Question about Buffalo Technology WHR-G54S Wireless Router (WHR2G54S)
Lost connection to you. I ran the utility and it didn't recognize the router. I can only connedt on the cable, not through the wireless.
  • 60 Answers
Make sure that the wireless light on the router is lit
can you see your network name in the available network?
try changing the channel if still not working
what are your wireless settings?
What is the OS?
Posted on Jul 16, 2009
Linksys router not recognize internet
Make sure your router's WAN port is set to dynamic IP. If the light on the front doesn't glow/blink for the WAN port, try a different cable. If a different cable doesn't work it's probably toast. :( This problem appears to be directly linked to the relationship between the WAN port and the modem. Given that the devices can connect to the router, but not internet, it has to be the WAN. Sometimes if the modem goes out it will send too much voltage through to the router and fry the WAN. Had that happen to my parents router. If the above doesn't "fix ya" then try a different router.
Worst case, you might have to put a wireless card in your PC and bridge the modem (wired connection) to the wireless card and broadcast for your wireless devices. At least until you get a new router.
Aug 02, 2013 | Dell Computers & Internet
Wireless connection isn't recognized
Please log into the admin panel of the Wireless router and see it the option for Broadcast has been enabled. If not check the box, save the settings and reload the router. You will then see the name being broadcasted.
Please rate if helpful.
Thanks
May 24, 2010 | D-Link 802.11g Wireless Router WBR-1310...
Just replaced Netgear WebSafe router with Linksys WRT400N. Now, can't "see" printer in network nor can access it to change settings (or print). Have tried with ethernet cable straight to router and through...
Reset printer to factory settings according to manual. Plugged in ethernet cable directly to router. Ran BRAdmin which recognized printer and saw that IP address had been automatically set within new router range. Changed setting to STATIC. Deleted old printer definition from printer list and added updated definition using Printer Setup Utility. Printed test page from BRAdmin. Also printed file from Documents folder wirelessly. Changed printer settings in another laptop & was able to print wirelessly from there as well.
Jan 07, 2010 | Brother HL-2070N Laser Printer
Lost ip/connection on Dell 1720dn
try resetting the "print spooler"
  1. start
  2. control panel
  3. admin. tools
  4. computer management
  5. services and applications
  6. services
  7. scroll down till you see "print spooler"
  8. left click once
  9. "restart"
Jan 06, 2010 | Dell 1720dn Laser Printer
I can not connect to my dlink when using other laptops. The other laptops recognize the wireless but can not connect. What can I do so that I can utilize other laptops on my wireless dlink?
since your laptops recognize the network, you need to access the wireless utility (windows or the one that you're using) to configure the connection. you may have to type in the passkey for the network if you're using one.
Oct 01, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
I have successfully connected my belkin wireless router and have been able to use my laptop in the past. i have HP 2000 and updated it with windows xp. since then i cannot connedt to the internet. it says...
make sure you have the proper network adapter or you have installed it. You can install the driver here: http://welcome.hp.com/country/ca/en/welcome.html#Support there, look for your hp model and then look for network adapters or wireless lAN.
Jun 15, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Not recognized by cable modem
Turn everything off for 2 minutes, cable modem, router and pc.
Turn on modem and wait 2 minutes for the modem to sync to TW.
Turn on router after 2 mins and wait until the router syncs with the modem.
Turn on PC
It sounds like your router lost its connection to the cable modem, which happens from time to time. TW will not help with your router. I worked for a cable co and the router and modem losing sync was the at least 70% of the calls. FYI cable doesn't use DSL,just the phone co.
May 19, 2009 | Zoom X6 Adsl Modem/router Rohs...
The Computer doesn't recognize the Router (And Yes. the wireless switch is turned on)
DON'T use the software.
Are you trying to connect by way of ethernet cable or wireless?
Either way you do it, you do NOT need that crap software. 90% of the time, that software interferes with everything. Up to AND INCLUDING preventing your system from connecting to the router.
Before you can get any help with this, you will need to give us more information about your setup.
NOTE: We CAN NOT POSSIBLY figure out all of the variables if you do not give them to us. So don't go marking my post as "Thanks for trying" just because your problem is not solved in the first post.
Instead, if you want answers, you're going to have to be more specific.
I see a Linksys WRT54G wireless router. Is there a version number on there?
Example: WRT54G v3 (Mine.)
You're also going to have to tell us more about your computer. Is it Windows XP? Service Pack 1/2? Windows Vista? Linux even? (Give model numbers if it's a pre-built system from an OEM manufacturer such as HP, Dell, etc.)
Then there's the internet connection. Cable internet? DSL? Satellite? Give us MODEL NUMBERS of the equipment they have issued to you for your internet connection.
Then tell us how you have things connected. Wireless? Ethernet cable? What is connected to what?
See what I mean?
FULL details bring quicker resolution of your problem. I will be monitoring this post as you seem capable of providing this information to us. When I see more complete information, I will help you further from there.
Thanks. :)
Cyryl
Nov 21, 2007 | Linksys Wireless-G WRT54G Router
Buffalo Technology WHR-G54S Wireless Router (WHR2G54S) Logo
41 people viewed this question
Top Buffalo Technology Computers & Internet Experts
Prashant M
Prashant M
hellics
Level 1 Expert
Are you a Buffalo Technology Computer and Internet Expert? Answer questions, earn points and help others
