Swintec 2600 Electric Typewriter Logo
A
Anonymous Posted on Feb 12, 2016
How do I replace the correction tape? - Swintec 2600 Electric Typewriter
I installed new correction tape, but there's too much play in it. It keeps unravelling. I have no idea how to tighten it up. When I turn the take-up spool, it just unravels it more without tightening...
Verify that you have installed the proper correction tape. The types of tape that can be used with this system are: Item 1030 - Correctable Film Ribbon, 1230 - Correctable Film Ribbon 2pack, 1031 - Multi Strike Ribbon, 1032 - Nylon Ribbon, 3010 - Lift-off correction tapes (to be used with 1030 and 1230 ribbons), 4010 Cover-up Correction tape (to be used with 1031 and 1032 ribbons).
Make sure that the correction tape is installed properly. Pass the tape through the left guide, behind the ribbon guide and out through the right guide. The rough side of the tape should face the platen. Attach the feeder spool to the pin on the left. Attach the take up spool to the pin on the right. Turn the take up spool counter clockwise until a small amount of tape has wound around it. Replace the cassette ribbon and close the case cover. Press [CODE] + [RESET] to move the carrier to the previous position.
3helpful
Trying to replace the lift-off tape on an IBM Selectric III
Open the gray lever to the right on the carrier.this will release tension on the correcting tape. Now put the supply spool on the left side and bring the take up spool across in front of the card holder. There is a little black wire just right of the card holders opening that looks kind of like a bobby pin , this is the
separator between the ribbon and the correcting tape.The ribbon is in front toward you and the correcting tape is behind. Continue feeding the correcting tape to the take up wheel and take up the slack in the tape then close gray lever.
Changing correction tape
i have the same problem. can't find a manual anywhere. someone please help
2helpful
How do i replace correction tape in brothers gx4500 typewriter
Here is a link to the manual for his model. See page 37 for instructions on how to replace the correction tape.
http://www.brother.ca/en/products/pdf/manuals/SX4000-UG.pdf
Brother ml 100 can't get it off the correction tape mode
First remove the correction tape, then turn it off and back on and let it do it's reset, if it will now type OK check to be sure you have a dry L/O tape, if it is at all tacky replace it with a dry L/O tape.
1helpful
Correction Tape
The correction tape which should be a yellow spool and the correction ribbon cartridge should be a yellow also, sometimes orange, first. The correction tape has to in front of the black correction ribbon. in othe words this is the order. Platen, paper, correction tape, correctable film ribbon, printwheel. Also make sure correction tape is dull side toward paper. Shinny side should face operator...
1helpful
Correction Tape
Two possibilities, one the correction tape is twisted and the wrong side is .facing the paper. The shinny side should be facing you, the dull side facing the paper. Second possibility you must make sure the ribbon is compatible with the correction tape. There are 2 types of ribbons. A correctable one (orange or yellow knob) and a multi strike (blue or purple knob on ribbon cartridge). The lift off correction tape (orange or yellow spools) only works with the correctable ribbon and the cover up correction tape (blue) works with the multistrike ribbon.
4helpful
2answers
Correction tape
To replace the correction tape:
1) use [SPACE BAR] or <<-¦ to move the carrier to the centre of the platen
2) open the top cover
3) remove the cassette ribbon (if installed)
4) pull off both spools, pressing against the correction tape with your thumbs. Bring it back to a position parallel with the platen and lift it up and out.
5) Pass the new tape through the left guide, behind the ribbon guide, and out thropugh the right guide. The rough (stick) side of the tape should face the platen.
6) Attach the feeder spool to the pin on the left
7) Attach the take-up spool to the pin on the right
8) Turn the take-up spool counter-clockwise until a small amount of white tape has wound around it
9) Replace the cassette ribbon and close the top cover
10) Press 'spider web' key +// to move the carrier to the previous position.
Hope this helps.
Regards TC
Correction tape
Does the correction tape move? Does it lift up to the proper height? If it does both of these try advancing it a few inches the tapes get old and the exposed portion won't work. If this helps but it isn't real good get a fresh (not one that has been sitting on the shelf for years and thes will help.
DickyO
4helpful
2answers
Typewriter change correction tape
I just finished replacing mine..You must first remove the ribbon for the typing, this simply lifts off. Then you must place the side with the corrective tape on the left side and the empty end on the right. While doing so, make sure that the ribbon of corrective tape is being placed around the knobs( one on each side) to hold in place. Then feed through and wind up till all the orange has disappeared then replace the Typing ribbon and this should complete the replacement
Top Swintec Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Mitch Vass
Mitch Vass
ADMIN Andrew
ADMIN Andrew
Are you a Swintec Office Equipment and Supply Expert? Answer questions, earn points and help others
