Question about Pool & Spa
Layz spa pump
The heater wont work on my layz spa everything else works but wont heat up
  • 2 more comments
  • the_titch May 25, 2011
    i have tried this fix and it does not seem to be working for us. We followed the instructions and the spa seems to heat up ok for a while but it is cutting off (ie red to green light) when the spa is a lot colder than 40C - maybe it is a thermostat problem???
    any help would be v greatful.
    thanks
  • MS MICHELE WARD
    MS MICHELE WARD May 19, 2014
    I tried this but could not locate the right items and now my spa is leaking, help!
  • MS MICHELE WARD
    MS MICHELE WARD May 21, 2014
    water is leaking from the vent at the bottom since i opened the unit, what can i do to fix this
  • Mary Fritze
    Mary Fritze Jun 16, 2017
    Our pump is reading E02 I check a the filers they are fine not reading the water flow keeps clicking off ? Next step I'll find censor
  • 3 Answers
Same problem I had so I seperated the globe by taking out the 5 screws around the middle then removed the nut from the hole the filter sits on its a strange fitting and must have a special key but I improvised by tapping it anticlockwise using a screwdriver and rubber mallet, once open identify the heater unit (it has a single wire going into it and is fastened to a length of metal pipe) and remove it by loosening the clamps at either side and pull the heater free, once free dismantle the plastic casing on the top of the heater inside you will see the live, neutral and earth wires, you can see the live (brown) wire goes to the water flow switch then the temp switch then the heater all I did was bypass the water flow switch by disconnecting the short wire from it going to the heat sensor and replacing it with the brown wire coming from the mains and it works fine now
Posted on Aug 02, 2009
  • 3 more comments
  • Basky1966 Apr 12, 2011
    Fantastic matey thanks for the write up saved me some money and my tub gets another years use, PS long nose pliers to get the inside nut off ;-) Thanks again.
  • Tony Taylor Nov 01, 2011
    Ha, it worked! Good on ya mate, have to buy ya a beer sometime. Thanks :)))
  • Alan welburn Jul 05, 2015
    Hi does this cause the hot tub to over heat ?? Or will it still click off at 40 degrees
  • Jenny Wright Aug 27, 2015
    is this for the 54075 pump
    need pictures to make sure i do it correctly
  • 3 Answers
HI
this worked for me too! getting centre nut off was easy using thin pliers - have taken some photos along the way - i'll see if I can get them up here
Posted on Aug 02, 2010
  • 2 more comments
  • jepstock Aug 02, 2010
    The 1st picture is of insides after top has come off - you need to remove the white plastic attachments. They are connected with two brackets which split in half when you remove the screws - mine also had some infexible sealant around which I had to cut off - and then used new silcone when replacing.
    The second picture is the top of the air blower unit - I had to remove this to get at one of the plastic brackets.
    Picture 4 shows the brackets half off - don't drop the little screws! You'll also find a rubber washer under each of the tubes - these need to be reseated correctly.
    Next picture - heater element withdrawn form tube - it's like akettel element - next job remove the plastic cover. Sorry this shot is a bit blurry
    - you can see the brown live power wire coming in from the left going to the flow switch far right - there's a short brown lead that takes the power to the element in the centre.
    Next shot shows how wires look afterwards - note no wires on flow switch as small wire has been discarded, and the brown wire from the mains goes to the terminal on the heater element that the short brown wire used to attach to.
    I took off the plastic cover underneath the element wiring to have a look at the flow switch - it works by water pressure pushing a rubber piston inside the switch to turn on the power - mine was fouled with deposits - I priced one up - you can get them for around £37.
    the above fix works, but as precaution I don't run the heater when anyone is the pool in case of leaks - good luck!
  • nigburke May 05, 2011
    Brilliant! Many thanks for your instructions. My family want to use the Spa but it looked like it was a no-go until I found this thread. Many thanks again!
  • alanjdmillar Jun 07, 2011
    hi there i have two heaters one the plastic casing is split due to frost damage but i have another good plastic casing which i can transfer all the workings to. how do i split the casing to get everything out and do the transfer...
    is this to a 54075 or 54090 pump
    New Friend:
We had our lay z spa just over 12 months and then the heater stoped working. I found a very good repair guide on ebay and was able to fix mine. Very happy now. Seems like a lot of people have issues.
Posted on Jun 14, 2011
When i turn the heater on it blows the fuse can you help please
dave
Posted on Sep 27, 2011
This solution works great... took me 30 minutes to get the unit apart and 1 minute to bypass the thermo... heat is coming out my pump now... sensational advice just saved me a $300 AUD replacement pump
Posted on Apr 24, 2010
  • Anonymous Feb 06, 2016
    Ya, I had E06 whenever I turned on the heater. pulled the cover, disconnected the sensor on the outside of the heater, put it all back together, and bingo, we have hot tub again! This works! (may cause tub to burst into flames, use at your own risk)
In reponse to gallydavid, I had the same problem, what everyone says is pretty much correct. It is probably a bit dangerous to bypass the pressure switch inside the heating unit but it is easily done. (on your head be it!) Once you have dismantled the pump/blower unit and found the heating tube, remove the small screws that cover the wires going into the element. Look at the brown wire (live) it goes first to the pressure switch. disconnect both wires from the pressure switch. Next disconnect the brown wire that went from the high heat cut out (a small disc shaped object attached to the element)to the pressure switch. this wire will be about 50-75mm's long. Discard that wire. Now connect the brown wire that was on the pressure switch that goes to the control unit to the high heat cut out. this means you have removed the pressure switch from the circuit. put everything back together.
