I have the opportunity to purchase a used karcher kds 950 for fairly cheap he tells me the motor doesn't work if this is the motor does anyone know the cost and details to change the motor
CarGurusApr 7, 2013 - I need to find out what transmission is in a 1999 gmc sierra 1500 pick up 4x4 extended cab. ... Good luck. if the transmission is bad and you KNOW that for a fact, just go ahead and pull it ... My trans went out yesterday and I found one and wantto make sure it fits before I buy it. ... Used GMC Yukon Denali".
CarGurusAug 15, 2014 - Is the transmission in a 1999 gmc yukon and a 2000 Yukon Denali the same. ... Does anyone know where I can get a fairly cheap used motor from in or ...Need a good fairly cheap motor for my 99 Gmc Yukon Denali 5.7L V8.
I would think that a ribbon cable which connects to the display module has been disconneted. Printers are fairly intricate and great care must be taken on dissassembly as well as assembly. Take a look but take care in doing so, its not worth taking them in for repairs these days because printers are cheap to buy and tech labour is not cheap. I have an HP 3630 wireless printer and it does excellent photos transmitted straight from phone on wifi, only cost $70au
This happened to me. I took apart the bobbin and there were no threads stuck. It moved freely, but the hand wheel was still stuck. So I checked the belt between the handwheel and the motor. I tugged on it (while the machine is off) and tugged on the belt to turn the handwheel. It took a couple tuggs to make the handwheel move, but once it started moving, it seemed to unfreeze. And I was back to normal. I can’t tell you what happened, but it’s fine now.
Normally when you dry run a machine you damage the pump so it would probably need changing. The motor might be Ok but for you to fix it you will need to take it to a Karcher dealer/service center.
From experiance it sometimes can be more cost efficient to purchase a new Karcher machine and get the 12 month warranty than spending money on an older machine.
Been there That would be the blower resistor and at least in the cases i have seen that usually means the motor is going bad you can replace the resistor fairly cheap not sure exactly where it is on you car but i would assume it is under the passenger side dash dont quote me on that dont know what type of car it is when you but just ask they should be able to tell you
good luck
Did you check if the igniters? they may be cloged up with ****. Unscrew the Sight glass on top of the boiler and run the machine (in cold or hot mode, doesn't matter, as the igniters are running all the time) and see if there are working, you should take them out anyway and give them a wipe with a rag as general maintenance item, and when you put them back in there should be about 5mm gap between them.
Less common reasons for the boiler to not work - Faulty fuel solenoidvalve, (You should hear a click sound about 5 - 10 seconds after you pull the trigger) - Dirty fuel filter, Take a look at those simple things and let me know if its any of these. I have a Karcher HDS 750 1989 Year model This machine just keeps going, it's had a fairly tough life but it has stood up to it all, i hadent spent anything on it until about 6 months ago when i purchased a new fuel pump for it as the old was wasn't pushing 170PSI to the Disiel injector it had slowly droped 70psi, and it doesn't create a hotter burn in the boiler, but still very good for a 19yr old pump, other than that thats all it's needed, it's still going strong to date Very robust machine. my e-mail is [email protected] Cheers Matt.
