Question about Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater - LP Gas
Power reset - Rinnai 1004
Is there any power reset capabilities for my Rinnai 1004 (LP gas) following a power failure ?
And if not, can I use a computer-style UPS as a backup?
Thanks
  • pgetch Nov 03, 2008
    1004F - 1 year old - run 6 months fall, winter , spring usually at low temp setting. Flawless operation to this point
    recent power failure - unit not getting power once service to bld'g was restored
    tried a couple of sequences - 1. close gas at unit, unplug, immed. plug in, open gas, turn on. This did not work. 2. Unplugged again and let sit 3-4 hrs., check fuse on circuit board ok, reconnected wire at moiter light, plug in - it started.
    2 days later > no apparrant power failure but found unit again w/out power.
    unplugged > wait > plug in > start.
    What is the tiny reset button upper right of circuit board - reset? and why
    unit not getting power 2 days after the initial power outage for no apparant reason?
  • 1,420 Answers
Actually the Rinnai 1004 has an E2prom chip in it that should hold your last setting. If there is a power outage longer than 12 hours, you may have to reset it. A UPS may not supply enough power to keep the unit running. I have seen a battery with inverter setup but very costly. Try and unplug you heater for a few hours and see if the settings stayed. Extend the durration until you find the point of no return. Check all the error codes stored in the unit by holding down on the Economy button as well as the up and down arrows all at the same time. Because you will need both hands to do this, get a friend to write them down as they are displayed.
Posted on Nov 19, 2007
  • 625 Answers
The rinnai is like a monitor. just unplug it, wait five min and plug it back in. then radjust your temp set point and it should pick back up. when there is a power outage the led-s flash 88:88
What does the code 12 flashing mean
Flame failure. The stove started and ran for a while then quit. Out of gas, power failure??? Try to restart. IF you get an 11 code then you may be out of gas.
Keep us posted.
Tom
Oct 22, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Heat shuts off, red power light blinking and number 12 blinking on the display screen.
You may have had a power failure. The situation could be as simple as turning the stove off and on again. The 12 code means flame failure. Gas heater are nothing to mess around with if you don't understand them completely. Don't remove anything from the unit unless you are very sure what you're doing. A call to Rinnai is in order if the code keeps coming on. Good luck,
Tom
Oct 12, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Rinnai 1004 F Error Code 11
Code 11 is that the unit is trying to light but does not sense a flame after 5 seconds. Usually means you have run out of gas if you are bottled gas. Check your bottles are turned on if you are on LPG, you might need to change over manually. Have you anything else on gas?
Jul 01, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Brand new and just hooked up 1004 when run for a few minutes begins to have a squeaking noise.
Remove the two screws on the top right and left sides of the heater. Unplug the wires on the top right front light. Start the heater and listen where the squeek is coming from. Contact your installer for a warranty repair and give them the information where the squeek is coming from.
Nov 19, 2009 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
How to test a used Rinnai 1004 furnace?
The fitting on the back of the unit is 1/2" MPT. Wouldn't suggest messing with it if you are not familiar with propane or natural gas. Make sure the unit is set up for LP if you are going to use a portable supply tank. These units are very reliable. Check all fittings with a diluted soap and water solution before turning on the unit. If it is not connected to it's venting system, you would have a forced induction source of ignition if you had a leak in your piping. These units should only be installed by a licensed plumber or gas fitter, one simple error could allow carbon monoxide (CO) into your house
Aug 25, 2009 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Air intake hook up problems
Typically you will be able to bend the gray hose to make an elbow or untwist the elbow off of the factory supplied air intake hose and use that.
Jan 11, 2009 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Looking for Manuals
Google rinnai 1004 and 556 manuals. I just did and found them
Nov 26, 2008 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Rinnai 1004 error code 11
I had this problem and oops, the gas intake was closed. check the door on the right side of the unit, and make sure the valve is turned to "open" .... here's the link for the online manual if you want it: http://lib.store.yahoo.net/lib/hectors876/1004om.pdf
Oct 04, 2008 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater - LP Gas Logo
973 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
