Question about Dryers
Drum spins, but not heating
I have a Kenmore electric dryer. The model number is 110.63102101 and I have the back off. I'm not sure what the problem could be. On the back there's a white sticker saying something about if the fuse is open and the thermal whatever is open.
    President:
  • 1,136 Answers
Hi, UNPLUG the dryer! Remove the rear panel of the dryer and locate the fuse. It is white and ¼” wide and 3” long. It is located on the blower housing. Remove the wires and check to see if it has continuity. If it does not, you need to replace it.
Please let me know if this help or if I can assist you further.
Thanks
Vic
Posted on Jul 15, 2009
  • Victor
    Victor Jul 15, 2009
    Hi, In case the fuse checks out ok, here is more on the element. UNPLUG the dryer! The element is on the right hand side. Plug the dryer back in and test to see if there is 240V going to the element posts. If there is voltage, but no heat, change the element. If it does not, you need to test the thermostats for continuity. If any of the thermostats are open, replace it. I hope this helps you.
    Thanks
    Vic
11076812693 drum won't turn.
Kenmore Dryer Model 110.76812693 (11076812693) Drum ...
www.repairclinic.com/.../Model-11076812693-Kenmore-Dryer-Drum-T...
Kenmore Dryer Model 110.76812693 (11076812693) Drum & Tub Parts in stock. One million parts for 125 brands. Guaranteed same-day shipping. Call 7 days ...
Kenmore Dryer Model 110.76812693 (11076812693) Motor ...
www.repairclinic.com/.../Model-11076812693-Kenmore-Dryer-Motor-...
Includes pulley for dryer drum drive belt. Other shaft has reverse threads for blower wheel. Common symptoms of a bad drive motor are: -Dryer stops turning ...
Kenmore, Whirlpool Dryer Repair - Heats properly, drum will ...
? 6:29
https://www.youtube.com/watch?v=bOShDc4kLfk
Jul 10, 2013 - Uploaded by ApplianceVideo.com
Service a Kenmore Dryer with some of the following issues: Heats but ... Kenmore, Whirlpool Dryer Repair - Heats properly,drum will not turn - 11068202794 ..... Whirlpool Kenmore Maytag Amana Dryer Won't Start - Easy Fix ...
How To Fix Dryer That Won't Tumble ' Dryer Repair
www.partselect.com/Repair/Dryer/Will-Not-Tumble/
Feb 08, 2016 | Kenmore Dryers
Kenmore elite dryer runs when door closes
I have seen the heating element blow and short out. Causing very strange problems. If you have a model number we can look farther.http://www.on-timeappliance.com/dryerrepair.html
Mar 27, 2012 | Kenmore Elite HE4 Electric Dryer
Kenmore model 110.63942101 (electric). everything works but no heat... drum spins, timer works. Should I buy heating element replacement kit? does it need to be installed from the back of the dryer...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 19, 2011 | Kenmore Dryers
Dryer spins and drum turns, but only cold air c...
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 20, 2010 | Kenmore 800 7982 Dryer
Hello,my kenmore dryer wont heat. i am not sure where the fuess are? thank you mike
There are no fuses internal to the dryer, except for a thermal fuse located with the strip heating element.
Let's start with the basics, does the motor turn the drum but the unit just does not heat?
Is this a gas or electric dryer?
Please provide Make and Model number of the dryer.
Dec 18, 2009 | Kenmore Washing Machines
Dryer heats but drum does not turn when the start button is pushe
You need to check the drum belt. With dryer empty, reach in and give it a spin. If the belt is good, it will stop in 1/2 turn or less when released. If the belt broke, it will spin almost a full turn.
Oct 25, 2009 | Kenmore 62602 Electric Dryer
Kenmore dryer model number 110.66912691 not heating.
Check the house electrical panel for tripped dryer-circuit breaker-pair. Push off, then on. If immediately re-trips, the dryer has a dead short circuit in it. If they hold, then retry the dryer. If it now works, ok! If not, recheck the breakers as above. If tripped again, there is a likely short in the dryer's heater assembly. The drum must be removed to access the heater.
Aug 24, 2009 | Kenmore 62602 Electric Dryer
Model PYE2300 AYW the dryer turns on and provides heat but the drum does not spin
your belt has come off the drum or has broken. Take the model and serial number to parts house for replacement. The belt should be accessed through the back of the dryer. Good Luck on your repair. Make sure to disconnect electricty before removal of back.
Dave
Aug 05, 2009 | Maytag PYE2300AY Electric Dryer
My kenmore dryer is blowing out cold air
Make sure that both poles of your circuit are live - An electric dryer uses 220 volts to the heating element, but taps into only one pole (110 volt) for the motor that spins the drum. Check your circuit breaker to make sure that neither pole has tripped.
Jun 26, 2009 | Bosch Axxis WTL 5410 Electric Dryer
KENMORE DRYER MOD# LEQ9858LWO WILL NOT TURN BUT HEATS
If you hear a humming, then it is probably a broken or slipped belt from the motor to the drum. There is usually a pully on the shaft of the motor, a tensioner pully on a spring, and a groove on the back of the drum that the belt rides in. If this belt breaks or comes off track, the motor will still spin but the drum won't.
You will probably need to take the front or back off of the dryer (varies by model) to expose a view of the belt, and once you do this, it will be easier to see if the motor is turning or the belt has broken or slipped.
If the belt has slipped, be sure to inspect it for wear, and replace it if worn. Otherwise, it will slip again and you'll have to repeat the process.
Jun 10, 2009 | Whirlpool LEQ9858L Electric Dryer
Dryers Logo
Top Dryers Experts
