Question about Polaris Pb4-60 Volute Polaris Booster Pump Part P5 P-5 Volute
Impeller does not spin freely
I took the pump apart to replace a few parts and when i put it back together the impeller seems really tight and doesn't spin freely. Now i can't get it off either. I do i keep the shaft from spinning so i can get it off, it came off easy the first time
  • 990 Answers
Pop off the half dollar sized cap at the back of the motor and use an adjustable wrench to hold the back of the shaft. They make a tool for this but with a little innovation an adjustable will do the job fine. When puting the impeller back don't tighten it more than hand tight and don't bump the motor on to seat it, this will overtighten it. You may have crossthreaded the impeller and will need to tap it out or replace it.
Posted on Aug 24, 2009
New pool pump motor is rattling
This really sounds like a motor going out. I would take it to a motor shop and have them check the bearings.
US Parts Center
Apr 07, 2014 | AO Smith Pool & Spa
Pentair Whisperflo 1.5 hp motor will only turn with help. Can it be fixed?
maybe bad start up capacitor remove match and replace or replace pump motor or pump
Sep 02, 2012 | Pentair Pool & Spa
I have a GE front load washer. I have had to check the filter in the bottom of the washer many times since I have had it. It has stopped draining again and when it is trying to pump we noticed that the...
This is the sign of a pump failure, the brushes in the pump motor are getting weak and this makes it hard to start the pump. Once you spin it it will take off because it had the impeller loosend before starting. I would say at the least you have bad brushes and maybe a bearing in the pump trying to seize on you. I would get a pump motor and keep it handy!
Mar 17, 2011 | GE Energy Star WCVH6260F Front Load Washer
My impeller was clogged and my pump was only humming. so i cleaned the impeller put it back together but it still only hum s its a baqua pure 2 hp pump. any advise
Check to see if the motor spins freely or appears to be dragging or stuck. If it does not spin freely, then you need to overhaul the pump and replace bearings and shaft seal or locate the source of the dragging in the pump housing
Apr 04, 2010 | Pool & Spa
Reddy Heater 110K btu motor won't start.
Bearing have gone bad in the electric motor. You will have to replace the electric motor. They are expensive but still cheaper than buying a whole new heater.
Jan 05, 2010 | Reddy HEATER RH125T 125,000-BTU...
Machine will not drain and spin
http://www.partstore.com/Part/LG+Electronics+Incorporated/LG+Electronics%2fZenith/4681EA2001D/New.aspx?ModelMfgName=LG+Electronics+Incorporated&ModelBrandName=LG+Electronics%2fZenith&ModelNumber=WM3431HW
you need a new one of these. i took mine COMPLETELY apart and found the impeller jammed. the impeller is a magnet in a sealed plastic carrier with an electro magnet around it. the electro magnet energizes , the two opposing fields spin the inner magnet ( just like a fish tank filter good idea actually!) the inner magnet on mine had a slight crack from factory causing vibration and allowing debris past the seal then jamming the impeller. to check yours drain it with the small drain tube, then get a towel or two and place around the unit at the floor.pull the large black drain cover off and after the gushing tidal wave look inside. you will see the white impeller. try turning it with w screw driver , pen or whatever. you may be able to remove and then clean / reassemble and be good as new. i only needed two tools to tear the machine apart. a Phillips screwdriver and pliers to get the clamps on the pump (2) and the clamp back on the door to drum gasket.
Nov 06, 2007 | Whirlpool AWM5145/2 Front Load Washer
Water not going through spray arms
1.does motor run? no. replace motor. 2.open door and leave the bottom rack inside dw.spin the spray arm underneath the bottom rack by hand. it should spin freely without binding. if it doesnt spin freely take out the bottom rack and try again. if it does spin freely then your bottom rack is laying on your sprayarm preventing it from rotating. 3.you could also not be getting enough water into your dw.
Mar 21, 2007 | Frigidaire 24 in. FDB421RF Built-in...
Polaris Pb4-60 Volute Polaris Booster Pump Part P5 P-5 Volute Logo
230 people viewed this question
Top Polaris Garden Experts
Paul Bade
john h
Are you a Polaris Garden Expert? Answer questions, earn points and help others
