Question about Oreck XL2200 Bagged Upright Vacuum
Kenmore progressive 300 smells like it is burning
    Problem Solver:
  • 6 Answers
These vacs use Ametek motors which are practically designed to fail. Frequent complaints are a burning smell and louder than usual noise in the canister. The problem is the poor quality
bearings Ametek uses in the motors in the units. They have low-end ball bearings with a nylon "crown" that breaks up and gums up the bearing. Further the fan end of the motor is a bear to get to because of poor (intentionally?) design. With great difficulty I WAS able to remove the fan and housing and inspect the bearing. Since finding a replacement is too much trouble or impossible, I cleaned up the ball bearings and switched the bearings on the two ends moving the remaining good one from the brush end to the fan end where I assume the load is. I packed the damaged one with grease.
Now the motor runs smoothly. I doubt however this jury rig will last very long. It is very irritating to toss a $120 motor because of a failed bearing. Kenmore and Ametek should be embarassed but I'm sure they are NOT!
Posted on Nov 07, 2009
  • 97 Answers
Change the belt, but if it smells like an electrical burn than the motor is gone.
Posted on Jul 20, 2009
The motor in the Kenmore canister started smelling like wire burning and then made terrible noise. I ordered the exact replacement motor and swapped them. Installed the same way the original came out, ran...
Actually there not supposed to burn up. I have read some reviews on that model Kenmore and it seems it is plagued by electrical problems.
I would definitely contact Sears customer service.
Sorry I couldn't be of more help.
Handie Andie
Mar 30, 2011 | Kenmore 25512/ 25513 Progressive Canister...
I have the model 36932 with direct drive. lately, there is the distinct smell of rubber when starting up and running. There is no belt on this machine. What could be causing the smell? roger
Check that the rotating brush is not seized and the belt is not slipping on it or the motor drive shaft. The belt will burn through if the machine is left to run any longer.
Feb 02, 2011 | Kenmore 31913 Progressive Direct Drive...
Burning smell. i think the belt is broken. how do I fix it?
Turn the power head over and you will see (2) screws. Remove the screws and the top cover will come off and you can get to the belt. Here is the belt you need:
Kenmore 23812 Belt
Feb 06, 2010 | Kenmore 23812 Progressive PowerMate Bagged...
Progressive drive bagless and beltless sweeper (purple) that has a burning smell when running, what could it be?
most likely the brushroll motor which is located inside the brushroll. This machine is one of the worst designs produced by kenmore, usually the brushroll motor only lasts 2 to 3 yrs.
Jan 06, 2010 | Vacuums
The motor makes a weird sound and starts to heat and smell like something is burning
If the motor sounds scratchy and is making a burning smell, or sparking you will need to replace the motor or the entire vac. Carbon brushes will rarely fix this as it is a high RPM motor
Sep 04, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Motor slows down and makes burning smell
If the noise is coming from the canister motor, you probably have bad motor bushings. I had the same problem, replaced the motor and all was fine - only for one year. The problem is back and is due to the fact the motor is very high speed (to get good suction) and should be made with bearings, not bushings. I will not be repairing a second time as a $70 motor annually is a bit pricey, and yes it will get VERY hot. I will buy a new vacuum - not another Kenmore.
May 25, 2009 | Kenmore 23612 Progressive PowerMate Bagged...
Upright Vacuum Cleaner Lost Suction
If you had the dryer sheet under the intake filter for any length of time you risk burning out the motor . If
it smells like burning hair and plastic then the motor is toast. Also check the hose and dust passage, but I fear that it is the motor.
Sorry...
Sep 24, 2008 | Kenmore 31913 Progressive Direct Drive...
Burning smell from motor...what needs replaced?
Without the complete model number, I don't know for sure what componets you have, most likely is the motor. You will have to take the motor cover off and check it out. You can go to sears.com, click on parts, enter your complete model number, scroll down to cannister and it will bring up a parts list where you can order parts, also a diagram of the cannister.
Jul 05, 2008 | Kenmore 25812 / 25813 Progressive Bagged...
Oreck XL2200 Bagged Upright Vacuum Logo
649 people viewed this question
Top Oreck Vacuums Experts
xalint1
xalint1
Kory Ronning
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
