Question about Connex 3300 240-Channels Base CB Radio
Does anyone know the pod too turn for lowering the watts on my connex it is too high and i would like to turn it back also the modulation thanks
    Champion:
  • 219 Answers
You have to adjust the high key first so make sure you're rf power is on high, hope you have a meter set it on the 20 watt scale, key up and turn vr 13
located in back of radio infront of where you're coax connector is until it keys around 12 watts, thats where most connex 33hp should be set,now go to low power and key adjust vr 16 right net to the otherone down to about 3 watts, now you can drive a liners. Mod is Vr 2 right below them two. whistle in mic and turn to get the mod you want.
Posted on Nov 21, 2009
Connex 3300 HP ,tx light on,dead keys 45 - 50 watts ,no modulation
Check for a Bad, whats called the AM regulator on the back corner of chassis by pwr connector. 2sa or 2sb styles. 2sb817 if available is a good $3 replacement.
Nov 04, 2015 | Connex Radio Communications
I recently bought a Connex CX366CE. I plan to install a SLMM-1 SUPER MOD AND SWING POWER MODULATION kit. I plan to hook it to a Viper 25,000 watt antenna. Is this going to work? Do I need an antenna tuner...
you should be fine, check your swr's before and after.a swing kit only throws the carrier and adds more modulation. the connex is a good radio to start with,you should be fine, with the mod kit and radio you will never reach 25k on that antenna with this setup. just make sure the antenna is tuned rite for optimum operation(low swr).
Feb 01, 2015 | Connex Radio Communications
What pod do i turn for modulation and watts
low watts and 95% modulation better then High watts and 95
% modulation
Jan 10, 2014 | Galaxy Radios DX-44V 40-Channels Base CB...
I have a connex cx3300hp i need to know the vr adjustments for meters and power and i dont have no modulation please help me jerry.? thank you.
i have a 10k on a quad mag mount my radio is a galaxy 98vhp peaked and tuned and i talk every where i key on base stations no problem that antenna is a beast you have some issues goin on over there u need to get that tuned i have a flat 1.0 and i run around 250 true watts and my swr never goes past 1.1 you wanna be loud n talk tune that puppy right biggest thing for them is ground best thing is to run it on a huge magnet best ground there is and you have to have good coax that has alot to do with it just tiny little things you have to check make sure everything is set up correctly
Oct 25, 2013 | Connex 3300 240-Channels Base CB Radio
What kind of meter is needed to check modulation on cb radio
astatic 600.It has 3 windows for SWR, Power handles up 5000 watts and modulation cost about 120.00
Sep 06, 2012 | Connex 3300 240-Channels Base CB Radio
Have a new connex 3300hp i can hear everybody else but nobody can hear me when i key up and talk the needle dont even move
look up the tune specs VR13 (L PWR) L32 L33 high power maybe your watts are turned down if it is brand new send it back to the place you bought it from.If the watts are turned all the way down you won't get any carrier your needle is not moving when tranmitting there is no rf power check to see if your tx light is on when depressing the mic button. you should have a rf adjustment turn it clockwise to turn the power up on the front of your radio.or the mods i gave you in the radio.
Mar 31, 2011 | Connex 3300 240-Channels Base CB Radio
Need a good setting on dead key for connex 4300hp for both low and high setting....its putting out almost 130 watts, thanks
put it @ 1-5 on low and max of 10-15w on high so it doesn't kill the transistors 130 is too high.
Feb 16, 2011 | Connex Radio Communications
I bought a used connex 4300hp. i had it "so
IT could??? peak power, 14-15volts yeah.. the 4300 should put out 80w by itself.. as long as you have a low deadkey ie 1-5watts it should be fine. just don't put high wattage into an amp like that.. it will get hot QUICKLY.!!.. make sure your swr's are low low low.. 1.7:1 or lower... so your not getting reflected power... i would put a wattmeter with swrmeter like a mfj. or vectronic cross needle meter inline just to monitor it.... they go for $75 @ most places. Good investment... call email if need more help
Feb 06, 2011 | Connex CX-4300HP CB Radio
Tunring up a cobra 150 gtl/dx
Um... What?? This is hooked to a switch? CB radio by FCC regulations is only supposed to have a max of 4 watts total output. If you can flip it to 7 watts dead key, you are doing really good. It won't do much more then that. It sounds like its set up to run on a linear amplifier, which cannot have more then 3 watts dead key transmitting into it.
Dead key, and modulation are different. You may have a meter that only reads dead key, and won't see the modulation. This radio is probably swinging close to 15-20 watts. you need a meter that can read PEP, Peak envelope power. Cheap meters only read AVG, or average power, witch will only show your dead key.
7 watts dead key is really good for that radio.especially since stock only has 4 watts. you cannot get any higher then that without changing finals.
at 3 watt dead key, or 7 watt dead key, your modulation wattage is still swinging much higher.
Also, you will get more swing with a lower dead key any way, which is better if you want it to be loud.
Leave it alone. its probably set just right.
May 12, 2009 | Cobra 150 GTL DX Base CB Radio
Modulation with my linear
the radio you are trying to fry your amp with is driving the amp to hard. that radio has a toshiba 80 watt final inside the radio you are killing your radio with the dead key at 2 watts it causes the final to overheat and shut down because it is not built to be turned down that much. its best to turn the radio back up and use the radio.
Mar 07, 2009 | Cobra 29 WX NW ST 40-Channels Base CB...
Connex 3300 240-Channels Base CB Radio Logo
614 people viewed this question
Top Connex Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Steve
Steve
Are you a Connex Radio Communication Expert? Answer questions, earn points and help others
