Question about LG Shine KE970 Cellular Phone
Glass is so scratched that i can barely see it unless the room is dark
    Problem Solver:
  • 10 Answers
Call lg
Posted on Jul 16, 2009
Pinball keeps bouncing up and hitting the glass, is this going ot scratch or break the glass?
Pinball machine glass tops are made out of tempered glass, they would have to take a direct hard hit to break. I've been playing for years and nothing has scratched or cracked yet so you shouldn't worry about it.
Oct 03, 2013 | Video Game Consoles & Games
My pointer just started jumping around, I have changed no settings or the position of my sensor bar ans my batteries are good
Try reducing the amount of light or glare in the room. If light bounces around the room it can affect the sensor.
Feb 28, 2011 | Nintendo Wii Console
Will the HB51R have to be placed outside to work on dusk to dawn.
The dawn to dusk feature is activated by photoelectric eye that senses when it gets dark.
If you put timer in a dark room, it will turn ON ... let's say to operate Christmas tree after you leave a room for the evening.
But if room stays dark, the timer will not sense when to turn off unless you also set timer to turn off 1-9 hours after ON.
That being said, a Christmas tree might make too much light for the timer's photoelectric eye.
Make sure photoelectric eye is turned away from direct light.
Dec 09, 2010 | Intermatic Outdoor Timer/Photo Control...
Red Lines through picture when screen is dark, back ground has a red tint. On my 48 "Sony Rear Projection" TV
You can try adjusting the Red color output. (Very touchy adjustment)
If you take off the front cover/speaker cover, there should be a access panel. Behind that, there should be a small square black box with 6 screws on it. This is the focus block. (At least this is where most of them are located)
It sounds more like you may need less red in the mix. There is a screw for each color. R, G, and B. Do not mess with the focus screws, just the ones labeled 'SCREEN.'
Go to an unused input where the screen should be dark. Barely turn the red down in a dark room so that the red spot is at the same level as the Blue and Green.
Use an insulated screwdriver and DO NOT TOUCH the focus block and ESPECIALLY NOT the back of it.
Very HIGH VOLTAGE. I found that out the hard way.
Do not turn any of these up too high or damage may occur and the TV may detect a short and shut off.
I have found that if the three colors are adjusted in a dark room to where the 3 color spots (R/G/B) are just barely visible on the screen at equal levels, there is a pretty good color balance.
I hope this helps! Just be careful.
Apr 19, 2010 | Sony KP-48S75 48" Rear Projection...
I have a dark line across copies
Whats the make and model of the copier?
One culprit might be the drum.  If you can take a look at the drum from your copier and you see black lines on it.  It could be scratches on the drum or it may need a new cleaning blade to clean the toner off the drum.
Nov 11, 2008 | Office Equipment & Supplies
Gray picture
This sounds like you have the contrast setting too high, go to your menu and find the contrast settings, and adjust to your requirement. As for the words being blurry, this could be because your tv is HD ready, and unless you view a High Definition channel then the picture will be a liitle blurred.
Hope this is of some help?
Sep 16, 2008 | Samsung DynaFlat TX-P3064W 30" TV
Cleaning glass cooktop surface
I used Mr. Clean multi-surface and the green, back side of the sponge. Turned on a light to show visible stains better, and scrubbed away. It didn't scratch the glass and got it out quick. Hope this helps.
Jul 20, 2008 | Jenn-Air JED8430 Electric Cooktop
Projection TV when turned on picture is dark can view slight images until dinning room light is turned on
Try hooking the TV to a different outlet fed by a different breaker. Does the problem go away? If so, the culprit may be a wiring problem in your house that is causing the TV not to get enough power unless the dining room light is on.If in doubt, consult an electrician to make sure both the dining room light and TV outlet circuits are working properly.
Mar 06, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Copies here and recipients faxes: dark, lined
How long has the drum been in there?
try this:
1-take out toner, look and see if it is ok. do you see stripes on it?
2- look at the drum are there any black rings on it? ( you did not specify white or black lines)
3- where the glass is on the opposite side ( the part you lifted to clean the glass, look at it standing from the back. you will see a white metal plate with some springs in it if you touch it. this is the reference that the fax has if there is/are a black dot on it it will give you a black line clean carefully. if it is scratched use white out to cover and make white again.
For the darkness try making a copy in photo mode if it is still too dark change drum.
Dec 07, 2007 | Canon FAXPHONE B640 Plain Paper Bubblejet
LG Shine KE970 Cellular Phone Logo
55 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
