Home | Phones | LCD Display on the han...
Phones
Problem for Phones
Generic problem for all Phones
LCD Display on the handset
By Nowinozal on Nov 17, 2007
The phone comes on but the display screen does not seem to function any more - it just turned off and won't now come back on rendering the phone useless.
Comments:
Nov 20, 2007
- It's a Motorola Razr V3i and cost $149 three months ago. Inexplicably, it has started working again after two days on charge and is still going as I type - could it all be a battery/charging lead problem?
Same Problem
Apr 27, 2009
-   I just hooked everything up and the display is grey and almost impossible to see who's calling.
Stupid me, this is my second one - had the same problem with the first but thought it was defective.-   andykobe
Feb 13, 2009
-   I have a GE Digital 5.8 GHZ and same thing happened little over a year old and both phone displays are now missing half the information all sort of pixalated, don't think this is a repair issue seems to be a defect issue -   cinnymint
Dec 25, 2008
-   I've had the phone for about 7 days and the same thing happened. It worked pretty good, a couple of times colored stripes appeared instead of the photos. I unplugged the phone and plugged it back in and it was fine. But now, nothing - the phone works, it is charging - indicated by the green 'charging' light, but no pictures and of course, no access to any type of menu to allow me a chance to try to reset in any way.
It was great while it worked - I have the box, guess it is going back!-   marmar99
Jan 26, 2008
-   PHONE WORKED FINE FOR ABOUT ONE WEEK THEN PHONE NO 2 LOST THE DISPLAY. A WEEK LATER PHONE NO 1 LOST ITS DISPLAY. CONTACTED PANASONICS HOT LINE FOR SERVICE INFO/. AND HELD ON LINE FOR OVER 15 MIN. WITH NO ONE ANSWERING.-   Guest
Solution #1
posted on Nov 18, 2007
Somewhat Helpful)
Priority1
Rank: Wiz
Rating: 84%, 312 votes
It is unlikely anyone could help you solve this problem over email but it is impossible without more information. The make and model of the phone would be very important. If your phone has a common problem with the LCD that could be easily fixed we would need to know what type of phone it is.
With what I know so far, unless your phone is worth spending $75 or more repairing it then it is a throw away item. Most likely the LCD would need to be replaced at a cost of $10 to $40 plus shipping, labor, etc... Worse yet, MOST LCDs are just not available.
Comments:
Nov 20, 2007
- Well, I doubt it's a charging problem unless the phone did not turn on at all. It sounds like an intermittent problem.... it wouldn't surprise me much if it never happened again but chances are it will. If this phone is under any sort of warranty I would try to duplicate the problem and send it in for repair. If you can duplicate the problem it will most likely only get worse over time and the problem could be in the LCD itself, LCD connector of LCD driver IC, etc.. so simply replacing the LCD would not necessarily solve the issue. Usually heat and humidity changes will bring out an intermittent problem like this. You could try putting the phone in the fridge or heating it with the low setting on a hair dryer. Small amounts of vibration can also have some results. Sometimes vibration increases an intermittent problem, sometimes it makes them go away temporarily.
Was this helpful?
Yes
No
Popular Solutions for Phones
Questions and Unsolved Problems for Phones
Answer
What is an affordable corded phone with big buttons for an elderly with poor eye sight with an... (More)
Answer
My LG Banter phone will not play music from my micro SD card. There is music on it from my computer,... (More)
Answer
My Panasonic DECT 6.0 always says "New Voicemail". We do not have voicemail through our... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Phones:
Top Phone Experts
Rank: Guru Guru
Solutions: 554
Experience: Experienced a lot in computer troubleshooting. Knowledgeable about cellular phones.
Ask Me
Find more Phone Experts
Top Telephone Repair
(800) 513-9962
Component level repair and complete refurbishing...
BARCLAYENTERPRISESINC
(316) 262-7171
Cctv,Cable Tv Wiring & Outlets,Computer Wiring...
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
