Sibyl Eaves Posted on Feb 13, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Model cmt-ex1. how can I set the clock without remote?
Paul
Level 2:
Passionate:
Visited the website for 10 consecutive days.
Habit-Forming:
  • Expert 73 Answers
  • Posted on Feb 14, 2016
Paul
Expert
Level 2:
Passionate:
Habit-Forming:
Answers
73
Questions
0
Helped
16115
Points
401
Here are a couple of links to the manuals, maybe you can find your answer in the operating manual:
Support for CMT EX1 Sony
http://pdf.crse.com/manuals/3867450151.pdf
Set time on sonymp3 cmt-bx20i
You need to use buttons on the remote to set the clock.
1.Turn on the system.
2.To select the clock set mode press TIMER MENU. If the current mode appears on the display, press up and/or down to select
"CLOCK SET?" and then press (+)
3.To set the time. Press up and/or down to set the hour, and then press (+) to confirm. Repeat to set minutes.
The clock needs to be re-set whenever power is lost to the unit.
The clock can be momentarily displayed when the system is off by pressing DISPLAY. The clock is then displayed for about 8
seconds.
The full support section with manual downloads is available here for further help and guidance:
http://esupport.sony.com/US/p/model-home.pl?mdl=CMTBX20I
Hope this is of help.
How to set the clock
You will need your original remote to set the time, and other functions that are not evident on the front panel.
3helpful
How do you change functions to get to the audi in function
Press the FUNCTION button on the RM-SC30 remote that should have been included with your Sony CMT-NEZ3.I have not found a way to select Audio In without the remote. See http://esupport.sony.com/US/perl/model-home.pl?mdl=CMTNEZ3 to download your manual.
6helpful
4answers
Change input to Aux In without remote CMT-NEZ3 Sony
I have not found a way to select Audio In without the remote (and I've tried every combination of buttons I can think of!)
The approved way to select Audio In is to press the FUNCTION button on the RM-SC30 remote that should have been included with your Sony CMT-NEZ3. See http://esupport.sony.com/US/perl/model-home.pl?mdl=CMTNEZ3 to download your manual.
3helpful
Help - CD won't eject! I press 'Open' on my sony CMT-EX1 system and the CD moves backwards as though it's going to eject but then it stays there, unreachable. Then the display begins to switch between...
I have the same problem and it's due to dirt!
I'm going to try using compressed air, but -
this definitely works:
:) Seriously:
tilt the cd player to a 45 degree angle (flat, basically - as if they tray were horizontal.)
I had my player for 10 or 12 years, and this problem is only coming up now. My house gets very dusty.
Also - vertical load disc players are hard to clean. X_X (inside the disc tray)
I love this stereo too!
I don't want to have to go out and buy another stereo!
4helpful
2answers
Need remote for sony cmt-ex1 any one help pleas 1st time on
Parts store shows this remote as #141861411 but not avail. MCM Electronics has that part number as 1-418-614-11 (RM-SCEX1) under thier order number 32-20405 for $13.80. You may wish to consult your owners manual to verify the number of the orig remote provided before ordering just to be sure.
Can I connect my computer to my Sony CMT-EX1 CD
stereo headphone jack from pc through to AUX, if on your system, via twp rca plugs
Sony cmt-ex1 CD verical loader
If your two speakers are working,if ok ,then the problem is in power amp section ,the IC chip there is already defected .changed that IC so it works normal again and some reheating works in power amp.section...
rate me as FIXYA
Laser does not read cd. says no disk therefore cd will not start spinning to pay
has bad tray cd rom would be hard to get this part also is it under warenty can u return it
Tv switches source channel without warning
Hi Andy.
What is the samsung model number ?
http://dysonmanuals.llc.nu/
Chris...
 Grubhead
Grubhead
SmartAviator
SmartAviator
