Question about Vocopro MEDIA-JUKEBOX 40 GB Digital Media Player ()
Vocopro Media Jukebox problems
My friend has been trying to copy the cd and cdg files on his pc to a Vocopro Media Jukebox and is having problems. He is using the old copy and paste method, and the operation starts as it should, but after 50 or 60 songs, he gets an error message, the f: drive (the vocopro) path disappears and everything stops. It says that the device cannot be found. Then, if you disconnect and reconnect the Vocopro, the 50 songs show up in the Jukebox. If you try to continues and copy and paste again (choosing the option to merge the contents of c: and f the same things happen...........an additional 50 or 60 songs, an error message and the Vocopro path vanishes. This can go on endlessly and I'm ready to tear my hair out trying to help him. He's got thousands of songs, so 50 or 60 at a time isn't going to cut it. He says that several people have had the same problem when trying to help him and by the way, it has happened with two different Vocopros and two different laptops! Freaky, no? He is using HP desktops running Vista. Please help
I Computers running Windows Vista are not compatible.
Posted on Sep 04, 2009
Only de right side of the cd player worrkin
because the problem is due to spark while switching cables of any kind the inside of your cd player damage and the solution is that ,take the player to any person in the market that can make it right.
Feb 06, 2011 | Vocopro CDG-8000 PRO
Tray's sticking on vocopro 8000 pro
Sounds like belts are slipping under tray. They can be cleaned or replaced or new ones of course.
Dec 23, 2007 | Vocopro CDG-8000 Professional Dual CD/CDG...
Philips gogear Ariaz manual
quick-start guide:
http://download.p4c.philips.com/files/s/sa2ara16k_37/sa2ara16k_37_qsg_aen.pdf
user manual:
http://download.p4c.philips.com/files/s/sa2ara16k_37/sa2ara16k_37_dfu_aen.pdf
Dec 28, 2010 | Vocopro Media Jukebox 40 Gig Media Player...
Not showing folders when conected to television but shows them on pc.
Your partition probably has unallocated space before the main partition (usually a tiny bit like 8mb). This will cause an empty menu. Use mini-tool partition wizard home (free) and delete the partition (backup files first!). Then create a new partition with FAT32 setting and change the 'Partition Align To' setting to 'MB'. This will make sure no unallocated space is created. Apply the settings and your done!. Make sure you DRAG your whole folder onto the drive instead of copy/paste. This will ensure your files are copied in the same order they appear in your folder on the PC. The jukebox is finicky about that.
May 10, 2010 | Vocopro MEDIA-JUKEBOX 40 GB Digital Media...
Will only play certain cd's. works great with the
try clean-it with cd drive cleaner kit. available on professional audio\video stores
Feb 21, 2010 | Vocopro CDG-8800 PRO
On my Yamaha CDC-625, I can push the open/close button or the playxchange button, but the changer door will not open. It sounds like a motor is trying to open it, but nothing. Pushing the button again...
The most common problem is a slipping belt.
You have to open-up the player to check it.
If you're not familiar with it, then please don't.
It's not such a big problem, look for a local repairshop.
HNY, Gerard
Jan 01, 2010 | Vocopro CDG-8000 Professional Dual CD/CDG...
How do I get NERO to burn a (cd+g)?
Nero won't burn a cd+g file as the burner does not recognize the file type.
You need a program called mp3+gToolz its free, get it here>>>
http://www.activeaspsoftware.net/default.aspx?p=downloads
You need microsoft.NET framework from windows update withmp3+gtoolz you can convert your mp3 and cdg files into a bin file youthen need a program called cdrwin you get it from www.goldenhawk.comits not expensive but its free to copy at 1X speed you then have to runcdrwin select everything to cdg then load you bin files and record yourtracks you must have a cdg compatible burner but it will let you knowif you haven't.
Good luck.
Sep 10, 2009 | Ahead Software Nero 6 Ultra Edition...
Elio Jukebox Media Manager
ok do one thing try it to do in ITUNES . connect your juke box and try to open it in ITUNES it can dowloaded for free in www.apple.com
Sep 07, 2008 | Tatung Elio Photo JukeBox MP3 Player
Elio Photojukebox 810 Image not found - No operating system
Sorry it wasn't the Elio Jukebox with 20 GB, it was the Elio Jukebox with 4 GB.
And yes it's solved. I copied the files from a second Elio on it. Not the files from the CD!!! You must copy the files from a working unit. It works with mine. If you need the files - I can mail it to you. I am from Germany but after you copied the files you can change the language from German to English on the player menue.
Apr 10, 2008 | Tatung Elio Photo JukeBox MP3 Player
Cd tray doors won't open
Check mechanics on CD door for dirt, or any loosen screws.
Oct 01, 2007 | Vocopro CDG-8000 Professional Dual CD/CDG...
Open Questions:
See all Vocopro MEDIA-JUKEBOX 40 GB Digital Media Player Questions
Vocopro MEDIA-JUKEBOX 40 GB Digital Media Player () Logo
256 people viewed this question
Top Vocopro Audio Players & Recorders Experts
 Grubhead
Grubhead
Andrew Taylor
Andrew Taylor
Gil Shultz
Are you a Vocopro Audio Player and Recorder Expert? Answer questions, earn points and help others
