Question about Intel Motherboard
Update Graphics Card + PSU and my computer DIED.... please help
1) XFX GeForce 8800 GTS XXX Edition 640MB DDR3 PCI-E Dual DVI 1.8Ghz
2) 650w. PSU bought for £16
Changed the graphics cards and connected all the power cables...
turn computer on and plat BF2 for a while not problem...
However the computer switched off while playing. but restarted fine and then played for another 4hrs with no problems.
Then my brother played GHOST RECON which I guess is more demanding for 15 min.
Then the PC just DIED....and the PSU smelled burnt!! and could not restart the PC.. then I switched back my old graphics card and PSU and the PC tries to start as the fun start moving but then the powers goes.. and 5 seconds later the PC tries to restart but no luck....
-How do I know if the motherboard is gone??
-What about the other components?
-I also unplugged the HD, DVD drives, and still the PC did no start.. however you can tell that the PC tried to start as the Fans tried to start but then stop....
  • 41 Answers
Re: Update Graphics Card + PSU and my computer DIED.......
A little something I picked up from a DELL technician, when checking for bad capacitors don't know how much it will help:
on top of each capacitors check for:
1. bulged tops (by default all capacitors are suppose to be flat on top)
2. Broken tops (bulged all the way)
Hope it helps.
Posted on Nov 18, 2007
  • 59 Answers
Try removing the ram to see if thats the problem,although I dont think it is.When you remove all of the other components and the motherboard still does not keep the fans running then you have correctly diagnosed the problem as a bad motherboard.Good Job!! I would say the motherboard is BAD.Also A burnt smell is BAD BAD BAD.All the symptoms you are describing are text book signs of a bad motherboard.ANOTHER REASON TO UPGRADE!!
Posted on Nov 17, 2007
  • 87 Answers
As u mentioned yea if ur computer smelled lyk sumthing is cooking so may b da capacitors or da chip inside them myt be burnt by heavy game called GHOST RECON so it is possible ur motherboard is half burnd half fine lol
0 characters
3 Points
Bootup donot display
Are you trying with one graphics card or more?
Mar 10, 2013 | Pine Technology XFX nForce 750i SLI...
Compatability of PC components
They should provided you get all the right drivers, disable the onboard sound, get a decent hard drive, get a case with good airflow, and make double sure that the drivers for that sound card are the correct ones and that the sound card isn't a lemon. Sound Blaster has seriously slipped in it's quality control over the last few years.
Jun 19, 2012 | Motherboards
Hi. i have a compaq presario sr5025an. I have 2 gig of ram. I have the intel core 2 duo e4300 processor. I am after a grapics card. cheers.
To get the full specs of your mainboard go to:
This motherboard has 1 PCI Express x16 slot for a graphics card.
You could use:
Geforce 6 series (6800GT)
Geforce 7 series (GeForce 7950, GeForce 7900, GeForce 7800, GeForce 7600 ,
GeForce 7300, GeForce 7200 and GeForce 7100)
Geforce 8 series (GeForce 8800 Ultra, GeForce 8800 GTX, GeForce 8800 GTS, GeForce 8800 GTS 512, GeForce 8800 GT, GeForce 8800 GS, GeForce 8600 GTS, GeForce 8600 GT and GeForce 8500 GT)
Geforce 9 series (GeForce 9800 GX2, GeForce 9800 GTX+, GeForce 9800 GTX, GeForce 9600 GT, GeForce 9600 GSO 512, GeForce 9600 GSO and GeForce 9400 GT
Geforce 200 series (GeForce GTX 295, GeForce GTX 285, GeForce GTX 280, GeForce GTX 275, GeForce GTX 260, GeForce GTS 250 GeForce GTS 240 and GeForce GT 220
Geforce 400 series (GeForce GTX 480, GeForce GTX 470, GeForce GTX 465, GeForce GTX 460, Geforce GTX 450)
With your system however I would recommend nothing greater than a Geforce GTS 250.
Please rate me high.
Nov 01, 2010 | HP Motherboards
I would like advice on upgrading my Graphics card
Unfortunatly your still running low end CPU power and low end agp graphics. Your going to pay 150-200 just for a fair PCIe/AGP HD/3D VC. If $200 doesnt hurt (and this is the lowest price best option), then might I suggest Mobo/CPU/RAM for around $200 that would do the trick and allow for future upgrades. You might also need a power supply. I just built one less than 3 weeks ago for a friend and it fairs against my own gaming comp.
