Question about Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum
Hoover Steam Cleaner - dirty water is not coming up in the tank!
My Hoover Steam Carpet cleaner problem:
It's not picking up the dirty water.
  • 97 Answers
Recovery tank (dirty water tank) not on correctly
Posted on Jul 20, 2009
Won't pick up brown water
Hello! Follow these quick trouble-shooting steps to restore suction to your Hoover F5835900.
1. Remove the clean water tank.
2. Recline the handle and let the cleaner lay flat.
3. Remove the dirty water tank lid.
4. Reposition the front panel located on the outside of the tank in the center. It should be flush to the tank, even straight across and pushed down as far as it will go.
5. Assemble the dirty water tank lid back on from the front to the back. The lid should not lift up from the front.
Try it out. The cleaner should now have suction. Good luck!
May 31, 2014 | Hoover F5835900 Upright Steam Vacuum
Hoover steam vac f 5855 does not pick up the water
make sure your recovery tank is securely seated and locked
Jan 10, 2011 | Hoover SteamVac Carpet/Upholstery Deep...
My hoover steam cleaner will not pick up the water the machine pu
Two checks:
(1) Is the lid aligned and sealed to the recovery tank
(2) Is the round rubber gasket installed on the tubular post under the hood, where the tank seals to the base? The tube extending down from the tank must sit on the rubber seal to get vacuum from the motor.
Sep 29, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover Steam Vac V2 Deep Cleaner leaking clean water
Fill the tank and determine if the plastic is leaking, or if the valves are leaking. if the tank is cracked, it would need replaced. There is an improved design now available.
You may cycle the valves on the bottom with the eraser end of a pencil.
Sep 24, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover Upright Steam Vac, 12 amp
  • Check to make sure that the lower dirty water lid is installed and secure and not cracked.
  • Check to make sure the front duct panel is installed on the dirty water tank (this will transition the water from the front nozzle into the tank)
  • Check the filter in the dirty tank lid, clean if necessary
  • Remove the lower tank and look at the motor cover, locate a round hole, you should see a black ring (gasket).
  • with the lower tank removed, turn the machine on to check suction at the round hole, if OK then your problem will be with one of the above reasons
Jan 12, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover steam vac model F5853-900 series 17.9
Make sure that the recovery tank is completely close.
Oct 13, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover steam vac clean surge
The recovery tank lid isn't locked down all of the way around. The foam filter on the inside of the tank lid is up too far, needs at leasat a 1/4 in gap from the top. The filter screen by thye indicator is clogged. Some have a duct that sits in front of the recovery tank, either it isn't there or not pushed down all of the way.
May 14, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
The automatic shut off
Check the filter on the inside of the lid for the dirty water tank. It needs to have a 1/4 in. gap from the top of the lid to the top of the filter.
Oct 13, 2007 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum Logo
817 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
