Question about Whirlpool GC5SHEXNS Side by Side Refrigerator
Bottom of ice maker/dispenser frosting over
The bottom of the ice maker keeps frosting and freezing over. Ice can no longer come out and the door keeps getting stuck on ice maker container due to excess frost and ice. What is the issue?
  • jeffshore Nov 10, 2008
    icemaker frosts over on bottom and onto door chute.
What is the solution?
Posted on Nov 10, 2008
Also; you may want to periodically clean out your chute by removing your bucket. Crushed ice has a tendency to stick to the surface of the chute and build up on its own even if the door is closing properly.
Posted on Dec 10, 2007
  • 290 Answers
Open the freezer door and look down the ice chute while you shine a flashlite up the dispenser cute from the outside. If you see light around the chute door, it needs to be replaced or something is wrong with the mechanism. The problem you describe is almost always air leakage around that flap.
Post back if you need more help.
Posted on Nov 18, 2007
  • Michael  Lindley
    Michael Lindley Nov 22, 2007
    Just wanted to follow up on your fridge and see what you found out.
The ice maker keeps freezing up where the ice comes out of the door on my Frigidaire Refrigerator.
The ice door is probably not shutting tight allowing air in which frost up the door. Inspect the hinges on the ice door. It could be a broken bracket or hinge or the solenoid which operates the door may not be closing it all the way. Remove the dispenser cover by gently prying it off starting at the bottom and then remove the screws to access the other parts.
Dec 22, 2009 | Frigidaire Refrigerators
Most times this is caused by the dispenser door not shutting all the way. This causes moist air to be drawn in through the opening and the moisture will freeze in that area and also cause the dispenser door to have even more problems closing. Check the door and get me your model number so I can list the parts that are most likely causing this, Thanks Sea Breeze
Oct 26, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool side by side ice maker freezes up. can't get ice out of
Can you give more details?
If the ice chute is frosting up, chute door is not sealing, air , with moisture, is getting in and freezing. An ice cube getting trapped by the door will cause this also. Either case, replace door and delay mechanism.
May 01, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water does not flow through the dispenser
sounds like the sensors are playing up causing the bottom of the fridge to freeze, this will also cause the water reservior to freeze thus no water to the ice tray and water dispensor. do a full defrost then see if you gain back all the functions proving the sensor fault.
Apr 05, 2009 | Frigidaire FRS26R4A Side by Side...
Frost gathering in freezer, icemaker dispenser freezes over
well check to see if door seal is split if it is get new one!! need to see photo of the frozon over dispenser- found before that when ice not bein used alot the odd time you will have to take out the ice in the bucket crack it up and put back in try this???
Feb 03, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ge profile refrigerator ice maker
I have a GE Profile PSW26P Stainless Steel Side by Side refrigerator that makes plenty of ice but will not dipense when the lever is pushed. The dispenser makes not sound when engaged. What do you think the problem is.
Sep 28, 2008 | GE Profile PSW26P Stainless Steel Side by...
you have a defrosting issue, either a heater defrost thermastat or defrost timer
unless removed the wiring diagram is located in the bottom grill of the frige
May 08, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
GE monorgram frost in the ice shute
Sounds like the ice door in the dispenser isn't closing properly or all the way which lets warm air in condensates then freezes.
Oct 22, 2007 | GE Monogram ZISS480DRSS Stainless Steel
Whirlpool GC5SHEXNS Side by Side Refrigerator Logo
1,034 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
