Question about Whirlpool Dryers
The drum just stopped spining according to my wife
The belt is good as far as i can tell also the drom turns when i spin the motor
    President:
  • Whirlpool Master
  • 1,922 Answers
Chk motor start capacitor if motor has one and sub a new one,make sure motor has power first before trying cap sub-out by that make sure there is power to moror,then unplug unit and sub-out cap,be careful they can retain a charge
Posted on Jul 29, 2009
Heat is blowing out but the drum is not spining
You broughtke the belt of drum wont turn you might take the dryer apart to make sure the idler pulley is spinning free also. They sometimes get tight and burn the belt up.
Apr 10, 2015 | Avanti D110 Electric Portable Dryer
Hi my Zanussi ZWG 1120M washing machine has stopped spinning, no error code is displayed, what could this be?
First check if the water remaining in the drum?
If it is, then the fault is in the drain phase (drain pump,filter...etc.) before the spining cycle.
Otherwise, faulty is motor, belt, electronic....etc.
By the way, model is unknown to me.
Dado
Jan 11, 2015 | Zanussi Washing Machines
THE DRUM ON MY MACHINE ISNT GOING AROUND AND IT'S NOT SPINNING
Is it old washing machine?
One problem could be belt. It could be dropped. If you hear motor spining noise, but drum isnt spining - this is it.
If you cant hear anything - motor carbong brushes..
If not - electronics problems (semistor or etc).
I need more info to help you better.
Apr 05, 2013 | AEG Lavamat 74640 Front Load Washer
The drum does not spin, the blower works, the gas will fire up, belts look to be in tact but may be loose?
Most gas dryers have a tensioner on the drive belt under the drum a metal bar with a teflon pully that is spring loaded to tension the belt. Try spining the drum by hand if it spins freely the belt may have come off the tensioner or it may be streched. If it doesn't turn the drum rollers or bushing may be bad. Without a make and moddel # it's hard to say
Hope this helps
Please leave feedback
Dec 04, 2009 | Dishwashers
Motor runsbut drum very slow to spin in spin cycle
The motor could be on its last leg of working. You can also check to make sure that the belt is not binding against anything under the drum. You may also want to make sure that the conterbalance weight is not hitting the belt. Make sure that your machine is lever and that it does not walk during spining.
Nov 28, 2009 | GE Washing Machines
GE hydrowave 5550 will not spin!!!
go to a laundromat as this is not a quick fix.
If your dryer doesn't tumble, check these:
Belt
Motor
Door switch
Belt Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time.
Jun 18, 2009 | Washing Machines
Dryer won't start spining the drum
The belt is the likely culprit, you have to look inside to see if it is the belt
May 03, 2009 | GE DWSR405EBWW Electric Dryer
Dryer will not spin, belt is not lose
Take off the back and you should see the motor. You can also lean it over on the frontside and get to the motor. If your drum is not turning and the belt is not loose, then the problem lies in the axle or sprocket the drum turns on. It may have seized up and needs to be lubricated. Check your motor and see that it runs.
Dec 27, 2008 | Kenmore 62602 Electric Dryer
Maytag washer lat9206bae drum will not spin switch motor pump ok belts smoke but drom pulley frozen
hi thanks for the question looks like you have a bearing problem the dru wont turn its an expensive repair for that model of maytag they were not a good model thanks for the question the appliance doc
Sep 26, 2008 | Maytag Washing Machines
Machine does Agitate
Open machine's rear panel and remove belt. Check if motor spins (when it should, as per cycle stage). If motor is spining - Move tub manually and check for smooth spin In case it doesn't spin smoothly - maybe that a sock or other piece of clothing get between the clothes tub and the outer tub and prevent tub's spining. If this is the situation, you should remove it. In case motor doesn't spin- Check with multi-meter if it get power. If it get power - The problem is with the motor. Good luck !!
Jun 07, 2006 | Indesit W 123 Front Load Washer
Dryers Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
