Question about Moen 3175 Legend One Handle Shower Faucet With trol Pressure Balancing Valve....
Single handle shower no hot water.
Single handle only cold water now comes in. I took it apart and it does not appear to have a cartridge but a teeth system. I am not sure of the brand.
  • Bill Johnson May 11, 2010
    can you give me some more info please?
    Top Expert:
  • 12,170 Answers
When shipped the anti scold is in cold mode remove center handle will c a blue and red adjustment pull red off and move up or down and replace check for desired temp if cold or to hot readjust
Posted on Oct 10, 2009
We have no hot water coming out of our bathtub faucet. We took it all apart and water is only coming our of the cold side of the pipe
there is probably a shutoff on the rough-in valve in the wall. Sometimes the seal in that comes apart and blocks the water. Get new stem for valve. Unscrew the nut, replace stem, tighten nut. Clean inside valve before u put new one in.
Oct 10, 2015 | Delta & Single Handle Shower Faucet
Replaced cartridge now only have hot water
You likely took out the anti-scald ring out when you took it apart and then put it in in a different spot preventing the handle from turning far enough. You may also have the cartridge or handle upsidedown.
Nov 25, 2013 | Price Pfister R897EBK Brushed Nickel...
Getting hot water when shower valve is first opened.
If I understand correctly, you have single handled shower faucet.
Normally there is a wait for hot water to arrive at faucet.
But now hot water is already at shower faucet.
Single handled faucets have a mixing area inside valve where hot and cold come together before going into sink.
This mixing valve can have crossover where the hot and cold can pass through to each other even when faucet handle is off. When single handle faucets get old, this can happen.
How it happens:
For example another faucet is turned on inside house, and pressure differential between hot and cold causes hot water at shower handle to pass through mixing area and into cold water line.
So if another faucet has been run, then that lets hot flow to faulty single handled shower faucet.
To confirm this is the problem: turn on other faucet and put ear against shower faucet to listen for moving water.
This condition may also signal there is a water leak.
The problem is not harmful, but will draw cold water into water heater each time, and is energy wasteful.
Replace faucet or have plumber repair problem.
Feb 19, 2011 | Price Pfister Single Lever Handle Faucet...
We recently installed a Moen single handle faucet in a refinished shower after having a plumber replumb the front of our house. Handle appears to be properly installed. Now there is no hot water or even...
u need to adjust the scald protector all single handle units are shipped in cold position for safety reasons if have paper work for handle it explains how to adjust if not unscrew handle and remove on handle / valve stem will see a red and a blue plastic clips pull back clips and turn slightly and push back do this till desired hot and cold setting are to your liking replace handle and your done
Dec 17, 2010 | Moen & One Handle Tub & Shower Faucet
Single-handle Glacier Bay shower faucet, hot/cold reversed
Behind the handle check to see if it has a dail to take out and replace at a different postion this will change the hot and cold. It a anti scald protection device. Don't remove cartridge just adjust dail.
Mark where you start and take out and move a 1/8-1/4 turn at a time and replace til temp desired. It has teeth like a gear you move to adjust temp.
May 11, 2010 | Delta & Single Handle Shower Faucet
Moen Single Handle Shower Faucet-turn on get cold, little hot
You can try to rotate the first plastic ring to the left of center a few teeth, this will let the handle advance alittle more to the hot side.
Oct 09, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Only hot water, no cold water.
The cartridges in the single handle units are prone to display this issue in hard water areas as mineral deposits such as calcium build up on the stem. The stems also have small rubber band like rings - for lack of a better term- that break apart and can clog the ports on the side where the are on. New stem should resolve the issue totally unless you have had a pipe break or other construction to the plumbing system recently. Thanks for using Fix Ya.
Mar 01, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Moen 3175 Legend One Handle Shower Faucet With trol Pressure Balancing Valve.... Logo
406 people viewed this question
Top Moen Plumbing Experts
john h
Donni Steen
Don Numinen
Don Numinen
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
