Question about Refrigerators
I have a GE Hotpoint Side by Side refrigerator Model #HSM25GFRA SA and have a problem with the water dispenser. I've switched out the filter with two new ones but still have the same problem - no water comes out. However, my ice dispenser is working just fine. What should I do?
  • 55 Answers
Alot of the GE refrigerators have problems like this. You either need to replace water valve on the back because one of the valves has stopped working OR the tube in the door has frozen and the door will need to be replaced. The best way to tell is remove the hinge cap on the bottom hinge and disconnect the little adapter put a towel down there and then trigger the water dispenser. If water comes out, the tube is frozen in the door. If not, replace the valve.
Posted on Jul 15, 2009
  • jesexton45
    jesexton45 Mar 27, 2013
    Thank you for the info. I believe that the Ice despenser fills from the back, we can get water out of the door.
I have a GE Hot Point refrigerator Mod# GSX24GRXA side freezer.
It would put water in the ice dispenser then a few minutes later it would do it again to where it would over flow.
I shut it off and cleaned out the ice and now it wont pump water up to the ice dispenser but it will still dispense water out of the door.
any ideas?
Posted on Mar 27, 2013
    Problem Solver:
  • 14 Answers
If the water is frozen in the door (test as AppKing recommends) then there is a simple fix for it. GE has released a water line heater that keeps it from freezing. It is only $30 and fairly easy to install. More info here.
Posted on Dec 13, 2010
2 Suggested Answers
SOURCE: I have a Hotpoint side by side refrigerator, model
probably the water solenoid. it will be in the back lower area. follow the tubing to the vavle
Posted on Aug 08, 2009
Have a Hotpoint model HSM25GFRA SA Ice maker stopped did some checking ond found the water solinoid to ice maker was open and replaced it. But still no ice, have removed ice maker, cleaned and defrost
Check to see if there is ice blocking the tube to the icemaker. Sometimes when the valve is giong bad or the icemaker sits too long without making ice the tube will freeze and block up with ice.
Feb 14, 2014 | Hotpoint HSS25GFP Side by Side...
Hotpoint HSS25GFT 25.0 Cu. Ft. Side-by-Side Refrigerator with GE SmartWater Filtration, LightTouch Problem: Water continually drips from water dispenser spout
Should be the water valve in the back. Over time the seals break down our debre in water will cause to leak. Sometimes new water filters will also cause small issues but shouldn't last long.
Aug 18, 2012 | Hotpoint HSS25GFT 25.0 Cu. Ft....
I have a Hot Point refrigerator model No. HSS25GFTA WW. I changed the filter but water still not coming out of the despencer, every thing else is working normal.
Sometimes you will need to purge the air out of the line after changing the filter. Just hold down the water dispenser for a few seconds every hour or so.
Jan 30, 2012 | Hotpoint HSS25GFT 25.0 Cu. Ft....
I have a hotpoint model no. HSM25GFRA SA serial no. HG224745, i have replaced the defrost heater but the refidgerator started getting warm again. purchased the thermostat but the guy said it may be the...
If you meant the deffrsot timer it is normally kept at the bottom near to the compressor unit, check for wiring to the heaters and the compressor cut off relay.
Oct 27, 2011 | Hotpoint HSS25GFP Side by Side...
Have a GE Fridge Hotpoint Model HSS25GFPJWW The ice make, makes ice but the water dispenser (to fill a class) doesn't work. Replaced the filter and it still doesn't work, in Oct 09 it the same thing...
i would ck the water valve . this is a dual valve in the back one side may have burned out and is not opening to let water in one side is for icemker and other for foutain . and also ck the water line inside freshfood see if its frozen. ( if themp is too cold in fresh food side it will freeze . should be about 38 deg .. hope this helps mm
Jan 20, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Divider between side by side compartments hot
The area arond where the seals is heated to stop the seal getting damp and mouldy.
Apr 17, 2010 | Hotpoint (HSM25IFTSA) Side by Side...
Hotpoint ice/water dispenser will dispense ice but not water
You may have a blocked filter. Has this even been changed since you have hook-up the water line, or did you recently just install a new filter. If so it may not be in right correctly. try removing it and reinstalling it.
Mar 13, 2010 | Hotpoint HSS25GFP Side by Side...
I have a side by side Hotpoint model #HSS251FMD.The water dispenser stopped. Replaced filter and now no water or ice.
sounds like the water inlet valve is not letting the water come in. need to check and perhaps replace this valve. hope this helps.
Oct 13, 2009 | Hotpoint HSS25GFT 25.0 Cu. Ft....
Refrigerators Logo
391 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
