Question about MSI WIND U100 Notebook
Pleas help my wireless devise has been turned off and cannot find wich buttons to turn back on please help laptop elonex webbook
  • 126 Answers
There should be a small switch located on either the front or side of the laptop. Usually they have a small icont that looks like a small cellular tower.
Try flipping that switch and see if that works.
Posted on Jul 15, 2009
Can anyone recommend Wat I can do please I've recently acquired from auction a Elonex Webb oil with what seems like linox not windows but it has an administration code is there anyway around it
It's got a 1.6GHz processor - most likely Atom - 512MB RAM, Wi-Fi of course, 3 USB ports and it'll ship with both Windows and Linux. The plan is to sell them through the Carphone Warehouse either separately or for free with home broadband packages. Elonex 10 2 webbook PC at the Carphone Warehouse Tech Digest
Jul 26, 2015 | Cars & Trucks
How do i turn on the wireless on my elonex note pad
there should be a key marked 'Fn' next to the windows key, press and hold that and the F-Key which has an image of an aerial on it.
that should turn on the wifi card.
Apr 30, 2012 | Computers & Internet
Elonex eb500 won't turn on
My guess is that firmware update failed on Win7. Try the same thing on WinXP. More information available at:
http://www1.elonex.com/support/products/ebook/500eb-firmware.shtm
Nov 22, 2011 | Computers & Internet
How can you find my 25 letter digit product key for elonex webbook
If you're trying to find the key for an installed Microsoft product, this program can help you. It can also show keys for many other installed applications as well. But it won't help you if you're looking for a product key to install a program when you don't have, it won't help.
Feb 11, 2011 | Compaq Armada M700 Notebook
Powers up but nothing on screen?
I have come across this problem before.
Remove the battery and the power cord. Shut the webbook lid and turn it over. Underneath you will see a panel with screws, unscrew the panel and remove it. Now, take out the memory module.
Underneath the memory module you will see the PCB (printed circuit board) have a very close look for 2 brass triangles, they face away from each other forming what looks like a split diamond. Get a small flat headed screwdriver and short the 2 triangles (hold the head of the screwdriver over both triangles) and press the power button.
Replace the memory, cover and battery and turn on the webbbook.
Hopefully that should sort the problem out for you but you will have to set the date and time.
If this does not work please post back .
Good luck.
Apr 12, 2010 | ASUS Eee 4G Notebook
Elonex webbook displays anything black as red
You could have a faulty inverter or a CCFL lamp, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Jul 08, 2009 | Computers & Internet
Wont start up
Take it out of the freezer. Try hitting ur F8 key upon startup and try to get to safe mode at least. If that does not work you probably have some hardware related issues keeping it from starting(IE bad RAM,HD,MB ETC). Check to see if it is under warranty since that might be your best bet if it is a hardware malfunction. :(
Otherwise you can swap known good parts to see what works and does not work.
Jun 21, 2009 | Computers & Internet
My Elonex One 7" Laptop will not turn on
Please make sure that you post in the correct section. This is clearly not a licensed Apple Product.
May 17, 2009 | Computers & Internet
Taking the Elonex Webbook off of offline mose permenantly
hi there, this is a Firefox 3 vs network manager fight. We are trying to get the full fix pushed out but you can change the setting by going to about:config then changing toolkit.networkmanager.disable this is documented with pictures on my webbook blog
Aug 23, 2008 | Computers & Internet
Cant connect to wireless router
Make sure the wireless adapter is enabled on the elonex laptop and its properly installed.
Connect wirelessly on the elonex one laptop using the same SSID and security key that you used on your main laptop.
Aug 07, 2008 | Belkin (F5D7230-4) Router (587009)
MSI WIND U100 Notebook Logo
154 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
