Question about OKI Pacemark 4410 Matrix Printer
Printing too far to the left, the stops are set as far to the right as possible but the text is still printing too far left. rear feed.
I'm trying to print a letter and everytime I do it prints too far to the left and cuts off some of the print.
Posted on Sep 09, 2009
Sato cl408e - printing over perforations. I tried turning the Pitch(all the way to the right) and Offset(all the way to the left), and this helped a little, but still not right. Because of this, when the...
Reset printer sensor threshold setting.
Turn on printer whilst holding down line key untill printer beeps.
Use feed key to step to Gap in display.
Load label plus backing under sensor and not volts reading.
remove labels and place backing only under sensor and note volts reading.
use following formula
High reading + Low reading / 0.5 = Value to use
e.g 2.8 + 1.4 / 0.5 = 2.1.
use result to change value of input using line key once set press feed key to set.
To change label start position use the pitch menu.
Jun 02, 2011 | SATO CL408e Thermal Printer
I removed a jammed sheet of paper through the front opening, Had to pull real hard. Since then, when printing or copying, printer feeds up to 4 extra sheet with each printed page. I suspect some piece of...
Please see this solution from Canon. It is recommended you check your manual for the proper procedure for clearing paper jams. Incorrectly removing jams could damage your printer. Trust the following helps resolve your current issue.
If you do not have a manual it can be downloaded from here:
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mx_series/pixma_mx300#BrochuresAndManuals
Issue: More than one sheet of paper feeds while printing
Solution: Clean the paper feed rollers using the MX300 operator panel
sikaku.gif Cleaning the Paper Feed Roller (Roller Cleaning) Clean the paper feed roller if paper is not fed properly. Cleaning the paper feed roller will wear the roller, so perform this only when necessary.
1. Make sure that the machine is turned on, and then remove any paper from the Rear Tray.
2. Clean the paper feed roller.
(1) Press the Menu button repeatedly until MAINTENANCE appears.
(2) Press the l_mark_s.jpg or r_mark_s.jpg button to select ROLLER CLEANING, then press the OK button.
The paper feed roller will rotate as it is cleaned.
3. Repeat step 2 twice.
4. Open the Paper Output Tray.
(1)Put your finger in the rounded indent beside the Paper Output Tray and open it gently.
(2) Open up and set the Output Tray Extension completely by pressing down the hollow on its front side.
5. Make sure that the paper feed roller stops rotating, then load three or more sheets of A4 or Letter-sized plain paper in portrait orientation in the Rear Tray.
Set the Paper Thickness Lever to the left.
6. Repeat step 2 three times.
The paper cleans the paper feed roller as it feeds through the machine.
If the problem is not resolved, wipe the paper feed roller (A) located on the right side inside the Rear Tray with a moistened cotton swab or the like. Rotate the roller (A) manually as you clean it. Do not touch the roller with your fingers; rotate it with the cotton swab.
Dec 25, 2010 | Canon MX300 Office All-In-One Printer
Zebra Z4M Plus
Is the length of the label correct on the configuration print out?
Else try t check if there isn't a feed or print adjust in the parameters
Jun 25, 2009 | Zebra Z4M+ Printer
Printing small envelopes
In Word 2007, use the Mailing > Envelopes > Options section.
In 2003 I think it was under Tools > Envelopes & Mailings > Options.
There you'll be able to specify if the manual feed is top first or edge first, to the left, centered, or to the right, and how far over and down to place the address and return address.
After a few adjustment runs, it works great.
Jun 09, 2009 | Dell 5110cn Laser Printer
Right side of text doesnt print
Many of these wont' print edge to edge but there may be a setting for it. start>printers (might be in control panel in yours) slect properties for the printer and advanced proterties then printing preferences (specific to your printer) and see if there are any settings. many of these have a 3/4" blank are down one side where it feeds the paper. try to rotate the print 180 (in your print settings) if possible.
Apr 28, 2009 | HP PSC 2175 All-In-One InkJet Printer
HP PSC 2355 All-in-One Operating Problem
Introduction When the all-in-one detects a paper jam, the display will read, " Paper jam: Press OK to continue ." The computer might display the following message: " There is a paper jam (or misfeed). Clear the jam and press the Enter, Resume or OK button on the HP PSC. " This document will assist in correcting paper feed problems such as paper jamming, print slanting, and multiple pages feeding into the all-in-one. Clearing paper jams CAUTION: All paper jams must be removed from the back of the all-in-one through the rear access door. Pulling the paper from the front of the unit rotates the paper feed roller in the wrong direction and can cause damage to the all-in-one.
  1. Turn off the all-in-one and unplug the power cord.
  2. Turn the all-in-one around so the back of the unit is facing out.
  3. Open the rear access door:
    1. Locate the tab on the left side of the door and press it toward the right. The door will shift slightly to the right.
    2. As the door shifts to the right, pull the door out slightly to release.
    3. When the door is released, gently remove the door by sliding the door out and to the left.
    Figure 1: Removing the rear access door c00212276.jpg
  4. Inspect the pressure rollers on the access door. They should be clean and rotate easily. If needed, clean the rollers with a soft lint-free cloth lightly moistened with water (distilled water preferred). If the rollers do not rotate easily, they may need to be replaced.
  5. From the access door opening, gently remove the jammed paper.
  6. Remove the paper stack from the paper supply tray. Discard any paper damaged or bent.
  7. Re-stack the reload the paper into the paper supply tray. Push the stack into the tray until it stops.
  8. Re-seat the rear access door:
    1. Insert the two posts on the right of the door into the holes on the right side of the opening (as shown in the figure below).
