Question about Coleman Heating & Cooling
AC won't cycle
Runs fine on full cool setting on thermostat but the compressor lugs down when it try's to cycle. I have replaced the thermostat and start capacitor and the problem persists
    Scholar:
  • 91 Answers
It could be that your unit is going into thermal overload. This can happen from several factors. Unit could be dirty(inside or outside coils) they can be cleaned with a degreaser or 409, but must be rinsed thoroughly. Location of indoor coils is close to where the indoor fan is, you'll need a 1/4 or 5/16ths driver to remove protective panel. Or your unit may be short on freon or the compressor valves are shot. These items need to be checked by a certified Tech. Good luck and reply if you have further info
Posted on Jul 15, 2009
My frigidaire AC starts cooling fine but stops blowing cold air after few minutes and it does not cool at all. I haved turned it off and re-started it and it does the same thing
The compressor is being prematurely turned off. That explains why the cooling stops after a few moments. Either the thermostat is responsible or the electronics working with the therm are responsible for the anomaly.
Freon level is fine because it does cool when compressor is running. U might also want to check the start/run capacitor. That sucker starts the motor and keeps it running after the start. If the run section goes bad the motor will usually stop after it starts.
Aug 17, 2016 | Frigidaire FAS256R2A 25,000 BTU Window Air...
My Dometic roof top ac doesn't cool. Fan runs fine, no COOL air. With thermostat in off position. Checking the voltages I found 118v at the breaker. At the run relay, 118v going in and a coupl
Please reply with Model number of bottom of AC unit ( upper) . Can be seen from inside usually. Thermostat model, plus if controls are at the ceiling assy or at thermostat on wall.
Jan 17, 2013 | Dometic Rooftop RV Air Conditioner
Bought this LG unit (LWHD7000HR) summer of 2010 and it worked fine - used very rarely. Did not use heat in winter either. Went to turn it on this summer and it does not cool. Fan operates but compressor...
Unplug the a/c and check the control panel of your a/c. Unscrew the control panel to expose the wires and terminal lugs.Check for lose wires or terminal lugs or defects from the compressor capacitor. If all are OK try adjusting the thermostat switch to make the contacts work. If the capacitor is damage replace it and replace any damage terminal lug. If the compressor still does not work, check the overload and the compressor resistance. If overload is open, replace it and check compressor amperage. If the compressor amperage is high, you have to replace the compressor, vacuum, and recharge freon.
Sep 02, 2011 | LG Heat cool Window Air Conditioner
The compressor fan come on; I can hear a clicking (the compressor trying to click on, then immediately shut off. It will contiula doing this as long as the thermostat is set for the ac to come on. I...
Possibly a bad run capacitor, have a service tech test it and replace if it is bad. That clicking you hear is the internal overload in your compressor clicking off on high heat/amp draw and then cooling down and resetting itself.
Jun 16, 2011 | Heating & Cooling
05 vue ac problem, ac not cold at idle, blows cold while driving, had checked freon is full, expansion valve was replaced, because high side flutters and low side does same. seems that compressor doesnot...
Hello, Are the cooling fan(s) coming on with the truck in park and the engine at idle? If the cooling fan(s) are not working A/C will not cool with truck setting still.
Oct 02, 2010 | 2005 Saturn VUE
AC is off but compressor cycles periodically
most likely your compressor contact is stuck closed, and will need to be replaced. if the fan also runs when the compressor comes on you may have a short between the t-stat and unit. hope this helps.
Jun 14, 2009 | Dometic Rooftop RV Air Conditioner
Refrig. not cooling, but freezer working fine
Is there ice frosted on the back wall? If so you have a defrost problem and you need to replace the thermostat, Defrost timer and heater. This ensures the problem is totally fixed. if you can nail down exactly which of these parts is the problem then just replace the problem.
Feb 09, 2009 | Frigidaire Refrigerators
Running Compressor Intermittently
replace the thermastat it has a bad set of contacts
May 05, 2008 | Goldstar R8000 Air Conditioner
Heating & Cooling Logo
64 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
paulcarew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
