Question about Sony STYLEPRO SDM-S91 19" LCD Monitor
Screem Comes on brefly and then fades to black
Monitor working but fades to black after a few seconds.
    Problem Solver:
  • 18 Answers
Go to control panel and click on screem after click on screem saver select none or try configurate to more time for to active the screem saver, and if it is not that you must take it to a technician
Posted on Jul 15, 2009
I have a acer.x223w when,it powers up the.screem stays black, n i get a blue blinking light on.the bottom
I disagree with ikkenom only due to the symptom of the flashing blue light. This would indicate to me that the monitor is not getting any display signal and is in sleep mode at least the is what happens on my Samsung monitor. Used to be that they use a two color led in the monitor, green when ON and getting display signal and amber or orange when in sleep mode. I would check the computer by trying a different monitor. If you have a second monitor, great, if not, maybe a friend will let you bring your computer over and try the computer with their monitor. Could also be a display adapter setting. Do you get any change when you first turn on your computer? i.e. Do you get the BIOS or manufacturer screen when first turned on? Also if you disconnect the monitor cable from the computer and power cycle the monitor, do you get a No Signal display for a few seconds before the monitor goes black and the blue light starts flashing?
Let me know what happens with the testing above or if you need further instructions to carry out testing.
Thanks, Jim
Feb 21, 2013 | Computers & Internet
The monitor fades to black, a few seconds after I turn the pc on (even before starting windows); the blue button keeps on. When I turn it off, and then turn it on again, it works for a few seconds, then it...
Simplest solution first; check your cables. If the connections are good, but it still doesn't work, try your monitor with another computer. If it works, you need to update the drivers on your computer. If it doesn't, the problem is with the monitor. If your computer needs drivers from LG for the monitor, you need access to another computer (or another monitor to go online). Go to LG's website and look for SUPPORT. Download drivers for your monitor specific to your operating system (Windows, Mac OSX, etc.) and install.
Mar 02, 2011 | LG W2252TQ Monitor
My Soyo 19" TFT monitor Model:MT-NI-DYLM1998 comes on at power up but goes black after a few seconds. But on repeating turning power off then on again, the monitor comes on and then goes black again after...
Thank you for answering those questions. That usually indicates it has a bad power inverter. From what i can tell, that monitor is a few years old. You can attempt to find an inverter online to replace it yourself (usually about $50 if you can find one) since its no longer covered under warranty, or put that money into getting a new monitor.
Sep 06, 2010 | Soyo DYLM24D6 LCD Monitor
My AOC screen goes black after about a few seconds after booting.
The picture board on your monitor is bad, since it goes off after few seconds and the power led or button is on, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer or service center within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Jul 26, 2010 | AOC LM729 17" LCD Monitor
After an hour or more monitor fades to black
it comes down to luck really and seems like you havent had any try getting a cheep dell 19 ince they seem to be bulet proof
Jul 10, 2010 | E-Machines T5010 PC Desktop
My monitor comes on for about three seconds when I turn the computer or the monitor off/on and then it fades to black. It looks like the computer is booting up fine when I can briefly see the screen but...
Connect the monitor to the "video-output" port on your laptop, to see if the monitor is working correctly.
You make have to tell the laptop to send the video-output to "both" the internal LCD screen and the external monitor.
If it works, then your monitor is OK.
Restart your computer, and keep tapping the F8 key, until you get a menu of startup items. Choose the 'VGA' startup option, to select the "minimal" device-drivers for your video-card. With the "minimal" drivers, your monitor should still be working.
May 31, 2010 | Computers & Internet
Monitor comes up in color then fades to black and white. Bad video card or bad monitor or what?
Connect the monitor to a different desktop/laptop, and see if it still "fades". If it does, the monitor is the problem.
Connect a different monitor to your computer,
and see if it still "fades". If it does, the video-card is the problem.
Jan 29, 2010 | Electronics - Others
My screen goes black after a few seconds
Sounds like a bad solder joint on the printed circuit board. Once it heats up then it no longer makes good contact and the monitor goes black until it cools down and makes contact again. You could resolder it if you knew where it was but monitors are dangerous to go playing around with as they can hold very high charges of electricity in their capacitors that are very dangerous. It's a throw away world. Go buy a new one.
Jun 02, 2009 | Gateway FPD 1750 17" Flat Panel LCD...
Syncmaster 226bw goes black
i think u have a problem with ur display,please contact ur service centre immediately to fix it.
Aug 16, 2008 | Gateway FPD2275W LCD Monitor
Radio frequency fades after few seconds
your headset wires are the antenna of your phone... be sure to let it loose freely to avoid the frequency fading... dont fold it...
Oct 27, 2007 | Sony Ericsson Walkman W810i Cellular Phone
Sony STYLEPRO SDM-S91 19" LCD Monitor Logo
164 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