    2. Press the tab on the left side of the door toward the right. The door will shift slightly to the right.
    3. As the door shifts to the right, push in the left side of the door to lock it into position.
    Figure 2: Rear access door posts c00212277.jpg
  9. Reconnect the power cord and turn on the unit.
Causes of recurring paper feed problems If paper feed problems occur repeatedly, one of the following might be the cause:
  • Something is obstructing the paper or print cartridge path. Open the cover of the all-in-one and check for obstructions.
  • The rear access door is unlocked or improperly seated. Follow the steps above to remove and re-seat the access door.
  • The paper width guide is not positioned against the paper. Adjust the paper width guide against the edge of the paper.
  • The paper is not supported. Paper should be flat and smooth with no folded, torn, or rough edges. Some glossy and/or coated papers, or reused paper (already printed on one side) can experience a higher incident of paper feed issues.
  • The paper tray is not fully extended.
  • The paper feed rollers need cleaning. Over time paper fibers and dust will stick to the rollers and should be removed. See instructions for cleaning the rollers below.
Paper jam message displays but no paper is jammed The print carriage might be jammed. Follow these steps to correct the problem:
  1. With the power on, lift the print cartridge access door. The print carriage should move to the access area located on the right. If the print carriage stays all the way left, reset the unit by unplugging the then plugging in the power cord. If the carriage still does not move to the right, continue with the steps below.
  2. Disconnect the power cord from the all-in-one.
  3. Remove both print cartridges.
  4. Push the print carriage slightly to the left and then to the right to verify that the print carriage is not jammed. If the print carriage will not move, check for obstructions under and around the carriage.
  5. Close the print cartridge access door.
  6. Plug in the power cord.
  7. When the " Insert Print Cartridges " message displays, open the print cartridge access door and insert the print cartridges. Verify that both cartridges are seated correctly and lock into position.
  8. If the error recurs, contact HP for assistance.
Envelopes The envelope flap can move with the grip of the rollers and cause paper feed problems. Use envelopes with a rectangular flap and/or tuck the flap inside the envelope when printing. The print is skewed or crooked A small amount of skewing is not unusual with printers. When there is too much skewing, the following steps can help reduce the amount.
  1. Adjust the paper width guide to fit against the edges of the paper stack.
  2. Verify that the rear access door is properly seated and locked into position.
  3. Remove the rear access door and clean the paper feed rollers (see the instructions at the bottom of this document).
More than one sheet of paper feeds in at the same time Several paper caused problems can result in more than one page feeding into the unit. Check the list below:
  • Reused paper (paper already printed on one side)
  • Torn or folded paper
  • Textured or coated paper
  • Unsupported specialty paper
To determine if the paper is causing problems, try using clean, undamaged sheets of plain white 70 - 90 g/m2 (20 - 24 pound) inkjet paper, such as HP Multipurpose or Bright White paper. If this paper feeds correctly, the problem is probably with the other paper. Cleaning the paper feed rollers Over time dust and paper fibers will accumulate on the paper feed rollers. This can cause paper feed problems. Follow the steps below to clean the rollers: Figure 3: Paper feed rollers c00212278.jpg
  2. Remove the rear access door (as describe above in this document).
  3. Clean each roller using a clean lint-free cloth lightly moistened with water (distilled water preferred). Rotate the rollers to clean the entire surface.
  4. Verify that the paper feed rollers on the rear access door are clean and rotate easily.
  5. Re-seat the rear access door.
  6. Plug in the power cord and turn on the all-in-one.
Jun 29, 2008 | HP PSC 2355 All-In-One InkJet Printer
Machine will NOT work
If the print carriage is stuck on the far left, gently try to turn the gears a few turn and if you are lucky enough the print carriage will go back to the right.
This is what I did and it is working fine now.
One thing importan, be "gentle" it is easy to break.
Apr 08, 2008 | Victor 1297 Calculator
PAPER JAM
SUGGESTION #1 The print carriage might be jammed. Follow these steps to correct the problem:
SEGGUSTION #2 cleaning rollers Over time dust and paper fibers will accumulate on the paper feed rollers. This can cause paper feed problems. Follow the steps below to clean the rollers: Figure 3: Paper feed rollers c00212278.jpg
If these suggestions don't fix the problem feel free to write back to me. Try to be a little more specific i.e does paper feed properly, error message shows with paper/without paper or both, do any of the lights flash when this happens, have you tried diiferent paper sizes ot types. Have you taken it apart to check for any obstructions?
Jan 06, 2008 | HP PSC 2355 All-In-One InkJet Printer
Feeding
Hello Sarunas,The problem ultimately, might lie with label feeding,Try Printer feeding,when u give the feed button, the labels should automatically, stop at the gap position, try printer calibration settings.
Hope fully, this should solve your problem
If you Any other queries, Related to barcode printer - Sales and Services.
Contact , Trridev Labelss Mfg Co Leading Labels Convertors In Tamil nadu
For more information visit our web page.
Jun 26, 2007 | Argox R-400 Thermal Printer
OKIDATA Mirocline 520 is printing off-center
I assume you've checked Page setup in the particular software you are using. It seems unlikely, but perhaps something is awry with the printhead home position sensor. This device is on the left side of the printer, and essentially sets a reference point, and the printing start position is counted from this reference. Sometimes this sensor is an optical device, other times a mechanical switch. The latter would be more apt to cause problems. If another tech has a better solution, say on!
May 30, 2007 | OKI MICROLINE 520 Matrix Printer
OKI Pacemark 4410 Matrix Printer Logo
489 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
