Question about Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water
Where is the freezer thermostat located on the refrigerator or where do we find the stematic. We have a side by side Model #ARS2665AW and we are trying to replace the freezer thermostat.
    President:
  • 1,136 Answers
Hi, Remove the kick plate in the front and see if there is a wiring diagram wrapped in lastic. It could be inside the control panel too.
Posted on Jul 15, 2009
We're is the frost timer locate at on a frigdaire frs6lfjw3
more than like top front where thermostat and freezer dial are located if its a newer model side by side a defrost control board the defrost thermostat or sensor is in the freezer cliped on the coil
Nov 06, 2014 | Refrigerators
Tip
How to Replace a Thermostat in a Fridge?
If there cooling and defrosting problem in your fridge. Also over cooling or not getting cooling properly problem. Then the problem relates to thermostat.
The procedure to replace the thermostat is as follows: ---
1) First of all unplug the fridge/refrigerator unit from electrical outlet for complete safety.
2) In top freezer and bottom refrigerator model units. The thermostat is located at the rear of freezer side. But in some units its located in the bottom of the refrigerator floor panel.
3) In side-by-side refrigerator the thermostat is located at the back of the freezer side.
4) To remove the thermostat you will have to remove the screws from the icemaker section located in the freezer section.
5) After the screws from the freezer’s inner section are removed. The inside panel will get loose and come out.
6) Many a time the screws are hidden under rubber type butches. So its bit hard to locate the screws. So check out properly that all the screws in the inner section are properly removed.
7) After the inside panel of the freezer section is removed. You will see the thermostat. It has wires connected to its terminals. Be care full that you don’t pull out any wires. They are very thin and delicate wires.
8) The wires are connected to the thermostat by a connector. So slowly remove the connector from the thermostat using a needle nose pier. Take care you don’t put any force while doing this. It’s very delicate but not very hard to do.
9) After the wires are removed. Remove the screws holding the thermostat .In some models the thermostat is screwed to evaporator coil tubes. In that cases take care you don’t damage the tube while removing the screws holding the thermostat.
10) Before removing the thermostat take care you note down the position of old thermostat. so after the old thermostat is removed out by removing the screws. Place the new thermostat in the same exact position.
11) Refit all the parts which you removed while removing the old thermostat in reverse method. Take care you don’t miss any part fitting.
This will help. Thanks.
on Mar 20, 2010 | Refrigerators
Maytag refrigerator
Your unit has several thermostats in it. The defrost thermostat is located in the freezer section usually close to the evaporator coil. Your freezer thermostat is located there also. Some refrigerators have several thermostat located in the fresh food side. One close to the control in the upper portion; some have one down by the vegtable bins. And the top end models even have a thermostat in the butter compartment. Without the model number it is hard to tell what is your case.
Jan 08, 2012 | Maytag Refrigerators
Fridge starts for about 30 seconds then cuts out and No 5 light starts flashing,not in possession of a manual so would like to know what the problem is,sounds like the thermostat but who knows.
I think your start relay, run/start capacitor and overload on the side of the compressor need to be checked or replaced. What is happening now is called short cycling and if the refrigerator remains plugged in the internal overload could fail and really become a mess. If your refrigerator is a GE Profile, Artica this solution will focus more on the mother board. More on how to test compressor and locate model numbers HERE and near bottom of page. How to Test a Compressor,Thanks, Sea Breeze
GE APPLIANCE MODEL NUMBER LOCATOR'S
Refrigerators
Freezers
Jul 15, 2011 | Refrigerators
Amana ARS2665AW side by side ice maker not filling
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don’t refill with water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Aug 27, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Defrost heater not turninh on
That model has what is called a adaptive defrost on it this fails very often it is located inside the ref under the control panel, The only other possible cause would be a defrost thermostat, this is located near the heater.
Aug 11, 2009 | Maytag MSD2650H Side by Side Refrigerator
Freezer working fine, Fridge is freezing everything on low settin
THERMOSTAT ON 90% OF SIDE/SIDE REFRIGERATOR IS LOCATED AT THE TOP OF THE FRIG COMPARTMENT .YOU KNOW, THE ONE THAT HAS OFF ON IT AND USUALLY NUMBERS. YOU WILL HAVE TO DROP THE PANEL TO ACCESS THE THERMOSTAT. ALSO NOTE THAT AN INDICATION OF A STUCK THERMOSTAT IS WHEN THE COMPRESSOR RUNS AND RUNS AND DOESN'T SHUT OFF.ALSO CHECK FREEZER TEMP TO SEE IF IT IS BELOW 0 DEGREES THAT ALSO INDICATES STUCK THERMOSTAT.
Jul 25, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Refrigerator side not cold
if you have frost build up on rear wall of freezer section then your unit is not going through defrost. its either defrost heater, defrost thermostat (which are both located on evaporator) or defrost timer
Jun 24, 2009 | KitchenAid Superba 21.6 cu. ft. Top...
GE Model tfx24f defrost not working.
Replace the defrost heater and defrost thermostat located behind the freezer panel inside the freezer compartment.
Jun 12, 2009 | GE PSC23NHN Side by Side Refrigerator
Amana Side by Side Refrigerator ARS2665AW Compressor
I would have the refrigerator checked out. The last place that was worked on would be the starting point to look for a fault. The wires for the compressor operation are located in the same area as the wires for that fan motor that was replaced.
Aug 24, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water Logo
196 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
