Question about Maytag M6Y12F2A Air Conditioner
Can't reset the power. what's the next trouble shooting step?
  • 92 Answers
Did you unplug it? check for internal fuse?
Posted on Jul 16, 2009
Is there a reset button anywhere for starter, electrical, or power? Looking for next step in trying to start my car?
What make vehicle ? Fords have a inertia fuel cut off switch . No reset button for starter , there is a relay more that likely . Do you know what a relay is ? Find yourself a wiring diagram for your vehicle an then go to YouTube an check out some basic electrical trouble shooting videos . Check out battery testing an voltage drop testing the starting system . The only way to fix a starting issue is lean how the system works an do electrical testing . There are no magical fixes . How to Diagnose No Crank No Start Issue Nothing or only Click When the Key...
Nov 22, 2015 | Cars & Trucks
Compressor not running no power to copressor whta are the next steps to trouble shoot
is the interior light on? if not check main circuit breaker...if that is okay check the fuse on the wall plug
Jul 09, 2015 | Refrigerators
Power surge caused appliance to go out. refrigerator ice maker now not making ice. has water on but no ice help
Reset the ice maker:
Locate the switch next to the water filter status light.
Press the light switch five times in 10 seconds or less.
Wait for the status light to change from red to green.
Mar 02, 2015 | Whirlpool Refrigerators
I just bought a Hoover Air Lite, and the mechanism that moves the belt isn't doing anything, I tried resetting the brushroll but that didn't do anything. Why is it not working and what can I do to fi
Hi Brian! The vacuum must be in vacuum mode for the brushes to spin. Try these trouble shooting steps below to get your brushes spinning.
1. Power the vacuum on.
2. Recline the handle by securing the nozzle and pulling the handle back.
3. Press the brushroll on/off button located directly next to power button.
The brushes should begin to spin, if not repeat the same steps only you will press the brushroll on/off button twice consecutively. This is the brushroll reset procedure. Hope this works out for you!
Oct 02, 2014 | Hoover Vacuums
Fix error code amana dryer
The best method is to do your home work and find error code list and service manuals inside dryer or Google it online with your model number find error codes as most are online and you must do total trouble shooting procedure and replace defective parts if necessary and after you plug the dryer it should reset it self
If dryer did not reset in other hand if error code persist you still have problem and problem could be main board issue
Best way is visual check and check for any faulty component and parts and check all thermostats and sensors and look for clogged vent or any damaged or rusty or cracked components and use step by step deduction method for trouble shooting
Dec 08, 2013 | Amana Dryers
Both My Inspiron and linksys will not connect to my ISP. They say both are receiving an invalid IP address! I have used all trouble shooting techniques including trying to release and reset! Even went as...
Step 1: Plug the computer (ethernet wired) directly into the modem. Power cycle the modem and when all the light come on you should have internet. If not call your ISP to trouble shoot.
At this point we should be able to determine if it is a PPPoe connection (needs username and password to connect) or if it logs in automaticly.
Step 2: Plug the router back into the modem and the computer plugged wired (ethernet) to the router. Remove power from both the modem and the router. Plug the modem back in first, once all the lights are on plug in the router. Try to connect.
Step 3: Log in to the router via its IP address (normally 192.168.1.1), if no one has reset the user name password it should admin for both. If it has been reset, you will need to know what the user name and password are to continue.
Step 4: Under setup if in step 1 you found you needed PPPoe, then you need to set that under the setup tab. Make sure you use the user name and password provided to you by your ISP. If you dont need PPPoe then make sure this is set to obtain IP automaticly.
Step 5: save settings. Once the router restarts, try to connect again.
If these step do not work, let me know:
1. who is your ISP?
2. What modem do they use?
3. What is your IP address when plugged directly into the modem?
4. What is your IP address when plugged into the router?
I will be around for about 1 more hour, its 2PM central time now.
Jul 21, 2011 | Computers & Internet
Alarm is on and I don't know what to do
Let's try doing some trouble shooting of the problem:
Do yo have the manual for the appliance? (I just did a search, and I did not find this appliance listed in our archives, so You may have to serach on the internet to find one--
Anyway-- Do you have a reset button-- or an override-- that let's gas flow, to bleed air out of the lines?
What form of ignitor doe it have?-- a Glow ignitor?-- can you see it glowing?--
If not can you see if it is broken?
Observe and smell and listen-- what clues can you give us to help you trouble shoot it to the next step?
Mack B
Jan 23, 2011 | Optimus H4438 Gas Compact Heater
My daughter's RCA 'Pearl' MP3 player will power on and the screen will say "Usable memory exceeded, Please remove a few files". It will then shut itself down. Because it won't stay on, my computer won't...
Main support for the TH1102 is on next sites:
http://support.rcaaudiovideo.com/product.aspx?product=32
and
http://www.rcaaudiovideo.com/downloads/?sku=TH1102
To reset the player remove the battery and replace it.
If the player won't function correctly after that, go to the trouble shooting site:
http://voxrightnow.custhelp.com/app/answers/detail/a_id/7522/session/L3NpZC8zYU5rR1U2aw%3D%3D
Get a download of the firmware upgrade
direct link PEARL_FWUtility_v2.0.exe , or look on next page:
http://voxrightnow.custhelp.com/app/answers/detail/a_id/9284
Connect your player and install the updater onto your computer.
Follow the steps as told within the updater.
Aug 07, 2010 | RCA Pearl TH1102 MP3 Player
Maytag M6Y12F2A Air Conditioner Logo
160 people viewed this question
Top Maytag Heating & Cooling Experts
Bill Long
Donni Steen
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
