Question about Optoma EP737 - DLP PROJECTOR - 1500 LUMENS *NIC* Multimedia Projector
Optoma ep 753 will not light
The last time we used the projector it worked fine. It has had extensive work done on it under warranty, inclucing the color wheel and engine (?). This time it lit for just a bit at full brightness, then dim, then the projector turned the lamp off. It tried for a couple more times, dim and hardly visable and now the lamp light and lamp will not come on. How do I test the bulb to see if it is bad?
  • 115 Answers
You can just open the lamp and see the condition of the inner tube only. otherwise you have to replace the lamp and run it.
Posted on Nov 19, 2007
I have the DELL 2200MP projector. It fell but still works except for the color it is only BW, there were broken pieces of what looked like a rainbow wheel, Im told this is a color wheel, can it be...
Yes, it can be replaced; but Dell replacement parts are very hard to find. Also, it is tricky to open the equipment and not damage any other parts during the process. If you don't work on electronic equipment, I would take it in for service. Other suggestions on the web say to buy a used one for replacement parts if you want to do the work, because they cannot find service manuals or parts - except for bulbs. The color wheel for my Toshiba was $160, and the lamp was bad at the same time.
Feb 08, 2011 | Dell 2200MP Multimedia Projector
Sharp XR1S It projects the image on screen, use to show the correct color. last time the image was projected but in pink hues. is this an adjustment issue or is the lamp going or gone?
first of all check the tint setting on your projectors picture menu.
if not get the correct color then, your projector is a dlp projector that means it have a color wheel in side. if the synchronization of color wheel is not correct this problem can occur. there is a sensor for couting the rpm of color wheel. also have a black mark on the color wheels rotating portion. the sensor scene this black mark for making count. if there is any dust in that portion it will make difficult to the sensor making the counts. you have to remove the color wheel to clean the same.
i have added a video how to clean the color wheel . not the same projector.
Feb 02, 2011 | Sharp XR-1S Multimedia Projector
HD70 DLP Projector: The projector is used and about a year old. It cur...
Did this start occurring after you replaced the lamp?
The reason I ask is I had the same issue after changing the lamp and it was caused because when I took out the old lamp I noticed dust in the lamp housing which I attempted to blow away.
This caused the problem because some dust got further into the projector, specifically around the color wheel. I sorted it out by taking the projector apart following the instructions here:
(note my HD70 was out of warranty, if yours is not, I would recommend contacting Optoma to get it fixed).
Follow the above instructions to step 14 and then locate the color wheel which is at the front of the projector behind a dark gray, plastic type square shaped cover.
You have to be very careful here, but remove the color wheel (there is one screw holding it in place) - note it
May 18, 2010 | Optoma HD70 DLP Projector
Buy a cheaper color wheel !
Sorry, the color wheel is only available in the Light Engine Assembly. You can not purchase it as a single part. You will have to purchase the engine and replace it to repair your TV. PN: 23405476 it runs about $450 with a $200 core. You may find it cheaper... I don't think it is readily available... Best of luck to you, I hope this was helpful.
Mar 26, 2010 | Toshiba 62HM95 62" HDTV
Color wheel sounds like a buzz saw. Fan is quiet because there is no noise in the cool-down mode. Can this be replaced by user?
Baily, I have had my HC1500U color wheel replaced two times due to the color wheel's unpleasant "buzz saw" effect showing up every few thousand hours of usage. It is happening again for the third time and I am still within Coscto's warranty so I am going to have it replaced again...will never buy a DLP projector again...too many moving parts that can break!
Would love to be able to replace it myself if you ever find a place that sells the color wheel.
Feb 09, 2010 | Mitsubishi HC1500 DLP Projector
Color wheel in my InFocus ScreenPlay 4805 projector
The 4805 Color wheel part number is 525-0146-00
You can buy it from AV SOLUTIONS in NY
As far as if it's worth it... That's up to you.
Nov 07, 2008 | InFocus ScreenPlay 4805 Multimedia...
Infocus 4805 blinking red light problem
My first questions is:
Is this the first lamp you have placed into your Infocus pj? If not, did you reset the hours when you did it last time? Otherwise that can also confuse the projectors internal system thinking there is NOT a new lamp in there and there for make it stop working once the clock hours are expired and over the 3000-6000 suggested hour life.
Let me know so I can help trouble shoot other possible problems.
Oct 27, 2008 | InFocus ScreenPlay 4805 Multimedia...
Optoma H30 Projector: color banding
Most DLP projectors have a colour wheel. It's usually hard to get at, and you may have to actually remove everything including the optical block from the projector to access it. This wheel turns on a motor just like a fan, and if it gets dirty it can act up just like a fan.
They are expensive to replace, so you might want to try taking it apart and cleaning it out. Add a small amount of 3 in 1 oil to the motor if you can.
Aug 22, 2008 | Optoma H30 Multimedia Projector
Nec lt260
Clean optocoupler under pcb 4554B on color disc wheel.
Dusty on this part make not good sincronice with dlp panel.Good luck.
Jun 28, 2008 | NEC LT 260K Multimedia Projector
How many times does the light flash?
Sep 28, 2007 | Sony Grand WEGA KDF-50WE655 50" Rear...
304 people viewed this question
Top Optoma Office Equipment & Supplies Experts
color wheel light...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
