Question about Gard Aquascape Black Waterfall Foam Accessories for Water en, Stream, Pond Use
Black coating on rocks (biofilm?)
I get an unsightly build-up of a black coating on all the rock surfaces.
If I shut the water off the coating dries up and some of it peels off.
any suggestions on how to prevent this
How to. Repair hole in plasterboard.
If the hole is small, use a lightweight filler, applying with a palette knife. If hole is larger or has broken edges, cut out the damaged piece and cut a new piece (hardware store) and glue in position (PVA glue is fine) when dry, fill join with lightweight filler.
Paint over when dry.
Apr 06, 2016 | Miscellaneous
How do sedimentary rocks form
from mineral sedament . suspended in water deposited over time (lots of time)
Mar 05, 2015 | ROCK Home Security
Rocks have turned brown - is there a cleaning solution to remove the build-up?
outside adornments that turn colour do so from the water used. It is normally a higher than normal iron content in the water or surrounding soil. Try spraying the rocks with CLR and leaving for a time to work
Dec 14, 2014 | Cars & Trucks
Can you tell me about anIgneous rock
Igneous rock is formed through the cooling and solidification of magma or lava. Igneous rock may form with or without crystallization, either below the surface as intrusive (plutonic) rocks or on the surface as extrusive (volcanic) rocks.
Aug 25, 2014 | Furniture
How do volcanoes erupt
Very simply: There s a layer of melted rock, called magma, below the Earth\'s surface. That magma is under tremendous pressure from gasses created when the rock melts, from the growth of the rock when it melts, and from the melting of other rock around it. When the pressure on the magma gets high enough, some part of the "pipe" it\'s in - that is the Earth\'s surface - breaks and the magma bursts out. As it escapes it cools, forming a mound. That mound is a volcano.
Jun 20, 2014 | Computers & Internet
Need to remove sticky residue from rock saw interior
I would use some sort of degrease product in the system to remove the oil residue . I believe that if you read the instructions it would say when cutting rock use only water to cool the diamond blade . Cutting oil is used only on certain metals to lubricate the saw edges and teeth as well as cooling and never in a concentration above 25% as it affects the cutting ability of the blade. For example concrete cutters use diamond saws and tap water when cutting
Mar 09, 2014 | Cars & Trucks
What are the classification of rocks and please describe briefly each. thank you
Making up the majority of the Earth's crust, rock is usually defined as a mixture of common minerals.
Rocks can be hard or soft, as small as a grain or as large as a building. They have been an integral part of the history of mankind, first being used as tools for hunting and defense, and as a building materials to construct shelters and monuments.
Combined with the effects of tectonics, weathering and vegetation, rocks define the natural landscapes we see around us. The minerals and metals we find in rocks are essential to the prosperity and cultural splendor of human civilization.
There are many kinds of rock, and they can be classified in a number of ways. However, geologists classify rocks based on how the rocks were formed. The three classes are:
1) igneous rocks (formed directly from liquid rock),
2) metamorphic rocks (formed by direct alteration of existing rocks), and
3) sedimentary rocks (formed by eroded materials from other rocks).
Feb 05, 2011 | Computers & Internet
The wall has a big hole its a sheetrod wall but i want repair the hole instead of remving the sheetrod.
square up the hole screw some wood to the back of the sheetrock where you can attach a new piece of rock all along the seams be sure to set the heads of the screws slightly mud the seams take a sheet rock knife and press the tape into the mud remove air bubbles let dry apply second coat let dry sand smooth not down to tape apply third coat let dry sand and paint
May 20, 2010 | Garden
Briggs & Stratton Stator Rusting preventing Lawn Tractor from starting. Took Engine apart after one month of having Sears replace the Stator and in the ''no start'' condition the Stator had quite a bit...
After a thorough cleaning, seal the surfaces that are exposed with Acrylic Automotive Top Coat or "Clear Coat". The acrylic base dries to a rock hard finish that is diaelectric in nature and will protect the surfaces it bonds to. Regap from flywheel as normal and this should fix it for two, three years if the machine lives under a tarp in the elements. :D
May 09, 2010 | Briggs & Stratton 50-Amp Automatic...
Build up of rock solid substance under engine cover
this is called black death, you have an injector seal gone on one or more injectors, the tar stubstance is diesel, injector seals need replacing.
Jul 06, 2009 | 1999 Mercedes-Benz E-Class
Gard Aquascape Black Waterfall Foam Accessories for Water en, Stream, Pond Use Logo
44 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
