Question about Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
PRINTER IS NOT RECOGNIZED. IT IS SHOWING DISCONNECTED ERROR 0X000003eb
  • 295 Answers
Try to install the latest version of Printer software from www.kodak.com/go/downloads on your computer. then open the kodak home center software . and try to print Adjust the settings and you are ready to go. download the user manual from www.kodak.com/go/manuals.
Posted on Sep 21, 2009
How do I reset my canon printer mx330 to accept non canon ink cartridges?
Which error the printer shows?
The Cartridge is Not Recognized? or other ones? Tell me the Error code that the printer shows and i'll help you
ADCSFXworks Printing Center <3
Nov 29, 2014 | Canon PIXMA MX330 Office All In One...
After years of using the same setup I get a communication error on my Epson r290.
Sounds like you have multiple drivers. On the MAC, go to the printer set up window in system preferences and select the r290, then go to the "-" minus icon at the bottom to dump the r290 from the list. Restart the computer with the r290 connected and see if the system recognizes it again in the preferences window. Hit the + icon to add it. Hope this helps.
Sep 04, 2014 | Epson Stylus R290 InkJet Printer
Cannot recognized ink in my canon pixma ip2770
i am having canon pixma ip 2700 inkjet printer. it worked properly till. I got refilled both cartridge and fix it in my printer but the cartridge was not recognized. i had tried installing the cartridge many times and also tried switch off and on it again many times but the printer shows the same error that "An error occurred.Some ink cartridges cannot be recognized." and a message box is opened and it shows that "An ink cartridge is not installed properly.Open the printer's cover, make sure the ink cartridge is installed properly, and close the cover." help me to recover from this problem i can't afford to buy new cartridges. suggest me some ideas and procedures to
Aug 31, 2012 | Canon Office Equipment & Supplies
Wont scan
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print a document again to verify that the problem is fixed.
Nov 09, 2011 | Lexmark X8350 Print, Scan, Copy and Fax...
My new pixma canon ip 2770 cannot recognize the black and colored ink
May 08, 2011 | Canon Pixma iP2700 InkJet Photo Printer
Unable to connect, get error message USB cable not connected but it is. Been working fine until today, about a month old
disconnect printer usb cable, then uninstall the printer from the computer by deleting the driver at the printer console, then connect the printer usb cable up and install using the driver downloaded fromt he kodak.com website. This should solve your problem.
Good luck.
Feb 05, 2011 | Kodak ESP 5 Printer
49.4c02 service error in hp laserjet 2300n
HP 2300 ERROR 49.XX
• A critical firmware error has occurred on the printer
• Turn printer off then on
• Disconnect the parallel cable or the network cable
• If message still there when the network cable is disconnected
upgrade firmware in jet direct card and the formatter board
• Bad network cable
• Replace firmware DIMM
• Replace the jet direct card
• Replace formatter board
• Replace engine board
95% of the time it is a PDF that has a font that is not recognized by the printer! If the error is not there when you follow the above, you may have to clear out the print queue.
Apr 23, 2010 | HP LaserJet 2300 Printer
Ink cartridges cannot be recognized in canon printer
Hello!
Remove the cartridges and gently wipe the cartridge contacts with a dry cloth, then put them back in. Then, hold the "resume" button for 10 seconds for each cartridge, that should reset them.
If that doesn't work, one of your cartridges (sadly) needs to be replaced.
Apr 15, 2009 | Canon PIXMA iP1300 Printer
Kodak ESP 3 Multifunction Printer/ Copier/ Scanner Logo
219 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
