Question about Sony KP-57WS520 57" Rear Projection HDTV-Ready Television
I can`t seem to get rid of the clock or channel on my screen HELP
The clock is always showing in the bottom right corner and satellite in the top left how do i get rid of this
  • 10,594 Answers
Press Display or "info" button on Sony TV Remote, on-screen display will disappear. Please use TV Remote, no other remote will work for that.
Posted on Jul 15, 2009
How do I fix the clock
Push the main control knob (right side of the unit) either up or down, until the Kenwood's display screen shows "Clk Adj." Press the center of the control knob for about a second to enter the clock-setting mode.
  • 2 Push the main control knob either up or down to set the Kenwood's hour display. Stop when the correct hour shows on the screen.
  • 3 Push the main control knob to either the right or left to adjust the minute display. Stop when the correct hour shows on the screen.
  • 4 Press the "Menu" button located in the bottom-left corner to save the changes you made to the clock. This returns you to the main menu
  • Oct 19, 2011 | Kenwood Car Audio & Video
    I can't set the time. I've looked on-line and still can't figure out the step by step instructions. They don't seem to match my watch which is a women's 1440 Sport watch with gray band.
    Hi aausenhus,
    You can easily change the time of your Timex watch by following the steps below.
    1. With the time and date showing, press the top left button.
    2. Press the right top button (this sets seconds).
    3. Press the bottom left button. This flashes the hour; press the top right button until you have the correct hour (there is no symbol for am, pm will show if pm).
    4. Press the bottom left button, minutes flash. Press the top right button until correct minutes.
    5. Press the bottom left button, month flashes. Press the top right button until correct.
    6. Press bottom left button, date flashes. Press the top right button until correct.
    7. Press bottom left button, day flashes. Press right top button until correct.
    8. Press bottom left button, time format flashes (can be set to 24 hour clock). If correct, you're done. Press top left button if you're done (can be pressed at any step if you're finished).
    To turn off the chime and alarm: Press bottom left until in the alarm screen. Then press the top right button repeatedly until the CHIME or CH symbol is gone and/or ALARM or ALM to disappear, then press the bottom left button to go back to main time.
    Hope it helps.
    Thank you for using FixYa.
    Apr 27, 2011 | Timex 1440 Nylon watch
    I cannot set the time in my timex 1440 watch. It came with the wrong directions. The mode button doesn't seem to work.
    Hi fransolomon8,
    Hope it helps.
    Dec 10, 2010 | Timex 1440 Nylon watch
    I want to use the gps and navigator on my nokia 5800, can you please help
    I'm assuming you just got the phone recently, in which case it probably has everything you need installed already.
    From the home screen, you can click the compass icon in the top left corner. Or from the menu screen (not the applications screen), you can click the compass icon in the middle.
    It should then say "ovi Maps" and show you a menu. Don't click anything yet. Click on the spanner icon in the bottom left to bring up the settings, then click on "Internet". Then change Connection to "Offline" unless you want to spend a fortune on mobile internet fees. Then click on Menu to go back to the "ovi Maps" menu.
    Now click on "My position" in the top left. It should show you a map, but not of the right place. (You can try zooming out and finding the correct country and location manually if you want, or you can wait for it to work out where you are.)
    Make sure the connection icon in the bottom right is crossed out and says 0.0kB, otherwise it will cost you money.
    Underneath that is the satellite signal. It will start out flashing one bar. You need to go outside, walk around, and wait a long time before it finds the satellites, then eventually it will find your position. When it knows or remembers your position there is a red dot button in the top left that will make it show your current position.
    The nokia 5800 doesn't have a compass (aka magnetometers) so you need to work out which way North is yourself.
    Let me know if this doesn't work.
    Mar 18, 2010 | Nokia 5800 XpressMusic Smartphone
    Sony lcd kdl-260200 ihave aproblem with a
    In the setup menu i believe it is called the "Reminder" if it is turned on it will always show you the channel or input, can't remember exactly where it is located but somewhere in the setup.
    Oct 10, 2009 | Sony Televison & Video
    Mitsubishi DLP wd-52725 wavy lines from top left to bottom right
    the DM board is going bad and needs to be rebuilt. check out www.tv-techs.com
    Jan 02, 2009 | Mitsubishi WD-52725 52". Rear Projection...
    Olevia 540-B11
    damm i have the same issue except the left side of the screen is far darker than the right. It still works but is very noticable. If you get this resolved please reply back!
    Aug 19, 2008 | Olevia LT42HVi 42 in. LCD Television
    Very small problem
    If you have the original remote, press display and hopefully the AV6 display will go away.
    Jul 15, 2008 | Sony BRAVIA KDL-46V3000 Television
    Sony KP-57WS520 57" Rear Projection HDTV-Ready Television Logo
    89 people viewed this question
    Top Sony Televison & Video Experts
    Jerry Greenberg
    Jerry Greenberg
    Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
