Question about Water Heaters
No hot water but heating ok..no fault displayed ???
  • 154 Answers
Problem with tempering valve or if old,coil may be plugged
Posted on Aug 01, 2009
Ls80t hot water goes hot cold hot cold heating is ok
http://waterheatertimer.org/How-to-fix-water-heater.html
What kind of water heater do you have? Boiler, indirect?
What brand and model?
Or is this a HVAC unit?
Gene
Aug 17, 2014 | Water Heaters
What is local set point
fault code 36 water runs hot for about 5minuets then registers this fault code and hot water goes off. water pressure seems ok and gas supply is alright.
Feb 02, 2014 | Honeywell Water Heaters
Ge geospring hot water heater fault code F1
Copy following links before calling GE with model and serial number for local trained service technician.
http://waterheatertimer.org/Review-GE-Heat-Pump-water-heater.html#error
http://waterheatertimer.org/GE-heat-pump-manuals-by-date.html
Don't buy expensive water heaters that do not have service manuals available.
Gene
h
Nov 18, 2013 | Geospring Hybrid 50 Gallon Heat Pump...
I have an ariston 20/24 mffi combi pressure rises when switched to central heating but pressure ok when asking for hot water ? expansion vessel ?
over heat limit stat on central heating circuit ? if hot water is ok and hot to temp when run for 5 minutes the expansion vessel is doing its job.remember hot water is the maximum demand for any boiler ,,heating is secondry?once you establish hot water at maximum rate then the only real problem is on you demand for heating??
Dec 10, 2012 | Water Heaters
My Rinnai is set to 50 but when I run the water no hot water comes. Instead after about 10 seconds the 50 changes to a flashing 61. As soon as I turn the water flow off it reverts to 50.
This is a fault code telling you there is a problem. In this case 61 is a fault on the fan. It's not spinning at the speed expected for the electrical power it's drawing; the heater monitors this. Checks you can do are make sure the flue is not blocked. If Ok you need to get a serviceman to check the fan and heat exchanger for blockages.
Sep 22, 2010 | Rinnai Digital Remote Water Heater Control...
Heatslave diverter valve
clicking rads are due to pipe expansion when getting hot.
If the hot water [secondary circuit] gets hot and the boiler stays on [does not keep going on and off] even with a constant low water flow then the diverter should be ok.
there is a valve to prevent the primary circuit [central heating] [ CH] from sending water to the rads. this or its control may be at fault.
both the
Both the CH pipes to & from the boiler should have manual valves to turn off. do this then try the hot tap-full on. If the boiler goes into overheat mode and the overheat stat kicks in to turn the boiler off -- then :-
Check also the heat exchanger, it may be furred up especially if you are in a hard water area. It means taking it off and manually checking [pour water through] If you're lucky it will be just muck to be forced out with hose pipe pressure, if not a new one
Sep 06, 2009 | Water Heaters
No central heating back boiler
back boiler run from a gas fire? check the instructions to operate the gas heat to the back boiler not just the fire
I presume that this a fully pumped system - air lock doubtful There maybe on/off valves on the pipes to and from the back boiler [situate close to cylinder] make sure they are on - anticlockwise turn
or there could be a blockage in the outlet from header tank usually in the loft. or If there is no water in it maybe the mains cold feed it is off.
Note if no water in it DO NOT USE the back boiler
May 03, 2009 | Bosch & Power Vent Water Heater
Water Heaters Logo
139 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
