Question about Nikon COOLPIX L4 Digital Camera
Flash not operating
Can you help me figure out why my flash won't engage on my Coolpix L4 camera?
Re: Flash not operating
Factory fault take it in to any nikon dealers
Posted on Dec 03, 2007
0 characters
3 Points
I have a Nixon Coolpix L4. And I am trying to figure out how to turn the flash off. I have the manual but it is all in spanish. Which I am not at all good at. Please tell me how to turn my flash off....
Press the flash mode button the icon above OK and select off,
I have posted a site where you can get the ENGLISH manual in pdf,
Good Luck
Aug 10, 2010 | Nikon COOLPIX L4 Digital Camera
Falash are not comming
If the flash dpes not work in auto mode at night time then its confirm the flash tube/bulb is cut or damaged. Just replace the flash tube then it will start working.
Jul 19, 2010 | Nikon COOLPIX L4 Digital Camera
Flash does noy work
First try with new batteries as power received will be less as the batteries gets older and so flashes might not be working well.
If you still face the same problem even after changing the batteries, then there is a problem with flash lamp.
Hope this helps.
Jan 31, 2010 | Nikon COOLPIX L4 Digital Camera
Can't change flash setting in auto mode. (Nikon
Hi Dear,
You cannot change the settings of flash in auto mode. To change the flash settings you need to keep your camera in programmable mode or manual mode so that you can change the flash settings.
Hope this will help you. If you have more queries on the same. Please do write to us again.
Have a nice day.
Nov 11, 2009 | Nikon COOLPIX L4 Digital Camera
How do you turn off the flash?????Nikon coolpix L4
Press flash mode button and highlight flash off, then press OK.
More details see manual on page 18.
Here is the link of the manual Coolpix L4 User’s Manual
Aug 01, 2009 | Nikon COOLPIX L4 Digital Camera
Nikkon Coolpix L4
Blown bulb or charging TRX.
Needs service.
Mar 18, 2009 | Nikon COOLPIX L4 Digital Camera
Flash inop
It is either the capacitor, which stores the electric energy for the flash; or the flash bulb itself.
Be careful with diy. If the capacitor is ok, it will give you a nasty shock when you touch the contacts. It is very dangerous and could cause serious injury.
Mar 01, 2009 | Nikon COOLPIX L4 Digital Camera
Nikon Coolpix L4 flash not working
This has happened to mine a couple of times. I cannot select flash, and the blur indicator is on most of the time.
Solution is to go into 'menu', select 'SET UP' then 'reset all'. My flash selection then works again.
Since one doesn't tend to set much up with a basic camera like this, resetting shouldn't cause any issues.
Hope this helps
Mar 31, 2008 | Nikon COOLPIX L4 Digital Camera
Lens error
If you cannot find a solution to your problem you may want to email He has good advice and good used parts at a fair price.
Oct 13, 2007 | Nikon COOLPIX L4 Digital Camera
Nikon COOLPIX L4 Digital Camera Logo
118 people viewed this question
Top Nikon Digital Cameras Experts
Are you a Nikon Digital Camera Expert? Answer questions, earn points and help others
