Question about Dynex DX-UBDB9 Serial Adapter
My computer will not read the CD that came with the adapter, How can I get it to work?
    Problem Solver:
  • 16 Answers
Try downloading the driver from here.
Posted on Jul 31, 2009
My memory card is not working
Memory cards, also called memory sticks or MS cards, can create problems with a computer. Sometimes, a computer will not read the card or errors cause problems when removing files from the card to put them onto the computer.
Problems range from a virus on the memory card to inappropriate software on the computer. Fixing the problem partly depends on the cause of the problem, but making the card work is simple and takes only a few minutes.
Scan for viruses. Some viruses or worms infect MS cards.
A computer that suspects a virus might interfere with the memory card as a result.
Look for viruses or problems with the anti-virus software that won't allow the memory card to open. If a virus if found, remove the virus through the anti-virus software before opening the memory card.
Check that the computer has the appropriate software installed to read the card.
Some MS cards or memory sticks might require more updated software or specific software that is not on the computer.
If the software is installed, look for current updates and download any updates to determine if the problem is old software.
Open the control panel.
Click on "Add New Hardware" and see if it is available.
If the hardware for the memory card is not installed on the computer, this will allow installation.
Once installed, the card should read.
If the memory card is not showing up, the problem is often damage to the card, which prevents reading the card. If the card is damaged, it must be replaced.
Use an adapter.
Some memory cards are not designed for reading in a computer directly and require the appropriate adapter.
The adapter changes the data to the appropriate system for the computer to read it.
Hope this helps
Nov 16, 2012 | Electronics - Others
Hi there, I just bought a new computer to which has the home network connection but my old computer now needs to be configured with my new NetGear WNA1100 WirelessN 150 USB Adapter to be able to have...
Since your computer can't read cd and you have the installation cd what you can do is to copy the contents of the cd to a flash drive from another system then use the flash on your own pc, and install it from the flash. Try this.
Thanks
Dec 14, 2010 | NetGear WNA1100 WirelessN 150 USB Adapter...
I have a computer with no wi-fi connection can I still install a wireless-B adapter?
Certainly; this is a USB adapter, so if you system works with other USB devices (like flash drives), you should be A-OK with a USB wireless adapter. If you have a fairly new version of Windows installed, you probably won't even need to run an installation CD, but you should read the manufacturer's "Quick Start" guide completely and take *their* word over mine :-)
Apr 21, 2010 | Linksys WUSB11 802.11b Wireless Adapter
HP ZV 5000 AC PROBLEM
You either have a bad adapter or a broken power jack in the laptop. To check the adapter use a multimeter set to voltage and connect one lead to the center in and the other to the outside metal contact. You should get a reading from 18 to about 26 volts. If you get no reading then the adapter needs to be replaced. If you get the correct reading then the power jack in the laptop will need to be replaced. If yo are ok with electronics repair you can get the jacks from Ebay.com if not your local computer repair shop should be able to do it for you.
I hope this helps, If so please rate my solution,
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of PC and printer support/repair.
Jul 08, 2009 | HP Pavilion zd7000 zx5000 zv5000 presario...
Cannot read belkin cd on computer
you will have to have the latest driver downloaded on your pc. Also go into device manager and make sure the device shows up and is enabled
Jul 06, 2009 | Belkin N1 Wireless USB 2.0 Network Adapter...
Unable to get on the internet. in device manager network adapters not working. Tried to update, and install from resorce c/d. still not working
your adapter might have burned out. easy thing to do is goto best buy, and buy a new network adapter card. last time i bought one it was around $15 bucks. then disable your current network adapter turn the computer off and then read the directions for installing the new one. the other way would be to download the drivers from dells website from another computer, save on a CD and then try to install them, but i would bet your network adapter just fried but your comp still says its there.
Jun 05, 2009 | Dell Dimension 4600 PC Desktop
Computer keeps crashing!
Thanks for your posting in FixYa.
Please can you reboot your PC in "Safe mode with Networking".
Tapping F8 key as soon as PC bootup.
Let me know if you are able to work in it then.
Regards
ELLIN
Sep 23, 2008 | Dell Inspiron 6000 Notebook
Will not install
You mean the adapter is not recognized by your computer or the setip CD is the one that is not being read by your computer?
If the adapter is the one that is not being recognize by your computer try connecting it on another USB port on your pc and if still not detected by your PC try connecting that adapter on another computer's USB port just to check if it will be detected by your pc, if not retirn the device back to store.
But if you're saying that the setup CD is the one that is not being recognize by your PC try downloading the software from the manufacturers web site.
Hope it helps..........
Jun 16, 2008 | NetGear MA111 802.11b Wireless Adapter
Belkin F5D7051 WONT WORK
i got one idea go **** your adapter and your self you ******* *****
May 18, 2008 | Belkin (F5D7050) 802.11a/g/b Wireless...
Driver for bluetooth for win 98
Hi!
1 Was it working before?
2. Is the bluetooth compatible with Win98? Does it meet the bluetooth's minimum requirements?
3. Is your computer an old computer? Maybe your computer's USB ports are USB 1.0 and the 4Gb USB is USB2.0. This I believe will be incompatibile.
4. Try those USB adapters at a different computer to further isolate your problem.
Hope these info helps!
May 01, 2008 | Adapters.com BT-0333 Bluetooth USB Adapter...
Dynex DX-UBDB9 Serial Adapter Logo
158 people viewed this question
Top Dynex Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Dynex Computer and Internet Expert? Answer questions, earn points and help others
