Question about Cycling
When I ride my 18 speed bike the peddles ****, it feels like the chan came off, but when I look its still on how do i fix it
    President:
  • 1,138 Answers
If your chain is still on the rear gears and the front gears on the crank and pedals to easily you have to switch gears into a combination that gives you more resistance. If you are unable to do this while riding, have someone hold the rear of the bike off the ground while you turn the crank and change the gear. You will generally want something in the middle of the rear gears and the second largest on the front to start.
Posted on Jul 17, 2009
Why does the Secondary Chain keep comming of?
Any time a chain comes off it means there's slack in it or something's not tight enough. Not looking at your bike, I would have to guess that you need to loosen the bolts on the back wheels and then pull the wheel assemblies back until the chain is tight. This is probably a two person job, one to unbolt and bolt and one to apply tension. That being said, many years ago I remember bikes my friends used had a problem where if they were riding at a good speed and then stopped peddling to coast, then slightly reversed peddling, then started fast peddling again, that they would throw a chain. I think what was happening was they were creating slack in the chain by coasting, slightly reversing their peddling, then starting again. The chains were also slightly gummed up, allowing slack at this time.
Jul 28, 2014 | Schwinn Meridian Adult 26-Inch 3-Wheel...
When riding the peddles slip,it appears that the chain is engaged and that the axle is slipping and make s the peddles spin, not engaged
If this is a coaster brake bike (single speed, no hand brakes) then the problem might be inside the rear wheel hub. If that is the case then you can only fix it by completely dis-assembling the rear wheel hub - or it might be simply that the chain is slipping, which would not happen unless the chain is too loose which would be indicated by the bottom of the chain hanging down too low. However, if this is a multi-speed bike, then it could be that the chain and rear-wheel cogs are worn - which can be fixed by replacing the freewheel and the chain - however, it takes a lot of use or rust and dirt before that level of wear happens.
Aug 07, 2012 | Trek Mystic 16
Basically I'm losing a lot of corner speed, when turning into corners. I shut the throttle off too early and it feels like I'm carrying the bike round the corner. If adjust the throttle mid bend,...
You need to accelerate very gently while you go round the corner. This sounds wrong but even if you hold the throttle in the same position, physics dictates that as you go round the corner you do actually accelerate as you go round a corner at a constant speed (velocity/direction/speed - look it up if your interested!).
So on the approach to any corner, you need to: -
1 Position yourself and the bike for the approaching bend, toward the right hand side of your lane for left hand bends and vice versa.
2 Adjust your speed to one you can quite happily ride around your bend (Slow down by easing off the throttle or appling the brakes)
3 Once at the right speed, (off the brakes) select the right gear for the speed your doing.
4 GENTLY apply some throttle to stop the bike slowing down anymore.
5 Tip the bike into the corner by gently pushing on the left bar for left handers or vice versa keeping the throttle still so that you hold your speed through the corner.
6 As the bend opens up (becomes a straight) gently apply more throttle as you release the pressure on the bar and stop turning.
If you want to keep improving your riding skills, sign up to a advanced riding course. They are for people who enjoy riding and want to be safer and consequently faster.
Good luck with your riding and enjoy!
Jul 28, 2011 | Suzuki GSX 1300 R Hayabusa Motorcycles
How to use thumb shifters on a 21 speed Schwinn Highplains bike
OK, for a beginner in the world of 18 speed bikes, put the chain on the big sprocket up front, it should be about 46 teeth, make sure it is center and doesn't make noise, if it does, adjust it just a hair either way, now, the rear, put the chain on the big sprocket in the rear, make sure the front didn't start making noise, if it did, adjust it again. You are now ready to take off, in low gear, as you start out, it is easy to pedal, soon you will be peddling air, shift into second gear in the rear only, don't touch the front. Just a little push with the thumb will make it shift, now were going faster, easy peddling, shift into 3rd, then 4th, etc, coming to a stop, down shift the back sprocket back into low gear (big sprocket) and be ready to take off again. Soon you will be shifting that thing like a Ferrari! The front sprocket, will be used for moderate terrain, wheelies, and mountain climbing, that will come later, learn how to shift the rear first. As each gear climaxes, hit the shifter, it will get smoother as you go, and keep the chain quiet, no climbing on the next sprocket or falling out of gear. Hope this helps.
May 03, 2010 | Cycling
When peddling bike seems to try to shift gears
There may be some chain links that do not move freely. turn the pedal slowly backwards and check for siezed links, as it goes through the deraileur.
A worn chain can do this as well, unfortunately you usually have to change the chain and sprocket cluster as a pair. If you just put a new chain on a similar problem can occur.
Apr 22, 2010 | Schwinn Mesa Gs Mountain Bike
Making the bike from a 18-speed to a 1 speed bike
single speed bikes have a single ratchet or fixed sprocket with no offset of the spokes, so you would probable need another rear wheel.
Another derailleur is probably simpler, try ebay
Apr 04, 2010 | Huffy Alpine Men's 26-Inch Mountain Bike
I just received a sports bike for ecercise and model number is EDG 329u. Every time I try to ajust the peddal speed it makes a weird noise and It will not move the speed it stays the same speed. It is very...
You have the bike in a high gear. Assuming it is a deraleur type, look to see which sprocket the chain is riding on. If it is one of the smaller sprockets (on the rear wheel, not the pedals), put it onto a bigger sprocket by changing gears to one of the lower gears. As a side note, professional riders change gears many, many times during one outing. They keep the pedal speed at a comfortable speed no matter how fast or slow the bike is going. Anyhow, to review, put the bike into a low gear, particularly when starting out from a stop. If the bike makes a wierd clicking sound, or the gears don't change as they should, it is possible that your indexing in your gears needs some adjusting, or there is some other problem. Any bike shop will take care of you, as these are very easy to fix.
Nov 25, 2009 | Cycling
My new 26 18 spd Alpine Bike gears are not
Turn the bike over so its sitting on the seat & bars..
There are a few small setting srews on the derailleur..
These are for adjuting.. Adjust while turning the peddles & shifting.. You should be able to smooth it out
Jul 08, 2009 | Huffy Alpine 26 Women's All Terrain...
LOOKING FOR RPM DIAGRAM AND SHFTING SPEEDS FOR YAMAHA VSTAR650
I want to know- if there is a big difference between a 2001 v-star classic and , say a 2005 or 06 v star classic. Are the newer ones lighter, or advanced in some way, enough to make a difference?
Mar 02, 2009 | 2001 Yamaha V Star 1100 Classic
Cycling Logo
110 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
