Question about Whirlpool LSR5132PQ Top Load Washer
Washer drains water immediately - Whirlpool LSR5132PQ Top Load Washer
    President:
  • 1,136 Answers
Hi, Does the water drain while the washer is filling? If so, check the end of the drain hose and make sure it is as high as the top of the washer.
If this is not your problem, Please let me know to clarify what is happening.
Thanks
Vic
Posted on Jul 15, 2009
On Maytag top loader, water enters but drains immediately.
check that the drain hose is above tub level
check for faulty program board engaging the pump all the time
Sep 20, 2016 | Maytag PAV2300 Top Load Washer
Washer fills then drains immediately
Motor plug faulty. Remove and check for burnt wires.
Dec 08, 2013 | Zanussi ZWF1430W Front Load Washer
I have a whirlpool ultimate care II washer. When I start the washer, water pours in but does not fill up the washer. The water immediately drains away. Its not leaking out of the washer. I think the...
This issue calls siphoning effect. It happens when the drain hose was somehow lower or not stand vertically. It causes no air pressure column in the drain hose to keep the water out. Check the drain hose and make sure it is high enough. Try to hold the drain hose straight up and see if it is happened before having further inspection.
Oct 05, 2013 | Whirlpool Ultimate Care II LSQ9564J Top...
Will not hold water ,when filling it just drains out
I just had this problem also. The reason I was having this problem was that I was letting the draining hose run into my bath tub to drain. Because of this the water was immediately draining out of the washer. So I had to hook the draining hose onto my bathroom sink to drain. By raising the hose higher,the washer filled up with water and worked just fine. Hope this helps.
Jan 24, 2010 | Haier HLP21E Top Load Washer
I have a Kenmore N2. What would make my front load washer fill back up with some water after the drain and spin cycle is complete?? IF I let the washer go until it's done and go downstairs to take out,...
first, run a rinse,drain & spin cycle. after it finishes filling, shut the water supply (taps) off. If water enters the washer after the drain, it has to be sifoning back in from the DRAIN hose. Check to see if the drain hose is not going up above the washer more than a few inches
Dec 03, 2009 | Kenmore Washing Machines
Water pours from drain hose overflow in front of washer
That drain hose in front has a stopper, to prevent discharge. Either it is not there or not tight or something. You can always clog it shut with a round wood bit inserted or something........I don't think it is too difficult.
May 08, 2009 | LG WM0001HTMA Front Load Washer
Maytag Performa washer immediately drains water out of the bottom
owww. you d have to remove the front panel to see what hose has split or perhaps the door boot has developed a tear. sure it will be quite obvious as to where wate ris coming form after removing the front panlel
Oct 30, 2008 | Maytag Neptune MAH5500B Front Load Washer
Repair man says washer hose must be off ground for proper draining
yes drain should be at least 36 inches from floorif hose outlet falls below water height in tub water will siphon out faster than it runs in try installing 1 and quarter diameter pipe into floor drain and dropping end of hose into it
Apr 30, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
LAV3600AAW Maytag Top Loading Washer
check your house drain make sure it is above water line in tub
Nov 30, 2007 | Maytag SAV5710 Top Load Washer
Washer won't fill up
The problem is most likely your drain. If there is no air break at the drain,( a gap where the hose goes into the pipe so air can enter) Your water will siphon out of the machine. Also make sure your drain pipe is higher than the tub of your washer and you only want about 6 inches of the drain hose sticking into the pipe. If you have water coming back out of the pipe when the machine drains, you will need a plumber to clean the pipes or replumb the drain. New washers pump out faster than older ones did and they need a good drain to handle the flow.
Sep 26, 2007 | Maytag PAV2300 Top Load Washer
Whirlpool LSR5132PQ Top Load Washer Logo
121 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
