Question about Whirlpool LSR5132PQ Top Load Washer
The water drains out immediately after starting the load.
  • 55 Answers
Hello. You have one of two problems.
1. Your drain hose is too far into the drain causing a constant drain. You will need to pull it out and adjust it to where it is only in the pipe about 6 inches.
2. The hose is in the drain and tape off. If this is the case, you will need to untape it and install a genesis valve. You can get a genesis valve(siphon break) at your local plumbers shop.
Posted on Jul 15, 2009
On Maytag top loader, water enters but drains immediately.
check that the drain hose is above tub level
check for faulty program board engaging the pump all the time
Sep 20, 2016 | Maytag PAV2300 Top Load Washer
Water drain out immediately while filling the washing machine
you should check 2 things the drain pipe should be higher than the drum or there is some dirt in the thin pipe of the pressure switch try to blow air in it in order to clean it
Feb 10, 2014 | Simpson Esprit 750 Top Load 7.5kg
Washer fills then drains immediately
Motor plug faulty. Remove and check for burnt wires.
Dec 08, 2013 | Zanussi ZWF1430W Front Load Washer
I have a whirlpool ultimate care II washer. When I start the washer, water pours in but does not fill up the washer. The water immediately drains away. Its not leaking out of the washer. I think the...
This issue calls siphoning effect. It happens when the drain hose was somehow lower or not stand vertically. It causes no air pressure column in the drain hose to keep the water out. Check the drain hose and make sure it is high enough. Try to hold the drain hose straight up and see if it is happened before having further inspection.
Oct 05, 2013 | Whirlpool Ultimate Care II LSQ9564J Top...
Samsung Washing Machine WA80v3 not working properly
Did the water start without you setting the cycle?
Nov 28, 2012 | Washing Machines
As soon as the machine starts drawing water for the washing cycle it drains the water immediately. Any suggestions?
Yes, make sure the drain hose where it goes into the drain is higher than the console of the machine. Also make sure it only goes 6 to 8 inches down into the drain. I this is already the case, they make a siphon break that goes on the drain hose that will prevent this. you can find one at any appliance parts house.
Dec 21, 2009 | LG WFT1071TP Top Load Washer
Maytag Performa washer immediately drains water out of the bottom
owww. you d have to remove the front panel to see what hose has split or perhaps the door boot has developed a tear. sure it will be quite obvious as to where wate ris coming form after removing the front panlel
Oct 30, 2008 | Maytag Neptune MAH5500B Front Load Washer
LAV3600AAW Maytag Top Loading Washer
check your house drain make sure it is above water line in tub
Nov 30, 2007 | Maytag SAV5710 Top Load Washer
Washer fills and drains repeatedly
Have a look at the routing of your drain hose. It sounds a bit as if: a. The highest point of the hose isn't high enough (you normally want to aim for about 3 feet off the ground) - so that water starts draining from the machine before it is finished filling. and b. There isn't an effective air break or anti-siphon valve where the drain hose goes into the domestic drainage system - so that once the machine starts to drain by itself, it continues until empty. A.
Jun 07, 2007 | GE WJSR2070B Top Load Washer
Whirlpool LSR5132PQ Top Load Washer Logo
54 people viewed this question
Dan Webster
Dan Webster
Sal De
