Question about Toshiba 50HM66 52" Television
Toshiba 50HM66 dlp
I have a dark shaddow at the top of screen about 6 inches down , ican still see picture behind the shaddow , if you can help i would be very thakfull warren
  • 1 more comment
  • sixjsix Nov 19, 2007
    my toshiba 50HM66 has a shadow at the top of the screen that is about 2" in height and gradually decreases as the shadow goes left. i can still see the picture behind the shadow. any fix advice appreciated.
  • warnick Nov 19, 2007
    sixjsix- i did alot of research and it appeares to be the light genorater, toshiba have a call back on some and if you give your ser# they may replace it free the problem is called digital shaddowing , call toshiba service at 1-800-631-3811 hope it helps warnick
  • vernonw Apr 13, 2008
    i have a rainbow like across the top of screen about 2" down.lamp was replace in 2007 it banged out.nothing but problems with this tv never again will i but a toshiba
The Toshiba web site has a place under support about that problem. It's the light engine and if you fill out the serial # and model # the will qualify you for a new one.
Posted on Jun 03, 2008
I have a vary dark picture except the top 6 inches of the screen. I have replaced the bulb is there a angle adjustment for this
Will probably need the light engine/optic block for this unit; If you can even locate it the cost would be prohibitive on this older unit.
You can buy a new LED or LCD for less.
May 15, 2014 | Hitachi 62VS69 62" HDTV
Vizio VW46L10 TV has a 6 inch dark band across the top of the picture.
Change input device to some other like a DVD player.
Switch off TV, switch off power, remove plug and wait for 48 hours and retry. If problem persists, call in a qualified service technician.
Aug 02, 2012 | Televison & Video
Viewsonic N3240WB-E top 3'' of picture has gone dark
From the description one of the backlights behind the display is failing, and cost would not justify the expence, you are further off replacing the monitor
Jul 09, 2012 | ViewSonic Computers & Internet
When the screen is dark there are lines that run back and forth across the screen which is only noticable when pitcure is dark immage.
the screen bias needs to be turned down-ehind the front cover which is behind the grille there is a small black square about 3 inch square 6 little knobs sticking out 3 say in small letters screen and 3 say focus, don't adjust the focus just the screen for the coresponding color that shows up when picture is dark.best way to do this is darken the room and put it on video input with no signal if lines are white slowly
adjust 1 color after the other counterclockwise untill
lines disappear if only 1 color shows then only adjust the knob with the matching color. this is a very fine adjustment, to much will make your auto focus stop working. check it after you are done
Jun 20, 2010 | Sony KP-51HW40 51" Rear Projection...
I have an lcd television but dark lines have appeared down the screen
if this looks like shaddowing it is the screen. the inverter lamps that make the screen light up are failing
Sep 04, 2009 | Televison & Video
Horizontal white lines across top of TV screen
Hi I had the same problem. Broken white lines across the top of the screen. This is called overscan. You need to go into the Setup menu, other settings. 16:9 overscan needs to be on. Hope this helps.It solved our problem.
Sep 15, 2008 | Panasonic CT-2006S 20" TV
RCA hd50lpw42yx2
If you have the extended warranty, use it immediately. This happened with ours after our 1 year warranty expired and found out it would cost us over $1000 to have it fixed. We've read that RCA used faulty glue that can't withstand the heat inside, causing a mirror to slowly slip over time. Our dark shadow keeps growing and growing.
RCA should have recalled this to fix it for everyone.
Nov 28, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Left side of television just started having a shadowing problem?
I have the same problem and was told by a technician that I need to replace the light engine. Probably around $ 700.00.
Oct 15, 2007 | Samsung HL-R6167W 61" HDTV
Toshiba 50HM66 52" Television Logo
222 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
