Question about Briggs & Stratton Garden
Briggs & Stratton engine loses power
I have a Briggs & Stratton power washer that wouldn't run so I replaced with an identical spark plug. Now it runs, but not at full power. Every so often it kicks into full power so I know I am not imagining this, but then it goes back to running at about 60%. I may have tipped the washer over when replacing the spark plug. Would oil leaking into the engine cause that?
  • 174 Answers
Hello herb1007
If it is running it would burn any oil off the top of the piston. (that got there when you tipped it). It sounds like you carburetor needs cleaning. There are sprays on the market that sometime help with this.
Posted on Jul 16, 2009
Spark plug gap
How to Gap a Spark Plug - YouTube
? 2:57
https://www.youtube.com/watch?v=IuW3svdqKZM
Oct 15, 2012 - Uploaded by ChrisFix
How to correctly gap a spark plug. This is a fast and easy video on how to gap a spark plug and spark plug gap ...
FAQ: Find My Engine Spark Plug & Gap ' Briggs & Stratton
www.briggsandstratton.com/.../identifying-the-correct-s...
Briggs & StrattonFollow this step-by-step image guide to locate spark plugs in different Briggs & Stratton engine types. ... Spark Plug Type & Gap Chart for Briggs & Stratton Engines. Now that you've found the part you'd like to replace, you can use the chart below to identify the genuine Briggs & ...
Spark Plug Gap - AutoZone
Dec 15, 2015 | Cars & Trucks
What is spark plug gap on unidentified pressure washer?
Briggs & StrattonLearn how & where to find the right spark plug and a gap chart to guide you through ...are commonly used for walk behind lawn mowers and pressure washers.
Spark Plug Gap - Troy-Bilt
Nov 24, 2015 | Garden
BRIGGS AND STRATTON 550 SERIES
Identifying the Correct Spark Plug and Gap
What is the correct spark plug and gap for my engine?
Due to the variety of engine and equipment configurations, your best source for spark plug information is your engine or equipment Operator's Manual. However, the following general guidelines will get you pointed in the right direction.
This guide provides the common spark plug part numbers used in our L-Head and Overhead Valve engines. For information regarding the service/replacement of spark plugs, please visit our Servicing the spark plug FAQ. Please be aware that the size/shape of the spark plug varies depending on engine design.
Briggs & Stratton L-Head Engines
(also referred to as Flat Head or Side Valve Engines)
Sep 29, 2014 | Briggs & Stratton Garden
Engine lockup
Sounds like the intake or exhaust valve is not opening.
Jun 08, 2013 | Craftsman 2700 PSI Briggs Stratton...
18 hp briggs and stratton no spark
unplug oil senso still no spark un \plug shutoff wire to coil still no spark replace coil
Nov 15, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Low power when under load lt1024 cub cadet 24 hp els 725 ohv
always check spark and compression first spark needs to be blue and compression should be 120 but will barely run on 80psi if both are fine rebuild and acid dip carb also check muffler for carbon build up clogged muffler means no power
May 16, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Stratton 2500 Power Washer Loses Pressure Time to Time
If by "a few minutes" you mean 180 seconds, I really don't know what to say. But if you mean 5-10 seconds, you probably are experiencing air in the water line or normal engine warm-up behavior when the choke has been set to full lean too soon.
May 23, 2009 | Briggs & Stratton 020324 3700 PSI Pro...
Garden Logo
325 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
