Question about Samsung HL-S6187W 61 in. HDTV
My TV set keeps turning off by itself.
The problem continues to happen at a quicker interval as turn the unit back on. I checked the timer and it is not on. The current bulb is the original the DLP came with. I thought about replacing it, but wasn't sure if that was the root problem. Please assist.
  • 304 Answers
Since the lamp is the original I suggest replacing the lamp. There is a Black Lamp Door in the rear of the set. Remove the Door and then the Lamp Exhaust Duct. Then you will see the lamp. Loosen the one screw on the Lamp and pull straight out. Now look at the front of the lamp. If you see shattered glass in side then you have a bad lamp. Note: Sometimes there will be no shattered glass and the Lamp can still be bad. When you have the new lamp becareful not to touch the front glass, not even once. Reinstall the new Lamp in the reverse order and make sure that you reinstall the Lamp Door and tighten the screw as the tv will not work with the door missing. The Lamp part# is BP96-01472A.
Posted on Jul 16, 2009
My tv, when plugged in just keeps turning itself on and off in intervals of about 3 seconds. It doesn't give time for anything to come up on the screen at all.
Problem is in standby power supply or microprocessor area---not the do it yourself repair and likely not economical to repair due to age and brand of set.
Sep 01, 2012 | Philips 60PP9352 60" Rear Projection...
Over tv its getting aoutmatically off
Hello
Put your hand on the back of your TV to check for overheating, if your set keeps switching itself off without warning.
Many TV sets come equipped with a safety feature that switches the power off if the set gets too warm.
Check the cooling vents located at the rear of your unit. Vents can collect dust and dirt, resulting in the fans becoming blocked and failing to work properly.
Remove dirt from the vents with a damp, clean cloth. Ensure the air conditioning is kept at adequate levels in the room where your TV is located. Keep the drapes shut on hot, sunny days to keep the room cooler.
Check the sleep-timer function on your TV if it keeps turning off. A sleep-timer is used to turn a television set off after a certain period of time has elapsed. If the sleep-timer is not turned off, your television will continue to turn itself off after a certain period of time.
If the problem persists,then a heat sink has gone bad.
The on/off button simply toggles a low voltage circuit that powers your tv. If it is dusty, it may complete the electrical circuit and send a false signal.
Take a can of compressed air, open the back and clean the dust off the circuit boards.
NOTE;opening the TV VOIDS warranty!!
Dec 22, 2010 | Televison & Video
How does the Timer and Sleep functions work for the SUMO KFR-70GW Heat Pump
Hi!!
On the timer function, when you press the button, it will ask you the starting time and ending time of when the unit will start and turn off by itself. prior to use this function, the clock on the control has to be set.. On the sleep function, it will give you the option to turn off unit on 30 min. intervals. Just like on a TV.
Aug 10, 2010 | Heating & Cooling
Why does my Sony 57" Hi-Scan 1080i? 16:9 Projection Television keep turning itself off. I turn it on and after 10 min it shuts itself off I can turn it back on but the longer it is on the quicker it shuts...
Sounds like a heat problem. Check to make sure that if it has a internal fan that it is working, and clean any dust build up, most projection tv's have fans, usually the number of flashes indicate a code that repeats.
Mar 16, 2010 | Sony KV-28FX60 28" TV
BUSH ID - HD TV
Try Checking your remote and make sure it did not short out by taking out the batteries and see if it continues turning on and off. if so then i would recommend replacing the remote. if this does not work try putting tape over the ir receiver and see if it continues, this will check for interference.
Nov 05, 2008 | Bush 5693D 24" TV
No pic
alright guys...blew a bulb....fixed that. still didint work...found out it was ballast...replaced that. tv worked for a month..all the sudden hdmi input didint work id plug in my playstation and screen would turn green and say "hdmi color has been corrupted" im thinking wtf? so a week later it works fine then just turns off in middle of watching espn... comes back on an hour later...only to turn off again...it just turns black for ten seconds then just turns off and the red and green lights blink at intervals of one second....replaced a bulb..not that, same problems.......when the tv comes on for the ten minutes before it quits working the pic and sound are great i just dnt get it...is it shorting out? color wheel bad? a fan?
May 24, 2008 | Toshiba 52HM95 52" HDTV Projection...
Assistant
is this electricity pocket plugged up to a timer ? or take the tv back to the shop... lost the receit just look for the same tv on computer
Feb 20, 2008 | Toshiba 28N33 28" TV
Assistant
check your sleep timer settings thats the most comman prob
Dec 18, 2007 | Philips 27PT81S 27" TV
TV keeps turnig itself on....Sony kv-27fs12
There is a problem with its remote timer circuit., it needs to be repaired by a technician.
Aug 16, 2007 | RCA F27650 27" TV
Nextvision n5
check your sleep timer settings. they stay on no matter how much you turn your unit on and off.
Oct 29, 2006 | ViewSonic NextVision N5 (n5-2) Video...
Samsung HL-S6187W 61 in. HDTV Logo
582 people viewed this question
Henry  Thomas
Henry Thomas
