Question about Epson Stylus CX7800 All-In-One InkJet Printer
Remove and replace inkjet cartridges
Help I lost my manual and don't know how to remove and replace the ink cartridges
  • Epson Master
  • 1,113 Answers
Re: remove and replace inkjet cartridges
Download user manual by clicking HERE
Posted on Nov 18, 2007
0 characters
3 Points
Lost my manual, need to change the ink cartridge, help
  1. Look at the indicator light on your Lexmark printer. You'll need to replace ink cartridges when the light flashes or turns red instead of the standard green.
  2. Purchase Lexmark ink cartridges. You can buy the brand name or purchase a generic version that is compatible with your printer. You can shop for low cost ink cartridges from ABC Ink.
  3. Step 3 Remove the old cartridges from your printer. Grip the sides of the Lexmark ink cartridges and pull it out. Dispose of the ink cartridges in a recycle program like the one at Staples or save the cartridges for refill.
  4. Step 4 Install the new ink cartridges after removing the protective tabs. Avoid touching the IC chip when installing the new Lexmark ink cartridges. Replace the cover of the printer.
  5. Step 5 Allow the Lexmark printer to run a nozzle test. Print several pages with the new ink cartridges to make sure you installed the ink cartridges correctly. The indicator light should return to a solid green color.
Apr 24, 2010 | Lexmark C533DN InkJet Printer
Replace ink cartridge
just open the cover .when you open the cover cartridge will come to center just pull all the cartridges one by one don’t make pressure too hard it will come easily if you put more pressure and try to removing it and it is not come out then don’t do it may be you doing wrong . let it be and take help from some one who using printer and know how to fix the cartridges.
Have a nice day and do not forget to rate please...!
Feb 16, 2010 | Epson Stylus DX4450 All-In-One InkJet...
Dont' Know Where Printer Cartridges Go In Brother MFC Printer
Here is the manual:
MFC240c Manual
See page 93 for ink cartridge replacement.
Thanks for using Fixya.
Jun 20, 2009 | Brother MFC 240C All-In-One InkJet Printer
How do i change ink cartridge 21 in hp deskjet D1460 printer
Here is the manual for your printer courtesy of HP:
On page 47 of the manual it explains how to change out the cartridges.
Let me know if you need more help.
May 23, 2009 | HP DeskJet D1460 InkJet Printer
Lexmark z2300 eplacing ink cartridges
Go to There will be instruction on how to replace the cartidges. you will b e able to print out the instructions after you fix the problem.
May 21, 2009 | Lexmark Z2300 InkJet Printer
Low on ink. don't know how to change ink cartridges.
Heres a direct link to the download page so you can get a manual, its free. CLICK HERE
That should help you the instructions for changing ink is in there, feel free to give me a Fixya rating if this answers your question.
Jan 04, 2009 | Epson Stylus CX3200 All-In-One InkJet...
Dell 725 printer no manual need to change ink cartridge
Here is the manual
Replacing an Ink Cartridge
  1. Turn on your printer.
  2. Lift the front cover.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
  1. Press down on the ink cartridge lever to raise the ink cartridge lid.
  1. Remove the old ink cartridge.
  1. Dispose of the old cartridge properly.
  2. If you are installing a new ink cartridge, remove the sticker and transparent tape from the back and bottom of the ink cartridge.
  1. Insert the new ink cartridge.
  1. Snap the lid closed.
  1. Close the front cover.
Feb 09, 2008 | Dell 725 InkJet Printer
How do i take out the ink cartridge
Hi Kalola, Here is the link to the document files for your printer, the one labeled *Product Information Guide* is the users manual: Page 6 covers the removal and replacement of cartridges. Let us know if you have any other questions and please don?t forget to rate the posting.
Jan 18, 2007 | Epson Stylus C40UX InkJet Printer
Epson Stylus CX7800 All-In-One InkJet Printer Logo
Top Epson Printers & Copiers Experts
Are you an Epson Printer and Copier Expert? Answer questions, earn points and help others