MY PC...
AMD ATHLON 64 X2 DCP 6000+ 3.01GHz
XFX 8800GT AD 512MB
500W PS
NEW PC....
Gigabyte GA-MA785GMT-UD2 MB $90+/-
AMD Athlon™ II X2 250 BOX 3.0GHz (CAME W/FAN)$70+/-
Sep 12, 2009 | Asrock K7VT2 Motherboard
Can foxconn g33M02 handle 500watt psu? and what nvidia geforce 8 series will work on my mobo?
Nvidia Geforce 8 is PCI-E Card.
Here are the list. This were all best and good to your MOBO.
bar_specs.jpg Core Clock (MHz) Shader Clock (MHz) Memory Clock (MHz) Memory Amount Memory Interface Memory Bandwidth (GB/sec) Texture Fill Rate (billion/sec) GeForce
8800 Ultra 612 1500 1080 768MB 384-bit 103.7 39.2 GeForce
8800 GTX 575 1350 900 768MB 384-bit 86.4 36.8 GeForce
8800 GTS 500 1200 800 640MB or
320MB 320-bit 64 24 GeForce
8800 GTS 512MB3 650 1625 970 512MB 256-bit 64 41.6 GeForce
8800 GT
600 1500 900 512MB 256-bit 57.6 33.6 GeForce
8800 GS 550 1375 800 384MB 192-bit 38.4 26.4 GeForce
8600 GTS 675 1450 1000 256MB 128-bit 32 10.8 GeForce
8600 GT 540 1190 700 256MB 128-bit 22.4 8.64 GeForce
8500 GT 450 900 400 256MB 128-bit 12.8 3.6 GeForce
8400 GS 450 900 400 256MB 64-bit 6.4 3.6
  • Full support for both Microsoft® DirectX 10 and DirectX 9 for unparalleled levels of graphics realism and performance
  • NVIDIA PureVideo™ HD2 technology provides unsurpassed Blu-ray and HD DVD movie picture quality
  • NVIDIA 8 Series graphics processors are essential for accelerating the best Microsoft® Windows Vista™ experience
Here is the link for more details about GeForce 8 series:
Hope i help a lot and give some ideas.
If i am helpful, please rate me.
Thank you. Good luck!
Aug 18, 2009 | Foxconn (755A01-6ELRS) (K8S755A6ELRS)...
Best Graphics card for my Pc
Hi Dr,
Best video card for you're Intel D845GVSR would be XFX GeForce 6200 Video Card - 512MB DDR2, PCI, DVI, VGA, TV Out. XFX carries a Lifetime Warranty.
May 09, 2008 | Intel Motherboard
Boot problem
yes i would try to upgrade bios and firmware in all if any has one update thats alot poweer u need hope u have least 600 w dual rail
Jan 19, 2008 | Abit IN9 32X-MAX Motherboard
Computer Not Booting Up
Are you running one or two video cards?
If just one, 550w should be plenty of power. Double check ALL connections and make sure that the ram and all add-in cards are FULLY seated.
Also check to see if the video card requires its own power plug. If it does, it will have a connector on it for you to attach a lead from the power supply.
Also make sure that you have both power connectors plugged into the mainboard, theres one thats only 4 pins and then of course the larger one of 24 pins.
If all connection look good, then start with the basics. Break it down to just the power supply, mainboard, cpu, one stick of ram and the video card... unplug everything else from the mainboard including drive cables and any add-in cards. And check to make sure you processor is seated properly as well as the ram and video.
Let me know what you find.
Oct 23, 2007 | ASUS P5N32-E SLI PLUS (0610839148967)...
normaly ther are two reasons for pc not showing the disply
1 memory card mismach
2 graphics card mismach
get the specification of the mother board and correct the above errors the pc will work if u need more assistace please write to me
Oct 23, 2007 | ASUS AI Lifestyle P5N32-E SLI...
Intel Motherboard Logo
243 people viewed this question
Top Intel Motherboards Experts
Brian Sullivan
Brian Sullivan
Sudeep Chatterjee
Sudeep Chatterjee
Are you an Intel Motherboard Expert? Answer questions, earn points and help others
