.2L SOHC Non-Interference
  • 2.22L SOHC Interference
  • 2.3L Diesel Interference
  • 2.4L DOHC Non-Interference (Valves may hit if camshafts turn out of time)
  • 2.4L SOHC Interference
  • 2.5L 4 Cyl. Non-Interference
  • 2.5L V6 Interference
  • 3.0L SOHC 12 Valve Engine Non-Interference
  • 3.0L DOHC Interference
  • 3.0L SOHC 24 Valve Engine Interference
  • 3.2L Interference
  • 3.5L Interference
  • 4.0L Interference
  • this should be what your looking for.
Dec 10, 2015 | Chrysler Cars & Trucks
Transceiver signal interference
The FT-840 uses a die-cast RF power amp with thermally switched fan to ensure full power output (up to 100 watts). The digitally synthesized local signals ensure clean, low-noise transmitter output on all HF amateur band. There might be no AC line interference. it has strong Rf output. any AC line intersect does not affect its radio performance. Check and adjust RF power so to maintain proper output. some times more RF power generated at the output may cause interference. adjust Rf power..Even some unfiltered Noise getting the other end of the end may calso cause interference. Check for any Ripple voltages present at the output. Contact authorised service station for further Rectification. thank you shanth
Dec 23, 2007 | Computers & Internet
My MA-lfqhw-wh worked fine for a while. Now the light and fan don't adjust, and the only way to turn it off is to pull the breaker switch at the at the bottom. I replace it once already. Wo
The switch uses wireless radio to do some things with that model. The problems that you are having could be either interference or the fan and light are using too many amps and burning the unit out.
Oct 30, 2014 | Electrical Supplies
List of interference engines
Hi, I believe the VG series of engines are interference engines, meaning if the valve timing is lost the valves will be damaged! Regards John
Jul 22, 2014 | 2004 Nissan Quest
My remote control ceiling fan and light turn on by themselves when wireless internet is being used in this room
It sounds like there is a radio interference conflict. Both devices are probably using the same band. Check to see if your remote controls can be switched to a different radio frequency. If to, that should solve the issue.
Oct 09, 2013 | Computers & Internet
We have a Hunter ceiling fan with a remote control, that appears to be possessed. It occasionally turns on or off by itself. What could cause this... interference from a neighbors remote?
Hi.
Usually there are jumpers inside remote circuit and on IR sensor, by changing them you will exclude the possibility of IR interference.
IR is a light signal, therefore it is highly unlikely that the problem is coming from your neioghbors, the problem looks more like a defective IR sensor on the fan, that is not a too unusual fault.
I suggest calling Hunter Ceiling at the number listed on the owners manual to see what they think about the problem.
Regards.
Mar 02, 2010 | Hunter Dryers
Remote control ceiling fan randomly turns itself on, never off. I can turn the light off with the remote, but then it usually turns itself back on. This usually goes on for a couple minutes then it quits....
Not necessarily true. Your fan light is controlled from the wall unit using radio, it's not hard wired, in most fans today. There is a promulgation of wireless devices in homes today, along with electronics and appliances that interfere. There are no easy answers here, you have to determine which item is causing the effect. Often times it's a microwave oven. My daughter was making breakfast in the kitchen using the stove, refrigerator, toaster and microwave. All of these appliances have electronics and can provide interference. Worst offender is the microwave oven which generates strong RFI inteference. You can test this by putting a 3' x 3' piece of alumnimum foil between the microwave oven and your fan. Not pretty, but at least you know the problem. Your microwave needs to be a goo 10-15 feet away from a device to minimize interference. Yes, that's not what you wanted to hear. Go back to a wired light.fan. There's most likely nothing wrong with your fan. Try changing the frequency that your fan uses. Probably won't help, buts costs nothing but your time. Good Luck
Sep 13, 2009 | Madison Avenue Dryers
Hunter 93886 fan
You may be drawing to much amperage for the switch to handle both fans. You may be underwired if it is an old house. you can hook wires together without switch in place and see if everything keeps working but don't hook them together with the power on. Also don't run very long as the wires could heat up. Run for about 5 minutes and turn power off and check heating of wires.
Jul 28, 2009 | Hunter 235 Fan
Hunter 27187 Remote Control Logo
538 people viewed this question
Top Hunter Televison & Video Experts
Michael Vanidestine
Michael Vanidestine
Level 1 Expert
Jim Goldsmith
Jim Goldsmith
Henry  Thomas
Henry Thomas
Are you a Hunter Televison and Video Expert? Answer questions, earn points and help others
