4.2L Engine
To install:
WARNING
During engine repair procedures, cleanliness is extremely important. Any foreign material, including any material created while cleaning gasket surfaces, that enters the oil passages, coolant passages or the oil pan can cause engine failure.
WARNING
Do not use metal scrapers, wire brushes, power abrasive discs or other abrasive means to clean the sealing surfaces. These tools cause scratches and gouges which make leak paths. Use silicone gasket remover and a plastic scraping tool to remove all traces of old sealant. Follow the directions on the packaging.
NOTE
If the oil pan is not secured within 4 minutes, the sealant must be removed and the sealing areas cleaned. To clean the sealing area, use silicone gasket remover and metal surface prep. Follow the directions on the packaging. Failure to follow this procedure can cause future oil leakage.
For more oil and oil pump details check
out the direct links below: ---
How to Replace Oil Pan on car?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-oil-pan-on-audi-a4-and.html
How to Replace an Oil Pan Gasket?
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-oil-pan-gasket.html
HOW TO REPLACE AN OIL PUMP
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-oil-pump.html
HOW TO CHANGE ENGINE OIL AND FILTER
http://schematicsdiagram.blogspot.com/2011/07/how-to-change-engine-oil-and-filter.html
HOW TO REPLACE AN OIL PRESSURE SWITCH (SENSOR)
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-oil-pressure-switch.html
How to Check Differential Oil Leaks and Replace Oil
http://schematicsdiagram.blogspot.com/2011/07/how-to-check-differential-oil-leaks-and.html
HOW TO PERFORM A BASIC ENGINE TUNE UP-OIL CHANGE
http://schematicsdiagram.blogspot.com/2011/08/how-to-perform-basic-engine-tune-up-oil.html
Oil pan Gasket on car?
http://howtobyme.blogspot.com/2011/11/oil-pan-gasket-on-1998-toyota-tercel.html
Oil pressure for car?
http://schematicsdiagram.blogspot.com/2011/12/oil-pressure-for-2001-gmc-jimmy-v6.html
How to replace Oil
Pan on car?
http://schematicsdiagram.blogspot.com/2011/12/how-to-replace-oil-pan-on-2008-honda.html
How to replace Oil
Pressure Sensor on car?
http://schematicsdiagram.blogspot.com/2011/12/how-to-replace-oil-pressure-sensor-on.html
How to replace Oil
Pump on car?
http://howtobyme.blogspot.com/2011/12/how-to-replace-oil-pump-on-2008-honda.html
Car oil leak?
http://schematicsdiagram.blogspot.com/2011/12/car-oil-leak.html
Car oil leaks from
valve cover gasket?
http://schematicsdiagram.blogspot.com/2011/12/car-oil-leaks-from-valve-cover-gasket.html
Oil light blinks on
dashboard?
http://schematicsdiagram.blogspot.com/2011/12/oil-light-blinks-on-dashboard.html
Oil pressure issues on car?
http://repairhelpcenter.blogspot.com/2012/01/oil-pressure-issuers-on-toyota-tundra.html
Oil leaks from air filter on ford?
http://technoanswers.blogspot.com/2012/01/oil-leaks-from-air-filter-on-ford.html
Wire running from oil pan to
alternator?
http://technoanswers.blogspot.in/2012/02/wire-running-from-oil-pan-to-alternator.html
Why car leaks oil
from oil filter?
http://schematicsdiagram.blogspot.in/2012/02/toyota-camry-leaks-oil-from-oil-filter.html
Why engine is
consuming lots of oil?
http://schematicsdiagram.blogspot.in/2012/02/2008-scion-xb-24l-engine-is-consuming.html
Maint REQD message
on car dash?
http://schematicsdiagram.blogspot.in/2012/02/maint-reqd-message-on-2008-lexus-rx350.html
Remove Sump oil pan?
http://repairhelpcenter.blogspot.in/2012/03/remove-volkswagen-sump-oil-pan.html
Sump not coming OFF?
http://repairhelpcenter.blogspot.in/2012/03/sump-not-coming-off.html
How to remove the sump on car?
http://repairhelpcenter.blogspot.in/2012/03/how-to-remove-sump-on-vw-beetle.html
Car oil sump removal diagram?
http://repairhelpcenter.blogspot.in/2012/03/volkswagen-beetle-oil-sump-removal.html
This will help.
Thanks.
Fig. Oil pan bolt torque sequence-3.0L engine
Hope this helps (remember to rate and comment this answer).
