Question about Tape Decks
Teac a1500U reel-to-reel
How do you get a new belt on the drive wheel and capstan wheel once you've opened the deck without completely dismantling the unit? There's gotta be a way without removing the heads, for crying out loud!
  • 319 Answers
SOURCE: How to change belt in teac x1000r reel to reel tape deck
If you are not familiar with such work, I don't recommend trying to install belt(s). Replacing belts may involve disassembly of mechanism parts and critical adjustments to follow. Take to a pro/tech
Posted on Apr 23, 2008
SOURCE: TEAC X1000R Stereo Tape Desk (reel to reel)
usually its a capstan drive belt. $10-18 for the belt & 30mins repair time - you'll be up &brunnin b4 you know it
Posted on Jun 20, 2008
  • 4518 Answers
SOURCE: belt change for Teac a4010sl reel to reel
You can but try! However either make a drawing of how the thing fits together or better still take pictures if you have a digital camera. Then you will know how it fitted together.
Posted on Mar 23, 2009
  • 141 Answers
SOURCE: I have a TEAC reel to reel stereo tape deck, Model
That's a rarity but easily fixed. Before pulling anything apart spray some penetrating oil (WD-40) or similar into a small container. Then with a cotton bud soak the tip in the penetrating oil and apply it to the base of the capstan where the bearing is. Allow this to sit for a few hours and even repeat it if it looks to have soaked the oil up. NOW, with the power lead out of the wall socket remove the top cover of the deck. You will have to remove a few knobs and mode switches too. Now see if you can rotate the capstan flywheel by hand. It might take a bit of pressure to get it to turn but once it does keep going until it starts to rotate freely.
By the way, check that the capstan drive belt is in one piece and not slipping first.
If it's running freely then reassemble the cover and other pieces tyhen put a few drops of light oil on the capstan bearing (sewing machine oil is ideal) Do this because penetrating oil will dry out after a while. That should fix it.
I'm assuming you know exactly how to thread the tape through the machine. Don't forget to position the stop lever on the upper side of the tape otherwise nothing will operate. If you are unsure about that write back and I will elaborate.
Posted on Apr 24, 2010
  • 222 Answers
SOURCE: I have a Teac a-1250 Stereo Tape Deck. When I try
Replade the capstan belt you can buy it @
Posted on Jun 06, 2010
  • 4518 Answers
SOURCE: I need a capstan drive
Just measure the diameter in MM and put the result into google with the words 'cassette drive belt'. Belts are not maker specfic.
Posted on Nov 06, 2010
0 characters
1 Points
Why don't tape decks play?
If your X-10 has a separate drive motor for the capstan , it could be weak and in need of replacement.
The C-3X could have belt drive and the belts could be weak and in need of replacement.
Jan 03, 2016 | Teac Tape Decks
Teac a-3440 will not play
Hi Gary,
This makes me think the Capstan Shaft is not turning either due to a broken or stretched belt or that the capstan motor itself has stopped working. This may be a job for a Technician. You first determine if the Capstan is turning or not- this is the metal post that contacts the Pinch Roller that rotates and is the way the deck gets it's speed regulation. If it is not turning look inside the deck from the side to see if the flywheel is turning and that the belt is on that flywheel. Lastly make sure the capstan motor is turning.
Beyond that a Tech may have to take over from there. I am in the Chicago area and can repair it if you are close. Many people send me units from all over the USA anyway.
My name is Sam. I operate Skywave Tape Deck Repair if you need my help.
Aug 17, 2012 | Teac Tape Decks
Thaks for helping. My tape deck door has suddenly stopped working. the tape is inside and when i turn on the wpower there is a clicking sound. it is a TEAC AD-500 CD player/reverse cassete deck
Without physically looking at the cassette deck myself, I cannot be 100% sure the tape is wrapped around the pinch roller and capstan. The capstan is the chrome rod which the rubber pinch roller pushes to regulate the speed of the tape moving across the head. However it is approximately a 90% chance the take up reel for the tape stopped working from a bad tape or a loose belt which drives the tape take up reel. The clicking sounds like it could be the auto reverse solenoid because it thinks the tape has reached the end of play. The fun part is to remove the tape which you may have to disassemble the front panel if you cannot gain access to the tape from the top or bottom. You will need to cut the tape and remove it from the capstan and pinch roller to open the cassette door. Sometimes you can remove the capstan to free the tape. Once you have cleaned all the tape out of the unit make sure the belt for the take-up is good. If it is glazed, cracked, loose or broken order a belt. Clean all the pulleys and capstan and replace the belt. Your unit should be functional after the above procedure.
Jul 14, 2011 | Teac R-H300 Dual Cassette Deck
I have a Teac A-1500 reel to reel tape recorder and need a drive belt for the capstan, Can you help me?
Contact: He can supply drive belts for Teac reel to reel recorders and other manufacturers units.
Mar 31, 2011 | Teac Tape Decks
Instructions for Teac Tascam 32-2B belt replacement. I have had this Reel to Reel Tape Recorder for a number of years and the belts have now perished. I have purchased replacement belts on ebay but could...
Ebay is the worse place to get belts- why do I know this? Well, as a servicer I am constantly replacing belts that are from E bay when clients can not get their decks to work with those wrong belts. While the counter belt is not critical the capstan belts are in a dual capstan system. The 32-2B is a X10 derivative so it will need proper servicing to work well. I am in the Chicago area and work on decks all the time as Skywave Tape Deck Repair just google it.
Mar 19, 2011 | Teac Tape Decks
I need a capstan drive belt for a TEAC 3440 reel to reel recorder. Wherr can I find one?
Oct 24, 2010 | Teac Tape Decks
My Teac 4070G reel to reel tape deck rewind and fast forward functions work, but the play function does not. Any ideas? Could it be a circuit?
Without actually seeing your Teac reel deck, i suggest you verify that all fuzes in the deck are good..not blown. Also with a tape correctly installed..ensure that left and right tape tension arms are held under tension/ closed by tape tension, also ensure the capstan shaft is rotating... look in back to ensure the capstan drive motor is running.. if yes, and tape still will not play... problem could be a stuck/failed solenoid, dirty or corroded push buttons, or corrosion on contacts where rear circuit boards/plugs insert into other boards.
Feb 28, 2010 | Tape Decks
Nov 24, 2007 | Tape Decks
TEAC model A1500 tape recorder
What i did to solve this problem on my A-1500 was to remove the tension arm, the pinch roller and the front face holding screws , pull off the rubber faces from the reel hubs and remove them, remove the front metal face plate... in back remove the wood backing panel... inside the deck rear, remove, (without letting them fall into the mechanism) 4 screws that anchor the heavy front cast piece that holds the capstan flywheel...carefully lift the cast piece that holds the flywheel. away from the deck face just enough to allow the old belt be removed, and the new one installed...ensure the belt is installed and goes all around the flywheel..and is not pinched when you push the casting back against the deck face and reinstall the 4 rear anchor screws. place the belt around the upper drive motor pulley wheel.. small diameter part on motor pulley and large diameter part on flywheel for users of 60 hz. Ensure 60hz is selected on switch..or 50hz if that is what you need.(for 50hz ensure belt is on large motor pulley part and smaller flywheel diameter part. with deck lying down or leaning, place a few drops of light lube oil into the felt at the bearing hole for the flywheel. Give the deck a test playback before completely reassembling and putting all the parts back where they were.
Nov 18, 2007 | Tape Decks
Tape Decks Logo
Top Tape Decks Experts
Gyula Lacz
Bruce Showalter
Are you a Tape Deck Expert? Answer questions, earn points and help others
