Question about Garmin n?vi 775T Car GPS Receiver
How to charge Garmin 755t
My Garmin 755t does not turn on, only when it is plugged into my car. Battery is dead. Does it not charge when plugged into car? I only bought this back in March 2009. Can I not charge battery with usb plugged into laptop or usb charger? Thanks
I had the same problem with mine & it was only 6 months old. The battery needs to be replaced. This is a good site that shows you how to change the battery & you can order the new battery from them as well. http://www.newpower99.com/
Posted on Apr 24, 2010
I can't adjust bluetooth,there is no "bluetooth" icon.
The Nuvi 755T does not have bluetooth capability. See this link to see the specifications of the 755T from the Garmin website:
https://buy.garmin.com/en-US/US/prod14933.html
Bluetooth wireless technology No
You would have to have a Nuvi 765T to have bluetooth
https://buy.garmin.com/en-US/US/prod14926.html
Bluetooth wireless technology Yes (with A2DP technology)
Aug 13, 2013 | Garmin nuvi 755T Car GPS Receiver
Garmin Nuvi 755t Stuck in power up cycle
You can do two things.
First, plug the GPS in overnight in a regular USB charger. If the battery charges up, then the problem is with your Garmin vehicle cable.
If it does not charge up, you can buy a battery replacement kit for it: https://www.amazon.com/Garmin-Nuvi-755-Replacement-Installation/dp/B003VFSR4M
Mar 05, 2017 | Garmin nuvi 755T Car GPS Receiver
I have a Garmin Nuvi 755T. I noticed that the unit was not charging via the car charger. I checked the charger and noticed that the green light was on. I also pulled the fuse and checked it and it is...
found female jack on the 755 mount where the car charger pluges into the GPS was not securely soldered onto ckt bd so after multiple times pulg in or unpluging the unit or just stressing the connection the fine wire conncetions (about 12) tend to break forcing the unit to operate on battery mode untill battery is discharged. you an purchase a replacement GPCCradle Holder compatible with Garmin Nuvi on Amazon GPS Cradle Holder Compatible with Garmin Nuvi for about $20
Aug 26, 2011 | Garmin nuvi 755T Car GPS Receiver
Car power supply for Garmin nuvi 755t does not work. Not sure if its the Wire, mount Adapter or other.
I assume you have checked the cigarette lighter to be sure it's working.
The most likely problem is the fuse in the power cord/charger. The plug which goes into the cigarette lighter socket has a ring at the end of it. Unscrew the ring, taking care not to lose any small parts, and it comes apart. Replace the fuse and it should be ok.
Dec 25, 2010 | Garmin nuvi 755T Car GPS Receiver
Car charger not charging internal battery ..gtm 20 cord ...nuvi 755
There is a fuse in the car charger adapter silver tip.... Unscrew it CAEFULLY its spring loaded and check fuse
Nov 06, 2010 | Garmin nuvi 755T Car GPS Receiver
Garmin Nuvi 755T touch pad gone askew
the touch screen is defective, i suggest that you replace the GPS, a new touch screen installed is about $250
Apr 07, 2010 | Garmin nuvi 755T Car GPS Receiver
755T runs slow have their been any noted problems that I don't know about
make sure it has a good charge on it...if the battery is very low, it will slow down or prevent the satellites form locking on
plug it in to the computer for a few hours, then take it outside in clear view of the sky and let it link up to the satillites.
to check of your unit needs any updates..go HERE and download the garmin web updater and after you install it, hook up your garmin to your computer via the usb cable provided with your unit.
if you need further help, just let me know
bill
Dec 11, 2009 | Garmin nuvi 755T Car GPS Receiver
Power cord doen not seem to recharge Garmin Nuve 680 in car.
to register my Garmin Nuvi. I want to get it registered, I tried before I'm not sure how far I got if it is registered or not
Jan 15, 2009 | Garmin Nuvi 680 GPS Receiver
Itunes to garmin 755t
You will need to convert your iTunes library to MP3 format, and then transfer to the Nuvi 755t in order to play them.
Dec 30, 2008 | Garmin Nuvi 660 GPS Receiver
Internal battery won't charge
Common issue. Steps to troubleshoot/solve:
1. Pull off face, press reset tab.
2. If unit wont turn on or if turns off immediately, connect to home computer using mini usb on side of gps (any usb cord that fits will do). This will charge the internal gps battery, which is discharged.
3. You will not be able to see the gps charge indicator while the usb cord is plugged into the unit. To check charge level, disconnect it, turn it on, and note the large "battery" icon.
4 Do you have a dead internal battery? If the gps holds a charge from your computer usb port, you don't.
5. If you have a dead battery, Google DIY replacement. With some soldering it can done for $15 total.
6. If you don't have a dead battery, the issue is charging from the cigarette lighter socket. Your car socket may have blown a fuse (check car manual). Your charger unit may have blown a fuse (unscrew the tip, check fuse inside). Also, some car sockets don't work when the ignition is off. Test yours.
7. There is a good chance the connection of the charger wire to the gps cradle is the problem. Fiddle with that. Replacement cradles are available for the c340 at about $25.
8. If your unit is not charging from the cradle/socket, buy a 12v usb cord. Plug into socket and into usb port of the gps. This is a workaround or alternative to buying a new cradle.
9. IMPORTANT: observe the "battery" icon while driving, esp. if you have doubts about charging. Basically, if you can see the icon, you're not connected to an outside (car or computer) power source. That is, if you can see the battery-charge indication, it means your battery is currently discharging and unless you get another power source to work it will be dead in a few hours.
Aug 27, 2007 | Garmin StreetPilot c340 GPS Receiver
Garmin n?vi 775T Car GPS Receiver Logo
701 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
