Question about General Electric Adora GHDA670N Built-in Dishwasher
Dishwasher won't drain?
We have a 4 year old GE adora dishwasher purchased at Home Depot. It is a Quiet Power III and has standing water in the bottom that will not drain. We are looking into pulling the hose to clear the air or debris, nothing in the dishwasher itself is blocking the draining.
  • 6,784 Answers
HI. check the following areas for fualts.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
Posted on Jul 15, 2009
GE Adora dishwasher model ddt575smf0es leaking from condensation
Sounds like a poor install. If the hoses aren't collected correctly heat from water could cause expansion therefore looser doors and hinges. Make sure the water connections are tight and then check the screws at the bottom of the door. you shouldn't need a pro to fix.
Feb 25, 2014 | GE Adora GHDA654LBG Dishwasher
GE Dishwasher Quiet Power III Dishwasher leaking
The average life of dishwashers is 7-10 ten years so it might just be dying but try this. If the leak is a small one that seems to always be near the left side of the dishwasher put a cup of white vinager in the upper rack and run the unit on pots & pans or heavy duty. This is caused by a build up of detergent that make the unit oversuds, when the suds turn back into water it leaks out the left front corner. The amount of water is not huge, one towel to clean up. If the leak is larger it could be the pump is leaking and you can order a new one with your model # from marcone.com
Nov 27, 2010 | GE Dishwashers
GE Quiet Wash 3, top arm does not spin
It sounds like you don't have enough water. Your water inlet valve may be not letting in enough water or the plastic pump inlet screen located on the bottom of your dishwasher had something blocking it.
  1. Check to see if there is something blocking the plastic screen on the bottom of your dishwasher.
  2. When your dishwasher is in the final cycle add a pot of hot water to the dishwasher and see if your dishes come out cleaner.
If the dishes come out cleaner you may need a new water inlet valve.
Dec 29, 2009 | General Electric Adora GHDA670N Built-in...
Will not complete a cycle
Very likely a bad timer switch.
Fortunatly, they are fairly easy to replace.
Just make certain you plug in all of the connectors that came off the old one into the same places that they cam off the old one.
Oct 27, 2009 | General Electric Adora GHDA670N Built-in...
Same problem. 2-3 inches of water left in the dishwasher at end.
Inspect for plugged drain screen. Sometimes you have to take apart the bottom area for access...
Sep 18, 2009 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
Dishwasher with one inch of water in bottom when complete
undo the drain hose from your drain and put it in a 5 gallon bucket and see how it drains your sink drain maybe stopped up or if it drains into a disposal it may be stopped up
Apr 24, 2009 | GE Adora GHDA656LSS Stainless Steel...
Quiet partner III taking over 4 hrs to complete normal wash cycle
ok check how fast the water is draining,,might be a bit slow...onthejob
Jan 20, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher soap dispenser won't open during cycle
I had the same problem with my GE Adora. The dishes were getting cloudy and the soap dispenser would not open. Turns out the hard water deposits were causing the soap dispenser to stick shut. I purchased and used Dishwasher Magic which is a dishwasher cleaner designed to remove limescale, rust and buildup. I used as directed and now my dishes are sparkling and the soap dispenser pops right open.
Oct 26, 2007 | Dishwashers
GE Adorda dishwasher
This one is a known issue and an easy fix. Use a tie wrap to securely tie the water tube for the middle spray to the upper basket. That's it. Believe it or not, it's that simple. You may want to secure it at the front and the back. To test this you can use the tie wraps used to closed the plastic grocery or bread bags. If this solves the problem you can buy a bag of nylon tie wraps from any hardware store. I had a similar problem with another GE model with a similar problem. The dishwahser used to make a horrible grinding noise during the wash cycle. One I secured the middle sprayer arm the grinding noise went away.
Sep 20, 2007 | Dishwashers
General Electric Adora GHDA670N Built-in Dishwasher Logo
1,485 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