NOW MAKE SURE YOUR SPA IS FULL OF WATER AND WATER HAS FILLED THE FILTER VESSEL, i.e you have bled the filter, then turn on the heating.
It should now work.
Posted on Jul 11, 2010
  • 3 Answers
Hey, i am not exactly an electrician, i think your solution is great and will work, but would someone be able to give me an idiots guide to rewiring it please?
Posted on Jun 10, 2010
  • manilvajl Sep 19, 2010
    Just fixed mine, the pressure switch just unscrews, take it out use a paper clip to remove the dirt etc. from the hole push on the diaphragm until the micro switch clicks blow into the switch to check it works, you will hear the switch clicking, screw it back in and connect wires.
  • Arawak Caterer
    Arawak Caterer Jul 12, 2015
    any pictures please anyone
Thank you for the great info . It's great having my hot tub back. I did take a shortcut. Instead of breaking the clamps on the heating element and needing to reseal them, I removed 2 screws from the base of the heating tube where it meets the main body as well as 4 screws from the base of the pump where they all fasten to the main body. This allowed me to lift the unit enough to get the cover off of the flow pressure switch and do your modifications without any silicone or breaking any seals. Thanks again everyone
Posted on Aug 29, 2010
Tried this but now when i press the circulation button all i get is a clicking on pressing it on and and green light but nothing ! what have i done wrong :(
Posted on Mar 27, 2011
  • 3 more comments
  • JonMint Mar 27, 2011
    done the above but now when i press the flow i get nothing but a clicking from the black housin with 4 screws that is fixed to the big white box :( what have i done wrong ?
    I have done the advise as described here. Seems to heat up but is still cutting off when the unit decides it is 40 but it is still too cold. thought this solution would sort it out but no luck. is there any way i can remove the thermostat? thank you
  • JonMint May 25, 2011
    m8 make sure you have no kinks in the tubes (A) (B) mine heated up went almost straight to 40 but still only luke warm ! check the inlet an outlet tubes :)
  • mornington06
    mornington06 Aug 31, 2012
    ive also done this conversion and now the filtering circuit doesnt work and when i set the temperature the previous night to 24 it still said 24 the next day disconnecting that pressure switch must do something to stop the circulation circuit to kick in has there is no pump noise when the filter circuit is activated.
  • Delroy rudd Jul 06, 2018
    E04 fix help please its heating tub but keeps coming up e04 apparently its the water sensor i have replacement but it has 2 red and blue which 1 do i need to change? Please help
Yes great advice it took ten mins to fix all you have to do is make sure you change filter reg and bleed once you have changed your filter u should never av a problem and the easy way of removing the nut from the middle use long nose pliers really easy once again thanks
Posted on Aug 01, 2010
THANK YOU SHANDYT. The inspired solution proposed by Shandyt has worked for me and I thank him for it. It saves anguish and £200 GBP. For those who undertake the job, be careful to learn how the two interior plastic pipe seals fit and screw shut again as they are a bit tricky and I found it necessary to take them off to give access to the fittings. Otherwise its a doddle! Clearly the flow switch is the weak point on these spa heater/pumps and Bestway must surely know this, so one suspects there may be built-in obsolescence in an otherwise solid product. Grateful Fred
Posted on Jul 06, 2010
    New Friend:
I have a Monaco lazy spa and the set up is slightly different. The pump and filter is working fine but I have no heat being produced can someone tell which part I need to bypass as it seems different to what is written above. Cheers in advance.
Posted on Jun 29, 2017
    New Friend:
My Miami is heating up to 26c, when I reset the water comes through warmer and then quickly resumes to cold again! Does anyone have any ideas?
Posted on May 11, 2017
    New Friend:
I get an e06 code ever time i put the heater on. I change filters regularly. Flow seems good. I've had spa for 8 months. The person i talked to at the layz site says warranties only good in the uk... really? Wth! Can someone help?
Posted on Oct 20, 2016
Tried to fix the heater on my lazy spa but still not working. Wen I turn it on it says err02 but there is water flow. The filter is saying the same error message. Only thing working is the bubbles. PLEASE HELP
Posted on Sep 22, 2014
My pump when swiched on at the power socket only shows the ambient tempreture and no buttons work on the control panel. I have opened pump and unplugged each module in turn to see if this would identify the problem but still nothing it does show a different error message on the display each time I disconnected the different modules so I think the display works but buttons are doing nothing...can anyone help????
