Question about Electronics - Others
Do cooling fans on the vec550pob turn on and off as needed or are they on all the time?
On all the time ol mate
Posted on Jul 19, 2009
AVE ERROR CODE 5351 WHAT IS IT?
C5351 Power Supply Cooling Fan Motor Failure The Power Supply Cooling Fan Motor Lock signal remains set to H for a set period of time while the Power Supply Cooling Fan Motor is turning. • The Power Supply Cooling Fan Motor Lock signal remains set to L for a set period of time while the Power Supply Cooling Fan Motor remains stopped.
Aug 26, 2015 | Computers & Internet
Error code 5351
Motor Failure
stopped.
Jul 17, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
2005 Jeep Liberty Cooling Fan - Run full time with the A/C on?
When your idling at a stop or parked an the engine is running A/C on cooling fans should be running . When your driving down the road air flow through the condensor is good enough and the fans don't run .
Aug 13, 2017 | Jeep Liberty Cars & Trucks
How you know if you need a cooling fan relay
If your cooling fan is running all the time or if the cooling fan does not turn on when engine temperature is at normal or higher than normal temperature. It is possible in cold weather the fan may not turn on often.
Jan 12, 2013 | 1990 Honda Accord
95 lexus es300 over heats when ac is turn on
Is your radiator cooling fan operating when the A/C is turned on? The cooling fan should be running at all times with the A/C on. If it does not, then your problem is being caused by a bad cooling fan motor, a bad cooling fan relay, a broken fan motor circuit, or broken fan control circuit.
Aug 27, 2011 | Lexus ES 300 Cars & Trucks
I have eclipse 00, just got fixed yerterday because of the cooling system problem. they installed a new cooling fan and now the car has two cooling fan. but i wonder why the new cooling fan which is...
I'm not familiar with your car exactly, but usually the second fan is the air conditioning fan. Turn off the a/c, and see if this causes the fan to shut off.
Mar 16, 2010 | 2000 Mitsubishi Eclipse
No led red or green vec550pob 1500 watt, nor do i know what the "power supply accessory socket"
how to repair power maxx inverter 1500 wats vec550pob
my inverter turns on but red and green light on at the same time, and fans working for 3 seconds on and off
Oct 25, 2009 | Vector Maxx SST Power Inverter
Fans not working right
MOST OF THE TIME IF THE COOLING FAN FAILS TO OPERATE.THE COOLING FAN RELAY OR FUSE IS BAD.ALSO THE COOLANT TEMPERATURE SENSOR IS OPEN.THE COOLANT FAN WONT TURN ON.TO HELP YOU PIN POINT YOUR PROBLEM.GET IT SCAN.IT WILL TELL YOU IF THE COOLING FAN CIRCUIT IS WORKING OR YOU HAVE A BAD COOLANT TEMPERATURE SENSOR.YOU NEED THESE TWO COMPONENTS TO GET YOUR COOLING FAN TO OPERATE AUTOMATIC AGAIN.
Sep 18, 2009 | 1990 Ford Taurus
Replaced relay, but both electric fans won't come on
Are we talking about the cooling fans for the engine and AC condenser?? Only one cooling fan will cycle on and off during normal operation. The main cooling fan will cycle on and off as needed for cooling the engine. If you turn on the AC or select a defrost mode on your climate control then the 2nd additional fan will run usually continuously in order to condense the freon in your AC system for cooling the interior of your car and in defrost mode it helps to reduce interior moisture on the glass (defog/ defrost). If no fan comes on at any time whether the engine is hot or cold or whether you turn on the AC or not and you have already replaced a cooling fan relay and checked related fuses then either the fan /s are bad or you dont have power in or out of the fan circuit which consists of several components that would need to be checked. Let us know if you find anything else or have additional questions.
Apr 25, 2009 | Hyundai Motor 2000 Tiburon
Electronics - Others Logo
191 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
