Question about Maytag Neptune MDG5500AW Gas Dryer
Dryer does not switch off automatically, needs to be turned off manually
  • 6,784 Answers
HI. the Control Board is defective, There are two logic chips that are responsible for initiating the proper selected drying cycle. if these chips are damaged, it will prevent the unit from automatically shutting down. replacing this damaged board will fix this issue.
Posted on Jul 26, 2009
Why do the Automatic cycles on my Whirlpool Duet Electric Dryer not always work?
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.htmlGOD IS So GOOD !!!! AND THAT'S WHY MY ADVICE IS FREE
Jul 30, 2014 | Whirlpool Dryers
Ge 5 cycle automatic dryer
check the lid or door switch, open and close the door, when you close it have to make a click if not there you have your problem when the switch goes bad is like when you hace the dryer door open. Hope this help
Jan 29, 2014 | Dryers
KitchenAid electric dryer, Model # 750LQ, has a broken (I believe)cycle selector (timer) control. The dryer turns on when the control is activcated by turning to the right, but is not in automated mode...
If you are setting the unit on automatic and the timer itself is not moving forward to the shut off position and you have to manually turn the timer off then you would need to order and replace the timer itself. If you have any further questions message me back Thanks Rick
p.s If you need me to look up the part number for your unit please provide the full model number of your dryer and I will try to locate the part number Thanks Rick
Jul 01, 2011 | Dryers
My dryer hums but the drum doesn't turn unless I assist it and then the dryer kicks on. The selector switch automatically turns on when I move from the "off" position (the start switch is...
Hello, Thank You for using FixYa. I will be helping you today.Its the switch in the motor thats bad.Thatmay have been the smell the motor burning up.Replace the motor
Thank You and please rate my answer if it was helpful..
Jun 15, 2011 | Frigidaire GLER642A Electric Dryer
The drum on my kenmore 70 series dryer won't turn and the dryer won't get heat up either. The drum will start to turn if we take the lid off and manually push it but not automatically
The dryer will not heat till the motor starts . If the dryer makes a hum when you activate the start switch' but won't start, then either the motor switch is bad or full of lint. If there is no hum then the start switch may be bad.
Nov 22, 2010 | Kenmore 63942 Dryer
My wife just finished drying a load of clothes in our Whirlpool 9250 dryer, cleaned the lint filter, and put in another load. When she went to set it to an automatic cycle the machine simply beeps three...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 28, 2010 | Dryers
My ge automatic dryer model ddp 1275 c willnt
Sounds like motor trying to start. Simplest answer is article of clothing caught in the blower wheel and thus keeping motor from turning. Second is motor switch mounted to motor is bad. Not all dryers replace motor switch separately from the motor. Third, is the motor which contains a new centrifugal start switch with it.
Aug 19, 2009 | GE Dryers
Dryer won't turn off when in automatic cycle.
Typicall there is a moisture sensor or equivalent that tells the dryer in automatic mode to stop (and not bake your clothes). Sound to me this sensor is defective.
Feb 26, 2009 | Amana Dryers
Automatic drying doesn't shut off
its the switch problem its got tripped internally so its not getting shut off.if the switch would have tripped to the opposite side that the dryer would have nit turned ON. so the switch needs to be opened the tripper needs to be replaced.easy job but very technical. thanks
Feb 26, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Maytag Neptune MDG5500AW Gas Dryer Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