Posted on Jul 03, 2014
I have tried all of the solutions on this page but my hot tub still won't heat up more than 28 Please help
Posted on Apr 24, 2014
I have just spent four hours on my unit. In my unit though, the pressure swith wires are white, one with red markings on them. The temp sensors have black wires to them. These all run into a motherboard separatly. I straight out cut the pressure sensors wires, no luck. I joined the cut wires together, no luck. Put it all back together the way it was built and no luck. Any guide on what wires to cut and join on these newer units with the different coloured wiring? Tony
Posted on Oct 06, 2012
Lay z spa pump control panel condensation / steamed up.
The buttons on my spa had stopped working although it still powered up ok. There was water showing in the display.
I opened up the "egg" to find I couldn't get at the back of the panel as it is sealed.
I used a hair dryer to heat up the panel from inside the unit (blowing air from a distance into the hole where the wire goes into the panel). I alternated this with heating from the front of the panel to clear the steam. Eventually the steam cleared and stopped forming on the screen.
I put the unit back together and it worked first time.
Be careful not to over heat the unit.
Posted on May 28, 2012
Hi ive done the modification on the spa pump where you bypass the flow switch the heater did work as i briefly tried it for a few seconds and felt it heat up, the more worrying is that when i put the heater on the temperature never rises and also the filter doesnt kick in and also when i press the filter keypad it doesnt work it did before i bypassed the flow switch any ideas people thanx.
Posted on Aug 29, 2012
The control panel is not working, pump coming on and making usual noise but none of the buttons are working , can anyone help pls
Posted on Aug 03, 2011
  • weatherman2 Aug 17, 2011
    I had a similar problem - condensation gets into the panel and corrodes all the switch contacts - need to replace the switch on the panel - fixed mine OK
Worked for me too! I am going to try and source a new switch though and replace it when it comes. Once you have done this you must remember to never switch the heat on without water.
Posted on Jun 17, 2010
  • BockaBocka Nov 16, 2010
    I currently own a Lay-Z-Spa Hot tub after six months the heater no longer heated although the red light stayed on , after loosing my receipt and paying cash , i had no way of getting a free replacement .
    So i decided to isolate the Supply and take the pump unit apart to find out what was wrong , after stripping down the heater element unit i found through testing the element with a multimeter ( I advise a qualified electrician for all of this work). found that the attached thermostat had not reset and burnt out the element.
    After a long
  • Chris Abram
    Chris Abram Aug 24, 2017
    Anyone have any pics they can send
My balboa spa is not heating everything seems to be working fine what could be wrong
check fuses for heater element if ok see if calling for heat if so check element if not calling for heat bad temp sensor replace
Sep 08, 2015 | Balboa Instruments Pool & Spa
My leisure bay spa will not heat up and the heat light will not come on, everything is working great but just won't heat up.
Maybe fused or breaker needs check.
Thermostat could need clean or replacement.
Invite a spa technician to next party, this should fix it
Aug 19, 2014 | Pool & Spa
Heater not working
if you set for a temp warmer than water is now if it wont heat up see if menu shows its calling for heat if not temp sensor if so sounds like bad heating element also is recirculation pump runnig and are your filters clean?
Apr 03, 2014 | Pool & Spa
Layz spa pump 58113 is very noisy can I replace the bearings or get a new part
If you are going to pay someone to replace the bearings, you may aswell pay the money to replace the motor and do a seal change
Mar 11, 2014 | Pool & Spa
PLEASE HELP.....cant not get Batizime pool to heat up.
something is wrong with the voltage it should be 240 when you test the heater terminals, i think the heater relay isnt making a good contact. but i would check for 240 at the main panel and chase the wiring to find the voltage drop.
Apr 02, 2010 | Hayward Comfort Zone Electric Spa Heater...
I want to heat the pool from the spa. I have the spa and spa heat on but the spillover wont come on when I have the spa on. When I turn the spa off the heat goes off. What do I do
When your system is put into Spa mode the system draws water from the spa only to the heater to keep the spa at temp, this is why the overflow doesn't work and why you can not heat the pool in spa mode. If you could heat the pool this way it would take a very long time, since the spa is smaller then the pool. You can heat the pool and spa at the same time in pool mode. Water is pulled from the pool, heated and goes back into the pool and spa.
Mar 27, 2010 | Jandy AQUALINK RS TELELINK KIT
Layz spa keeps going off says on readout 6cf.heater is fine pump everything else is ok cheers kevin
You have a problem with the RCD (residual-current device). This is the part of the plug that you have to push reset on before a current will flow. You can repair this by buying a new RCD plug and rewiring it or if you already have an RCD socket adaptor for another appliance, you can just cut of the plug on the pod/ pump and rewire it into a rubber plug and then plug this into the RCD adaptor and the lay z spa should no longer cut out. The RCD is important because you do not want to blow the unit inside.
I hope this helps, If you need more assistance, please ask.
Sep 30, 2009 | Pool & Spa
Spa wont heat
Check the pump make sure that it is getting power. If there is power to the pump and nothing is working then pump is bad. Also this could be your computer board is bad, a inline fuse. or the Jandy is bad
May 20, 2009 | Jandy Aqualink Rs4 One Touch Control...
Pool & Spa Logo
29,975 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
