Question about Ovens
Timer is making ticking noise cant turn it off.
My same oven makes a ticking sound when you tell it to start pre-heating the oven. The oven continues to make this ticking sound until you stop the oven and it completely cools down. This ticking sounds to be coming from the oven control panel. I have no solution, but I'm glad I wasn't the only one who had a problem with this ticking sound!
Posted on Sep 28, 2010
My delonghi oven is making a ticking noise and with all the switches turned off it's is still heating and rather hot. Won't turn off and cool down
Sounds like an improperly grounded element in the circuit... If an element or wire makes contact with the metal frame and welds itself in place, the electrical current can BYPASS the control and heat uncontrolled- throw the circuit breaker to interrupt the power.
A thorough inspection must be made of the elements and wiring.
Help Me Find My Model Number
Dec 12, 2016 | DeLonghi Ovens
I can't make it stop , Its supposed to be off , minute minder is off as well as the auto control center . I just can't make the start time to go off , I hear noises ,like ticking noise.
if all elements are not warm then there is no quantity of power being used
have an electrician check out the stove as it may be a faulty minute clock
check around the room for a clock that is keeping the time as that is a ticking noise even though it is battery operated.
May 21, 2015 | Ovens
My wall oven is making a constant unusual noise
Without a model number its hard to be exact. If your oven is older it will have a clock timer motor that turns the dials or flips the clock display cards. This timer has gears and bushings that will be annoying as they wear and start a vibrating hum or clicking-usually not worth tinkering with..it can be taken out and checked or replaced. Electronic timers of course don't have any moving parts to the timer, but have relays in the circuit to turn the oven on and off. They do not 'whir'. This is the likely issue.
Repost..let us know.
Apr 28, 2015 | Ovens
Timer very soft cannot hear it
Ive heard of this before. Many oven Manufacturers use clockwork timers which give 1 faint "ting" noise when finished. Others use electronic ones, which are not much better. If you are not standing next to the oven, you cant hear it. I usually recommend a separate timer , like a water timer or egg timer type thing which you can set (and Hear) and leave it near where you are working so you can go and turn the oven off. These can normally be purchased at Smiths, Tandys etc maybe Big W or K Mart
Apr 09, 2015 | Ovens
Everytime i turn on my stove it makes a big bang noise, i cant figure out what else it could be.
Sounds like your cord or wireing may be arching. Your elements may also be making that noise. Carefully try to see if you can see what is arching.
If you need further assistance please comment me back.
Jul 27, 2011 | Ovens
Why does my Jenn Air convection oven make such a LOUD clattery/ticking noise whenever I use it? I think it must be the fan...can you help?
If you can get at the fan blades without taking anything apart, try to turn the fan blade by using a small screwdriver or even a small wooden skewer. Listen to see if the blades are making contact with either fan cover or the back of the oven or the edges of the convection opening.
Once you determine which blade(s) are making contact, use a sharpie marker to mark those blades you need to correct. That way if the blades are hitting the fan cover, you'll know which ones need to be bent back into shape once the cover is removed.
With the oven turned off, you should be able to remove the circulating fan cover and correctly bend the fan blades back into shape and stop the noise.
Hope you found this very helpful and best regards!
Aug 07, 2009 | Ovens
Smegg Oven Model Number and problems ... please help =)
It looks like an S551X-5, I think the timer is a safety mechanism, maybe just set it to full when in use and turn it off when you finish.
Go to http://www.smeguk.com/KitchenStudioLine/Product/S551X-5.aspx to see features, etc.
Jan 28, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Baumatic oven not heating up
I have the same model steel finish was looking for parts mysel and came across yr dilema... I had that problem before . I always turn left knob to fan.. turn heat to whatever say 200 then click the button with the hand signal and i never touch any other button it alays does the job for me.. i cant cook so never need to touch ant other button ,,,, its a timer issue that stops it heating up swtch it all off at spur or mains start it up again
DamienPJennings@aol.com hope this helps
Jan 13, 2008 | Ovens
Burners on gas stove work but oven and broiler not working
Most ovens, unless they have an electric igniter (does it go tick tick tick when plugged in and turned on? If so, it has an electic ignition.) have a pilot light. In order to keep gas from flowing out, and to prevent a possible explosion when the pilot light has gotten put out, they have an electric thermocouple on them that shuts off the gas when it gets cold. Plug the cord back in, and relight your pilot light by holding the lighter (I recommend a fireplace match or bbq lighter, not a cigarette lighter to prevent singed knuckle hairs!) over the thermocouple for a couple of minutes.
Nov 19, 2007 | Maytag CWG3100A Gas Single Oven
Ovens Logo
297 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
