Question about Refrigerators
Ice building up in my walk in
On my cooler behind the machine the coals are getting iced over
    Champion:
  • 287 Answers
Possible thermostate failure. this happened to me a few times. Is it frosting up in the freezer section?
Posted on Jul 16, 2009
What causes Ice build up on inside back panel of kitchenAide KUWA244PBS?
normally that means yhe defrost thermstat is bad or the heating element that causes the defrost is bad.
Aug 31, 2014 | KitchenAid KUWA244PBS Wine Cooler
Why is there ice build-up in a frost-free cooler?
Check the drin, its probably plugged up.
Aug 20, 2014 | Furniture
Ice build up
Normal to have a bit of ice. Set the temp to 0 for a few hours every week. Check Seal is good all round the door.
Apr 20, 2014 | Haier HVFM20ABB Wine Cooler
Samsung double door (fridge) the fridge cooler part is iceing up, the fan switches on and off you can hear it is catching on ice
There is ice build-up behind the plastic casing. If this is
not removed it will get worse, If you are pretty handy you can remove the white
casing at the back of the fridge and remove the excess ice. If not turn off fridge
and let it defrost completely. The alternative is to call Samsung if still in warrantee,
if not in warrantee they will charge you to compete this and it will not be
cheap!!
Aug 18, 2013 | True Freezer Glass Double Doors Top Mount...
DANBY dbc657bls This is a beverage fridge by Danby Designer. I have 2 of these fridges and one is just starting to get ice build-up at the back. I have defrosted it a couple of time and the problem of...
you have a door seal leak, the ice is from outside air getting into the cooler, you might also check for an air leak it the service door in the bottom back of the cooler.
Jan 21, 2011 | Danby DWC610BL Wine Cooler
My roper refridgerater is not cold enough even though the compresser fan is running and the freezer fan is running
First thing to do is check for ice build up on the coils and make sure there is air flow in the unit. If there is any ice build up, then try defrosting and cleaning the coils, make sure any dust build up is also cleaned off. If that doesn't help, a new thermostat may be needed. Let me know if you need anything else.
Benjamin
Nov 05, 2010 | Nor-Lake Norlake Refrigeration 4' x 6'...
Ice build-up on GE ZDW24A wine cooler cooling coil
Probably the thermostat is bad , you can bypass it by putting together the two wires from the thermostat and if the unit starts working ,replace the thermostat ;only do this if you havesome knowledge of electrical work and be very carefull.
Nov 04, 2009 | GE ZDW24A Wine Cooler
Avanti Beverage Cooler BCA5105SG running very loud.
Inside the cooler is the evaporator fan usually right in the middle behind a cover. As it slows down you have less circulation and ice forms quicker and cooling is diminished. Sounds like it is going out.
Sep 14, 2009 | Avanti (BCA5105SG) Beverage Cooler
Mountain of ice in walk-in(floor), around the parts(ceiling)
No choice but to move your food to a secondary unit & defrost the walk-in. If you go chipping around your condenser you risk more damage. Hopefully you have seperate breakers for you walk-in vs other cold storage areas.
Apr 22, 2009 | Hoshizaki Freezer Commercial Ice Machines...
Fan blower coleman electric cooler
The fan should blow air into the heat sink. The warm air exits the heat sink at both ends. (It might work the other way, haven't tried it.)
When you have ice in your cooler, you know the thermo-electric element is working well--it's below freezing!
Ice builds up because there is water in the cooler. For example, in humid weather, you open the cooler, some humid air gets in, and the cooler temperature condenses the water. You have to empty this water, either by tipping the cooler, or using a sponge.
You can easily defrost the cooler by unplugging it for an hour or so. You know it's time to defrost when you hear the fan blades making a racket because they're hitting something--a thick buildup of ice.
Aug 10, 2008 | Coleman Electric Cooler 40 Beverage Cooler
Refrigerators Logo
54 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
