Question about Goldstar GVR-DD1 VHS VCR
Goldstar KMV-9012 (year 1990) TV/VCR Combo
Main power button turns on both the TV & VCR. I power on, the vcr makes a running/slight grinding noise for about 5-10 seconds, then shuts completely off. VCR will not load a new tape either, automaticially or manually. It only will push in so far, but no reaction. When I power on, I can see the cogs, that would drive the tape, spinning ... but again, after 5-10 seconds it completely powers off. I would even be happy just using it for the TV, as it's hooked up to satelite, however it will not stay on for more than a few seconds, without powering off automatically.
Any suggestions would be greatly appreciated!!
Re: Goldstar KMV-9012 (year 1990) TV/VCR Combo
I resolve it ,it was a limit switch(black color plastic) on entrance of vcr the base was broken,use superbonder to fix it and clean the rest ofthem one is down two are on top
Posted on Jun 06, 2008
  • 579 Answers
This is the problem with these combo units. When the VCR has trouble (this sounds like a mechanical one) it inhibits the TV from working as well cause they share the same power supply. It needs a VCR expert to fix ya up.
I tell people all the time not to buy these combo units unless they really need the conveinience cause you get to throw away the TV when the VCR goes bad.
Posted on Dec 28, 2007
0 characters
3 Points
New sanyo hdtv and old vcr...can't get menu to appear on screen
there is an input or input select button that gives you cable,hdmi and video composite,to run the vcr. hook up cable and put the tv on channel3 to make sure that works first,then play with the rca cables. keep in mind a tape has to be playing,the new tv have a signal sense circuit,if there is just "snow" you get a blue screen
Jul 22, 2009 | Goldstar GVR-E435 VHS VCR
After vhs auto rewinds both it and TV power down
some televisions have a feature where the video signal disappears,they power off.when the vcr shuts off,the signal goes and the tv shuts down
Jul 07, 2009 | Emerson EWV403 VHS VCR
How to connect flat screen t.v to vcr
Easiest way is to connect the TV & VCR using a Scart connector. The VCR should automatically switch over when play is selected. To go over to the VCR channel then select AV1 on the TV input select. ( This may be named different depending what make of TV you have eg. AUX 1)
Jun 16, 2009 | Goldstar GVR-E435 VHS VCR
I'm looking for the manual for a Mitsubishi VCR HSU447 with the remote control RM75502 so I can program my TV to it. Thanks
1.- Turn off your TV
2.- On the remote control, set the VCR/TV slide switch to TV position.
3.- While holding in SP/EP button, press the code button listed below that corresponds to the brand of your TV
4.- Press TV POWER on the remote control. Once your TV has turned on, your remote is set up to operate your brand
Brand of TV Brand Code Button
Mitsubishi 1,2,3
Fisher 0
Goldstar 2,9
Hitachi 8
Magnavox 4
NEC 2,9
Pioneer 6
Philips 4
Sanyo 0
Sharp 3,5
Toshiba 7
Zenith INPUT
I finnaly found my VCR Manual, and I'm glad to share this info with you, because I was looking for the manual all
over the web and FOUND NOTHING!. Bye!
Mar 15, 2009 | Mitsubishi VCRs
Remote codes
Hope this helps.
Feb 27, 2009 | VCRs
Can only get DVD audio when hooking it up to Goldstar VCR...
The DVD must be connected with the RCA jacks-plugs [usually black & red] to the INPUT of the VCR, not to the RF connector. You must press the VCR\TV button to VCR so that the VCR takes control.When you place a DVD movie or AUDIO program it could be copied to the VCR. or played through the VCR.
Nov 11, 2008 | VCRs
No movie picture
If you want to record from cable to your vcr the usual configuration is either cable to cable box, cable box to vcr, and vcr to tv. If you want to get rid of the snowy pictures, you can plug the cable box directly to the tv and separately to the vcr, and you can also plug the vcr into the tv. but the tv has to have two inputs
the best configuration will be the black, screw in, coaxial cable from the cable box to the television and the red, white and yellow RCA plugs from the cable box to the vcr in.
then the vcr our red whit and yellow cables to the back of the tv.
To watch vcr, switch the tv to video mode
to watch cable, switch tv to channel 3 or 4, depending on the cable service.
please let me know if you have questions.
Jun 24, 2008 | Goldstar VCRs
Usaly there is a button on the remote for input but if you do not have that you might try changing chanels below chanel 1. Some Goldstars hide the front input down there
Mar 03, 2008 | Goldstar GVR-DD1 VHS VCR
Now one question - Do you want to record the TV program on the VCR or Movies from a DVD plater hooked to your HD TV?
Jan 10, 2008 | Goldstar GVR-E435 VHS VCR
Hitachi F361 VCR Digital Auto Tracking (not 631!)
I had the same problem when I got the TV from someone and I didnt have a remote. I went out and got a ONE FOR ALL remote and once I got it set up I had it in VCR mode and hit the AV button and now I can get to the channels. Hope it works for you.
Oct 31, 2007 | Hitachi VTFX631A VCR
VCRs Logo
355 people viewed this question
Top Goldstar VCRs Experts
Jaime Hernandez
Scott Eckhardt
Are you a Goldstar VCR Expert? Answer questions, earn points and help others
